slk 230K auto - how to tow? - Mercedes Benz SLK Forum
#1 Old 09-22-2013
Vehicle: 1998 230k
Quoted: 7 Post(s)
1998 230K
Had to get a towtruck yesterday due to the water pump pulley coming loose & shredding the drive belt.
The driver didn't want to lift the front wheels & leave the rears on the road due to it being an auto.
So we lifted the rear & left the front on the ground, however we couldn't get the steering lock on as he wanted to leave it in neutral (apparently the 'bouncing' can cause a problem with the 'park' mechanism even if the handbrake's on.
He put a ratchet strap round the brake pedal to secure the steering wheel, but caused the brake light switch to become adjusted such that the brake lights stay on all the time! (Now fixed by readjusting the switch - not a fun job!).
He did say that there's a way to remove the key (& engage the steering lock) with the 'box in neutral on most cars, but we couldn't see whether it was possible on an SLK.
So my question is.....
If I can only lift 2 wheels, how do I tow an Auto SLK?
cartoony is offline
#2 Old 09-22-2013
Naffdave's Avatar
Vehicle: 2005 SLK 280 7 Speed Tiptronic In Silver
Other Toys: NSM Sattilite Jukebox
Quoted: 22 Post(s)
Send a message via Yahoo to Naffdave
The only way ive ever known how to tow a auto and this is from years ago was to disconnect the prop shaft (transmission shaft) from the gearbox to diff.
Dave
Naffdave is offline
#3 Old 09-22-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
I'm pretty sure ther's something in the handbook about this. Will check and report back.
ajberrow is offline
#4 Old 09-22-2013
ajberrow's Avatar
From UK handbook:
"Towing
Having the car carried away on a transporter or trailer is preferable to towing it away. We recommend the use of a rigid towing bar if towing is necessary.
Automatic Transmission
You may only tow a car with automatic transmission a maximum of 30 miles (approximately 50 km). A maximum towing speed of 30 mph (approximately 50 km/h) must not be exceeded.
The transmission could be damaged if the maximum speed or towing distance is exceeded.
Switch on the ignition (turn the key to position 2 in the ignition lock).
Move the selector lever to position N.
If the car is to be towed for longer distances or if the transmission has been damaged, only tow the car with the rear wheels raised or the propellor shaft disconnected at the rear axle.
If you are towing the car with the front axle raised, the engine must not be running. Application of the brakes by ESP may otherwise destroy the braking system on the rear axle."
ajberrow is offline
The Following User Says Thank You to ajberrow For This Useful Post:
#5 Old 09-22-2013
Vehicle: 1998 230k
Quoted: 7 Post(s)
Many thanks.
The quote from the manual says:
If I tow it with the rear wheels raised, how do I lock the steering? I can only engage the steering lock if the key is out, & I therefore understand that the car must be in park.
a) Is it OK to tow with the rear wheels raised, in park, with the handbrake on?
b) Is there a way to get the key out of the ignition but leave the gearbox in neutral?
cartoony is offline
#6 Old 09-22-2013
ajberrow's Avatar
Would you need to lock the steering?
If it is unlocked, the wheels will follow wherever the car is steered by the towing vehicle.
If it's locked and not dead straight, the wheels'll try to steer the car in whatever direction they're pointing and, even if the amount off dead-centre is tiny, wouldn't that make the car the very devil to tow?
I had a car towed with the rear raised, with steering lock and ignition both off. Seemed to work well.
Anyone know any different?
ajberrow is offline
#7 Old 09-22-2013
Vehicle: 2001 SLK 320
Glad you guys have brought this up. Never would have thought about it. When ever I have needed a tow, they ask what kind of car and have always brought a flatbed.
DIYGirl is offline
#8 Old 09-22-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
The manual will tell you that you cannot tow N slk the regular way. you need to have a flatbed tow truck technically.
slk320chick is offline
#9 Old 09-27-2013
Vehicle: 1998 230k
Quoted: 7 Post(s)
The annual says you CAN tow it, with either the front OR rear wheels raised.
With the front raised, it's max 30mph & max 30 miles.
All I'm trying to work out is how do I get the key out while leaving the car in neutral?
You can do it on most automatics - there's usually a little hidden button hear the gear lever that you need to press.
cartoony is offline
#10 Old 09-27-2013
Minion
Quoted: 148 Post(s)
This is what it says in my manual:
page 249
Mercedes-Benz recommends that the vehicle be transported with all wheels off the ground using flatbed or appropriate wheel/lift/dolly equipment. When circumstances do not permit the recommended towing methods, the vehicle may be towed with all wheels on the ground or front wheels raised only so far as necessary to have the vehicle moved to a safe location where the recommended towing methods can be employed.
#11 Old 09-27-2013
raybonj's Avatar
Vehicle: 2001 SLK 230 BLACK
Other Toys: My Golf Clubs
If you are lifting the rear of the car why do you want to put the car in neutral. If the rear wheels are off the ground the car can be in park and the parking brake can be set if you wish (again not sure why you would set the parking break). The front wheels will roll freely, I would how ever make sure my steering is locked because the front wheels will not always follow the rear of the car, they can turn to far to correct back.
Just my thoughts, but a flat bed is by far the best. I have not seen a tow truck for years that pulls cars any more. I am sure they are out there.
My name is John
raybonj is offline
#12 Old 09-28-2013
Vehicle: 1998 230k
Quoted: 7 Post(s)
Thanks John. I would have thought it fine with the rear wheels raised, hand brake on, but if you see my original post...
cartoony is offline
#13 Old 09-29-2013
raybonj's Avatar
What are you doing going over a dirt road!! LOL. I would think the bouncing in neutral or park would be the same on the transmission, but I am not the tow truck driver. But I would rather have it in park with the rear up, then towing from the front in neutral and thinking he is not going to go over 30 mph. Again my choice would be call a tow truck with a flat bed.
What did you do and did any think happen to the car?
My name is John
raybonj is offline
FOR SALE 2005 (55) MERCEDES-BENZ SLK 350 Tip Auto Russell Dunn SLK Cars For Sale 1 08-22-2013 09:31 AM
SLK 200 Tow Bar? David Tarry SLK R170 General Discussion 0 04-29-2013 02:02 PM
Private R172 Unveiling Reception for SLK Owners! YellowSLK U.S. West Region 5 06-14-2011 10:50 AM
2001 slk 230k auto trans playin up richards711 New Members Introduce Yourself Here 10 05-23-2011 04:36 AM
