Transmission Warmup? - Mercedes Benz SLK Forum
#1 Old 09-19-2013
fastdawg
fastdawg1's Avatar
Vehicle: 2007 SLK350 6spd
Quoted: 94 Post(s)
I've got a 4 speed (I think it's 4) automatic transmission, I've noticed on the cooler mornings it's a bit slow on the up-shifts until it seems to warm up. I've only had the car a few months, and the temps have only been getting into the mid 40's at the coolest, is this nothing unusual? By the time I roll out of the housing development, it's pretty much just fine, that takes maybe about 5 minutes from the start of rolling out of the garage. It's not bad, but it just seems to hang on to 1st a little long until it's warmed up. After that it's perfectly fine. I just wonder if it's a sign of maybe needing the fluid changed in the transmission and maybe a filter if there's one in there? Ferris, Ferris, anyone, anyone?
fastdawg1 is offline
#2 Old 09-19-2013
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Well, your '99 has a drain plug for the torque converter too, so you are lucky in that you can pretty easily replace about 95% of your ATF. That's a job that most agree ought to be done about every 50K miles. Use the correct ATF when you do this job. Hopefully someone will jump in and confirm/deny, but I seem to recall that the transmission is designed to hold the shifts a bit longer until the car warms up.
Len
1999 E300D 215,000 miles
sokoloff is offline
#3 Old 09-19-2013
Dolau's Avatar
Vehicle: SLK 200 kompressor 2003
Other Toys: Yamaha FZ6S2
Mine is the same at 75k miles but I think I read on here that the transmission needs a service every 40k miles which I think is a fluid change and a filter.
From the bills that came with my car I don't think mine has been done at 40k so booking mine in soon with my local garage but this month I had the second pair of tyres and a service and oil change so counting pennies at the moment
Other transmissions are sealed for life
I think you have a five speed transmission - do you have the tip tronic? Down shift once and it goes from drive into 4
Dolau is offline
The Following User Says Thank You to Dolau For This Useful Post:
#4 Old 09-19-2013
fastdawg
fastdawg1's Avatar
Quoted: 94 Post(s)
Being a fairly new owner, I don't have a reference to how it should run, but changing the fluid to me seemed like a no-brainer. I have the same issue with the ride and exhaust noise. I guess I should go out and drive a few to get a feel for how my car should ride and sound. Not that there's issues, I just need a frame of reference.
#5 Old 09-19-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
and here's how to do it
https://www.slkworld.com/slk-r170-cla...id-change.html
ajberrow is offline
The Following 2 Users Say Thank You to ajberrow For This Useful Post:
#6 Old 09-19-2013
Dolau's Avatar
Can't open that on an iPad will try my laptop later
Dolau is offline
#7 Old 09-19-2013
ajberrow's Avatar
That's odd. works fine on my iPad.
ajberrow is offline
#8 Old 09-20-2013
Dolau's Avatar
Error 303 KFC or something
Dolau is offline
#9 Old 09-21-2013
ajberrow's Avatar
Try clearing the cache for your browser on the iPad.
If you're using Safari! go to :
Settings | Safari
Then tap Clear History
Then tap Clear Cookies and Data
ajberrow is offline
The Following User Says Thank You to ajberrow For This Useful Post:
#10 Old 09-21-2013
Dolau's Avatar
KFC domain network error but thanks for the iPad info didn't know I could do that
I will try my laptop tonight as that looks a useful download
Dolau is offline
#11 Old 09-21-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Can you download it and save it to your c drive/desktop? here is the file:
Also, what's your email I'll send it to you that way.
slk320chick is offline
#12 Old 09-21-2013
Vehicle: 2000 SLK230
During a cold start, you engine will shift in higher revs to warm up your catalytic converter into operating temperature ASAP. Its in your manual.
http://www.mbusa.com/vcm/MB/DigitalA...0_slk32amg.pdf
thunderstorm is offline
#13 Old 09-21-2013
ajberrow's Avatar
Why didn't I think of that? Doh!
ajberrow is offline
#14 Old 09-21-2013
Dolau's Avatar
Thanks both despite the error message- while I was out today it downloaded and I printed it out but I will load it up on my laptop so I can save it
Dolau is offline
2005 SLK350 transmission downshift issue Iridium SLK R171 General Discussion 7 11-30-2017 02:40 PM
Lifetime engine & transmission warranty... worth it? jameslk55 SLK R171 General Discussion 16 03-26-2013 02:33 AM
Is my transmission schizo? johnnielee123 SLK R170 General Discussion 3 10-31-2012 01:48 PM
7G transmission service completed efair SLK R171 General Discussion 0 06-04-2012 02:46 PM
Transmission trouble Eightkmeter SLK R171 General Discussion 4 06-09-2009 11:10 AM
