Bad codes - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By slk320chick
  • 1 Post By raybonj
  • 2 Post By slk320chick
#1 Old 09-18-2013
raybonj's Avatar
Vehicle: 2001 SLK 230 BLACK
Other Toys: My Golf Clubs
Bad codes
I got one of those OBDII testers (ELM 327) on line and this is what I came up with.
2002 Mercedes SLK230 with 114,000 mile had 2 bad codes one red P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) not sure how bad this is or what it means. Tried clearing the code but came back.
The other was a gray code
P2032 ( I thought it was code P2022 but there is not a code with that number) Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 2) again not sure what this is or if it is serious.
This is what read out
TID:$06 CID:$02
- Lean to Rich sensor switch time(calculated)
Max: 25,000
Test result value: 65,535
FAIL
Should I be worried.
My name is John
raybonj is offline
#2 Old 09-18-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Let's see what we're working with here..
P0135
P0135 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
Per google:
http://www.obd-codes.com/p0135
Technical Description Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1) What does that mean? This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
Symptoms You will likely notice poor fuel economy the illumination of the MIL. Causes A code P0135 may mean that one or more of the following has happened: O2 Heater element resistance is high Internal short or open in the heater element O2 heater circuit wiring high resistance open or short to ground in the wiring harness
Possible Solutions Repair short or open or high resistance in wiring harness or harness connectors Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
Mercedes OBD Error Code Details for P2032
Check the gas cap
slk320chick is offline
The Following User Says Thank You to slk320chick For This Useful Post:
#3 Old 09-18-2013
raybonj's Avatar
The engine had not completely warmed up could that be the reason for the P0135 code. It was a red code marked important.
I will check gas cap for P2032 but pretty sure it is on tight. I have had that happen on other cars but got light on dash. I have no lights on dash.
Car does have a slight miss when setting at idle sometimes and then sometimes no miss. I was thinking that might be plugs, needing to be changed. Not sure when they were changed if ever. I have only had the car for 2 years but it does have 117,000 on it. Might just change the plugs for fun and something to do when it is raining and I can't play golf.
Thanks for the answers on the codes Chicky.
My name is John
raybonj is offline
#4 Old 09-18-2013
Quoted: 6496 Post(s)
the rubber of the gasket around the gas cap sometimes dries out. just saying
#5 Old 09-18-2013
Quoted: 903 Post(s)
My guess is you need to replace both O2 sensors.
I think something got lost in translation here -- I don't think there is an "exhaust gas temperature sensor". Bank 1 sensor 2 sounds like the downstream O2 sensor.
efair is offline
#6 Old 09-18-2013
raybonj's Avatar
First question Jeff can i buy just the gasket, if so I will buy one and give that a try after all it is a bit old and I am sure it is dried out.
Efair, I will do a search on O2 sensor and see if that is something I can fix or have to take it to my mechanic.
Thanks for the help guys
My name is John
raybonj is offline
#7 Old 09-18-2013
i think the gasket is part of the cap so don't know if you can buy one separately
#8 Old 09-18-2013
raybonj's Avatar
Did a search under changing O2 sensor but did not come up with anything.
My name is John
raybonj is offline
#9 Old 09-18-2013
Vehicle: 2001 SLK 320
You can buy the gasket by itself. Look up gas cap gasket at AutohausAZ. It is $5 or $6. I just bought one.
DIYGirl is offline
The Following User Says Thank You to DIYGirl For This Useful Post:
#10 Old 09-18-2013
Minion
Quoted: 148 Post(s)
lookie lookie
https://www.slkworld.com/slk-r170-gen...-sensor-s.html
JaysonM likes this.
#11 Old 09-18-2013
raybonj's Avatar
Gas cap on order will be here next week.
slk320chick likes this.
My name is John
raybonj is offline
#12 Old 09-18-2013
raybonj's Avatar
Originally Posted by slk320chick View Post
I found this in the link.
I have a Scan Gauge II and noticed that in the pending codes section I would have O2 sensor codes from my 320 while parked and idling or with the engine off. I have not ever had the CEL come on though. What I did was to set the gauge to monitor the O2 voltages and found that while driving the voltages where in the correct ranges. I then checked the pending codes when driving down the road it did not have any registered. If you are seeing the codes in the pending section and you are parked, then you probably are OK.
I might give this a try tomorrow take the car out and drive it and check for codes. It is worth a try.
New OME sensors are between $80 and $120 depending on which one it is up stream or down.
My name is John
raybonj is offline
#13 Old 09-21-2013
raybonj's Avatar
Jeff's right again
I think you might be right about the gas cap, I just noticed that the cover is getting a ring around the gas compartment lid. I am glad I have one on order.
My name is John
raybonj is offline
#14 Old 09-21-2013
Minion
Quoted: 148 Post(s)
Wait a minute how did JB get credit for a new gas cap hello? Man I got the shaft! No love for the chick. I see how it is ray!! You owe me a drink sir! Lol
jbanks15 and raybonj like this.
#15 Old 09-21-2013
Chicky's post says 'check the gascap'
#16 Old 09-21-2013
fastdawg
fastdawg1's Avatar
Vehicle: 2007 SLK350 6spd
Quoted: 95 Post(s)
A bit competitive are we?
fastdawg1 is offline
#17 Old 09-22-2013
Minion
Quoted: 148 Post(s)
Always.. he's like the little brother you want to wake in the middle of the night and give swirlies to.
R171 SLK200K running lean....got fault codes..advice please! loanheadhouse SLK R171 General Discussion 7 10-12-2014 09:57 PM
Getting codes pulled if no check engine lights on phd gator SLK R170 General Discussion 14 09-30-2013 02:41 PM
R171 control (option) codes Tslick SLK R171 General Discussion 24 10-31-2012 02:37 PM
