Ignition key - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By BarrySLK280
  • 1 Post By Dolau
  • 1 Post By Carl Beck
#1 Old 09-18-2013
Dolau's Avatar
Vehicle: SLK 200 kompressor 2003
Other Toys: Yamaha FZ6S2
Ignition key
A couple of times recently the ignition key gets stuck when trying to extract it from the lock
I know that sometimes the key wont turn until you wiggle the steering wheel but this is after a journey and want to take it out
To get it out I have to switch the ignition back on and then off again to get it to come out
Did think I would spray wd40 down the lock but not sure what giblets are down the bottom of the lock
Dolau is offline
#2 Old 09-18-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
I can't imagine that the giblets would react badly to WD40. I use it on everything electrical that needs a clean and never found it to cause a problem.
ajberrow is offline
#3 Old 09-18-2013
raybonj's Avatar
Vehicle: 2001 SLK 230 BLACK
Other Toys: My Golf Clubs
Spray it on the key first and put the key in and out a few times see if that works. That way you don't drown the switch. Just a thought.
My name is John
raybonj is offline
The Following User Says Thank You to raybonj For This Useful Post:
#4 Old 09-18-2013
Dolau's Avatar
Good thinking!
I will try that but it only happens about once a week
Dolau is offline
#5 Old 09-21-2013
Vehicle: 02 230
could be. but you'll not want to drive it until you get it solved. due to the nature of mechanical things it'll fail altogether in a bad neighborhood, with no cell towers. more likely, you'll have to replace the lock. but you can try oiling it. wd isn't oil or lubricant. you can use it to clean the cylinder, then spray in fine 3 in 1 type oil. or silicone.
wolf! is offline
#6 Old 09-21-2013
BarrySLK280's Avatar
Vehicle: 2009 MB SLK 280 Auto
Other Toys: Ford Fiesta 1.5Tdci Econetic Titanium
Quoted: 13 Post(s)
Smile
I use this stuff. Really good for creaks/squeaks and it's dry....
raybonj likes this.
BarrySLK280 is offline
The Following User Says Thank You to BarrySLK280 For This Useful Post:
#7 Old 09-21-2013
Dolau's Avatar
Thanks wolf and Barry. - haven seen that here but will have a look
BarrySLK280 likes this.
Dolau is offline
#8 Old 09-22-2013
Vehicle: 1999 SLK 230 "Sport"
Quoted: 28 Post(s)
I had trouble getting the key out of the ignition at times... Then I read the Owners Manual for another reason... and found out why I was having trouble with the key.
Make sure your foot is OFF the brake pedal and the car is fully in "P" Park.. With the ignition key Off. - you should NOT be able to move the gear selector lever out of that position. Remember to remove your foot from the brake pedal..
FWIW,
Carl B.
etyu likes this.
Carl Beck is offline
The Following 2 Users Say Thank You to Carl Beck For This Useful Post:
#9 Old 09-22-2013
Vehicle: R170 230 in silver 1997
Other Toys: Yamaha FS1E Raleigh Chopper
FWIW,
Carl B.
Took me a while to find that out to remove key !!! No oil needed
Mike C is offline
#10 Old 09-22-2013
Vehicle: SLK 200 R170
Other Toys: Triumph Tiger 1050, Teal type 35
Don't spray WD40 in ignition lock!
Please don't spray WD 40 into your ignition lock you will risk setting fire to your P&J if you do. Use a little light oil on the key.
byjingo is offline
The Following User Says Thank You to byjingo For This Useful Post:
#11 Old 09-23-2013
Dolau's Avatar
Thanks guys,
That is probably it..... Always in a rush!
Thanks by jingo I did wonder
Dolau is offline
Key won't turn in ignition switch jafco SLK R170 General Discussion 38 10-18-2016 03:01 AM
hard to start issue Key fobs or Ignition switch? qwkrn u SLK R171 General Discussion 9 11-18-2015 12:30 AM
Can't unlock with key and can't turn ignition galaxie1964 SLK R171 General Discussion 15 04-20-2013 06:50 PM
Smart key (ignition key) El Barco SLK R171 General Discussion 26 11-28-2012 07:51 AM
Removing Ignition Key Spatengal SLK R170 General Discussion 8 08-20-2012 12:54 PM
