gas hog, black exhaust, fast idle - Mercedes Benz SLK Forum
  • 1 Post By CT_SLK
#1 Old 09-17-2013
Several recent issues with my 1999 SLK 230 include (to me) excessive gasoline usage--about 20 MPG on Super premium, a blackening of the exhaust pipe and a fast idle--about 1K rpm after warmed up. Any place to start looking for the source of these issues before I take it to my local $ervice $hop.
Tom Barnhart is offline
#2 Old 09-17-2013
Quoted: 6496 Post(s)
Techron is the fastest and cheapest attempt.
https://www.slkworld.com/general-disc...esitation.html
#3 Old 09-17-2013
Vehicle: 06 SLK55 Caspian Blue
Other Toys: 07 R500 4Matic Alabaster White, 08 Infiniti G35x
Black exhaust and low mileage sounds like a rich fuel mixture.
Start with the easy stuff. Air filters clean? Intake tubes unrestricted? Fuel filter clean and undamaged? Fuel filter change recently? Defective filter? A bottle of Techron can't hurt. But that will generally increase the amount of fuel and the efficient distribution within the cylinder. That doesn't sound like your problem.
Have you had the car performance tuned on or off a dyno? Generally, a tuner will be leaning out the air fuel ratio not enriching it but they could have screwed up the fuel maps.
Your car is 14 years old. Plugs worn or fouled? Pull them and check the electrodes. Gaps still OK? Any oil around the electrode? Excessive carbon buildup? How about your plug wires? Any cracks in the insulation?
Emission systems are another place to check on an older car but I'd expect a code from the ECU if a sensor goes bad or the exhaust gases are outside the normal operating range.
Fast idle could be the throttle position sensor (TPS). Not sure if your 1999 SLK230 is drive by wire or a mechanical throttle linkage. If it's mechanical, it may be a simple adjustment problem.
At any rate, with the age of the car it may be time for a complete engine checkup and tune including gaskets and seals.
leapyfish likes this.
CT_SLK is offline
#4 Old 09-17-2013
Mensra's Avatar
Quoted: 385 Post(s)
Also an air leak on the vacuum system can cause the computer to run the fuel rich.
Mensra is offline
#5 Old 09-17-2013
Just got the car back from my favorite independent shop. Here is what they did: Checked all codes for faults, replaced plugs and wires, replaced air and fuel filters, cleaned the IAC, the Mass Air Sensor, and throttle body, flushed the injectors, reset everything to spec.
Car runs like a champ. All it takes is parts and money. They also replaced a faulty windshield washer pump and put new wiper blades.
I think I now have a new 14 year old car.
The Following User Says Thank You to Tom Barnhart For This Useful Post:
#6 Old 09-17-2013
Glad you got it sorted!
Blacked out slk230 AgentOnge SLK R170 General Discussion 27 08-22-2016 05:08 PM
fast idle when cold Tom Barnhart SLK R170 General Discussion 2 03-07-2013 09:30 AM
feels like the idle is a bit fast adrose SLK R170 General Discussion 2 10-21-2012 05:17 PM
R172 Detail Specs UK-C200 SLK R172 General Discussion 5 01-19-2011 05:10 PM
