Bas/esp - Mercedes Benz SLK Forum
  • 1 Post By carpetman
#1 Old 09-13-2013
Vehicle: '01 SLK 320 with TSW custom wheels and Hankook low profile tires
Other Toys: Street-modified '07 Heritage Softail Classic
Bas/esp
Torrential rains in NM (worst in 30 years) and I hit a pothole with my right front and the BAS/ESP warning light came on. SLK320 seems to be driving and braking fine. What can I do to clear the light besides taking to MuchoBucks dealer? Sorry to be such a PnInTAs, but it's my first baby.
carpetman is offline
#2 Old 09-13-2013
Vehicle: 2003 SLK32 AMG
Other Toys: 73 Mustang convertible
Quoted: 15 Post(s)
Send a message via MSN to adrose Send a message via Skype™ to adrose
Turn wheel full lock left and right with engine running, that usually fixes it for me!
adrose is offline
#3 Old 09-14-2013
Thanks for the tip. I tried that several times in my garage, but the light is still on.
#4 Old 09-14-2013
Vehicle: 2000 SLK 230
Quoted: 34 Post(s)
your wheels speed sensor may have broken, only way to check that is to either replace it, or take it to the dealer and have them check it
SirClass is offline
#5 Old 09-16-2013
Vehicle: 2004 SLK 32 AMG - Silver
Sensor
You should be able to run the codes and confirm which wheel is having the problem. I think a new sensor is about 130 bucks.
I had a similar issue. Depending on your tools and experience, you may be able to DIY. If not, it's really not that expensive a repair.
Kyngfish is offline
The Following User Says Thank You to Kyngfish For This Useful Post:
#6 Old 09-16-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
It's an oddity the BAS light.. when I first got the car, I was moving it in and out of the garage testing gears etc.. and the slightest lip from the garage floor would set it off. You may want to do the 30 minute disconnect the battery trick to see if the sensor resets itself. If it doesnt and the light is still on, then you'll know you've got a real problem.
Mine turned off after the left right wheel turn though per the manuals instruction.
slk320chick is offline
The Following User Says Thank You to slk320chick For This Useful Post:
#7 Old 09-17-2013
PMB
Vehicle: SLK320
Other Toys: 2006 Mini Cooper, 1981 Yamaha RD250LC, 1996 Suzuki Bandit 600, Motobecane AV92 (being restored).
This happens to mine sometimes when I I have been to the car wash. Usually goes off after a short drive. However, it stayed on for several days during the summer. ABS etc. were working fine, so I was not too worried. Turned out to be a dirty / corroded connection. A bit of a clean up and the problem ahs not come back since - even with the car wash.
PMB is offline
The Following User Says Thank You to PMB For This Useful Post:
#8 Old 09-17-2013
Thanks for all the great suggestions. I'll try the battery disconnect first. Do I need a code reader or is there another way to check the codes. I know on my wife's jeep you turn the key half a dozen times and count the blinking lights, but I think that is more for the 'check engine light'.
#9 Old 09-17-2013
Minion
Quoted: 148 Post(s)
Any auto parts store should have a code reader and be able to pull these for you. At least this is what they do for us in the US. And if there is a stock mb radio in it, call mbusa.com's customer service number and they will give you the radio code after you disconnect the battery if there is a problem wit it.
#10 Old 09-18-2013
30-minute battery disconnect did not work to clear the light so I guess I'll go to the code reader. I have an OBD II reader. Is that going to work and if so, where does it plug in?
#11 Old 09-18-2013
Minion
Quoted: 148 Post(s)
You have a facelift model yes? Look under the dash on the drivers side. There should be an orange plastic tab that you open up, and the odb reader plugs into. But I'm not sure if your year requires the ODB II reader or not. More people will chime in.
#12 Old 09-18-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
I believe that that MY requires an OBDII reader. I bought one that works with Torque for Android for Ł7 (about $12). Not tested extensively yet, but seems to be showing sensible data. More will be posted when I've had a proper play with it.
The socket is next to the bonnet (hood) opening lever, under the dash on driver's side of car on UK models.
ajberrow is offline
#13 Old 09-26-2013
Vehicle: 2001 slk320
Other Toys: john deere tractor
mine does it sometimes .. as a matter of fact it did it this morning ... yesterday i noticed my front right tire is a little low ... this has caused the light before .. i just need to air back up and I bet it will go away ... it has before ...
rdinky1 is offline
#14 Old 09-26-2013
Autozone
Just go to an autoparts store, they will usually pull the codes for free.
If resetting it doesnt work, and it started happening when you slammed into a pothole, I'd be willing to put money on the problem being the sensor needing to be replaced.
Kyngfish is offline
#15 Old 09-29-2013
Thanks to all for the help and suggestions. Took it to my mechanic while I left town for a weekend camping trip and the bas/esp light coming on when I hit the pothole was strictly coincidence. A rodent had been stripping some electrical wires and we guess, when I hit the hole, it jarred a bare wire onto metal and shorted the fault light. He re-taped the wires and re-set the computer and $189 later it's fine.
Thanks again
ajberrow likes this.
The Following User Says Thank You to carpetman For This Useful Post:
#16 Old 09-30-2013
Keep us posted
189 for taping some wires seems really steep. Let us know if that fixes the problem long-term, I'm actually interested in the outcome.
Kyngfish is offline
#17 Old 09-30-2013
Vehicle: 01 320slk
Other Toys: Passat 4mo. Ranger FX4, Hondas, Alfa bits, 500cc Triumph
Must be OEM tape.
Glad you resolved the issue.
I've seen plenty of time consuming electrical issues caused by rodents.
Himecraig is offline
#18 Old 09-30-2013
Tape is free, finding what to tape is $189.
CarolinaBluetec is offline
#19 Old 09-30-2013
Vehicle: 2003 SLK320 Magma Red
Other Toys: 2001 Vulcan 1500
Originally Posted by CarolinaBluetec View Post
Tape is $1, knowing what to tape is $188.
There, I fixed it for you (credit to Henry Ford and numerous other turn of the century factory owners)
spclk is offline
BAS/ESP light paultalb SLK R170 General Discussion 3 10-20-2012 11:53 AM
BAS/ESP Again dekw1 SLK R170 General Discussion 4 07-06-2012 12:04 AM
6 sp g/box oil change and bas/esp light help please barks SLK R170 General Discussion 1 10-14-2011 02:26 PM
BAS/ESP Light dminkara SLK R170 General Discussion 0 10-02-2011 03:46 PM
