Auto Dimming Side View Mirror - Mercedes Benz SLK Forum
  • 1 Post By slk320chick
#1 Old 09-10-2013
Vehicle: 2007 SLK 280
Other Toys: 2013 Kia Sportage
Quoted: 14 Post(s)
The driver's side view mirror on my '99 SLK is on it way out. This mirror has the auto-dimming feature.
The mirror has developed some sort of haze on the inside making it difficult to use. I am thinking the dimming fluid on the inside of the mirror must be going like what happen to the inside rear view mirror.
Well my question, just to replace the mirror glass is around $328 and change. This is from MyMercededparts.com which has decent prices.
Without the auto-dimming function brings it down to $49 and change. Since I have pretty dark tinted windows, I really do not need the dimming function.
Would I be able to use the non-dimming version in my car?
Bassman62 is offline
#2 Old 09-10-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
I don't see why not....isn't the dimming package just an add on feature? I would imagine everything base wise was designed the same way.
I hope someone else that has swapped it out chimes in!
slk320chick is offline
#3 Old 09-10-2013
Quoted: 14 Post(s)
I hope someone chimes in too!
#4 Old 09-10-2013
Mensra's Avatar
Quoted: 385 Post(s)
Hmmmm...... To restate the question I believe, the issue is will you be getting an error if one uses a non-dimming mirror? I don't know if star diagnostics can be set up to disable the requirement that a dimming mirror be installed on the circuit.
Mensra is offline
#5 Old 09-10-2013
Quoted: 14 Post(s)
I'll be getting an error if I use the non-dimming mirror?
#6 Old 09-10-2013
Mensra's Avatar
Quoted: 385 Post(s)
Actually using a non-dimming mirror is not the issue. The question is will the computer reported error if you use a non-dimming mirror. It could be looking to see if the mirror is functioning correctly. Now I don't know if the computer monitors "everything" in the car. If it does not monitor the functioning of the mirror, then you should be able to use a non-dimming mirror without a problem.
Mensra is offline
#7 Old 09-11-2013
Quoted: 14 Post(s)
Ok......now I am not sure which one to get????
I wouldn't think the computer would be that advanced to monitor the mirrors. Maybe on a newer MB. My other concern is would a non-dimming mirror affect the interior center one. I am pretty sure it is the interior mirror that tells the outside one when to dim since the sensors are on the center mirror.
Sent from AutoGuide.com App
#8 Old 09-11-2013
Minion
Quoted: 148 Post(s)
Yet another dumb question but..
Have you called a mercedes service department and asked them if it would work??
raybonj likes this.
#9 Old 09-11-2013
Quoted: 14 Post(s)
Not dumb! Funny you ask because I called today. But my service manager was out today. Tomorrow....
#10 Old 09-11-2013
JiminFL's Avatar
Why not just unplug the existing one and see if a code shows up?
JiminFL is offline
#11 Old 09-21-2013
Minion
Quoted: 148 Post(s)
Was there a resolution to this?
#12 Old 09-21-2013
Quoted: 14 Post(s)
I ask the dealer and even they were not 100% sure. So I just bit the bullet and ordered the auto dimming mirror. Should have it next week.
#13 Old 09-21-2013
Fanatical Member
Stinger's Avatar
Other Toys: yes
I was just gonna say, is the dimming mirror that much more expensive than the "non-dimmer"? It's a great feature to have and if your car is set up for it why not take full advantage of the option.....especially if the cost is relatively small.
Steven
Stinger is offline
#14 Old 09-21-2013
Quoted: 14 Post(s)
The non-dimming mirror is around $40 and change.....the dimming mirror $340 and change. So big difference in price.
#15 Old 09-21-2013
Fanatical Member
Stinger's Avatar
Other Toys: yes
Ouch! PaChing!
Steven
Stinger is offline
#16 Old 09-21-2013
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
It shouldnt throw any codes it a standard mirrir is used, and it it does, it'll be on DAS for the service engineers use ... I've retrofitted a dimming rear view mirror, and the wiring in my (retrofitted) folding door mirrors is there for the dimming side mirrors and I've used my non dimming ones .... no codes that I can see....
Sean
Seanhump is offline
Interior rear view mirror Hotrcknrollgrl SLK R170 General Discussion 11 03-12-2014 08:41 AM
Assistance needed with Auto Dimming rear view mirror Seanhump General Modifications R171 3 02-28-2013 06:08 AM
Driver side mirror replacement daveshea Where to get R170 SLK Items 1 07-19-2008 03:11 AM
passenger side mirror iceborne SLK R171 General Discussion 7 03-18-2008 10:23 AM
