Battery Disconnect-tools always needed? - Mercedes Benz SLK Forum
  • 1 Post By Woolly
#1 Old 09-09-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
I have no idea how to disconnect my battery [no, I don't need to and I'm not experimenting with any mod] but I thought if there were anything basic I should know what to do, I would imagine it would start with disconnecting the battery. So, I head to youtube [shivers] and find this..is it accurate?
slk320chick is offline
#2 Old 09-09-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Always disconnect the negative lead (black or brown) first - this is earthed to the body, so if your spanner (wrench) slips, it won't short out and melt the wrench and ruin the battery - which can happen if you try and disconnect the positive first.
Also, when reconnecting, connect the positive first. When connecting the negative, do it in one firm, deliberate movement - if you are hesitant about it, it can generate sparks (and subsequent electrical 'spikes' ), which the on board electronics don't like.
Woolly is offline
#3 Old 09-09-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
I've installed one of these , makes disconnecting quick , safe and very easy !
http://www.ebay.co.uk/itm/2308250557...84.m1439.l2649
curro101 is offline
#4 Old 09-09-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Also make excellent anti-theft devices. If you're using one on an R170, don't forget to turn the steering wheel two full tuns from lock to lock after reconnecting.
curro101 likes this.
Woolly is offline
#5 Old 09-09-2013
curro101's Avatar
Quoted: 528 Post(s)
I have one on the r171 for the " battery resets " , funnily since I put it in , haven't needed it , and also on my BMW that sits for long periods , that way I know the battery will be the same as I left it , no need for trickle charging !
curro101 is offline
#6 Old 09-09-2013
Minion
Quoted: 148 Post(s)
Could you explain please what it's purpose is? Reading that ebay ad is like german to me.
#7 Old 09-09-2013
raybonj's Avatar
Vehicle: 2001 SLK 230 BLACK
Other Toys: My Golf Clubs
Also make sure you have your radio code or you will be going to the Mercedes Dealer with prof of owner ship to get the code. It has to be reset after you have disconnected the battery.
Number 10 mm socket or wrench should be the size you need to disconnect the terminal.
My name is John
raybonj is offline
#8 Old 09-09-2013
curro101's Avatar
Quoted: 528 Post(s)
You remove the negative from your battery and put this item in its place , you then connect the negative to this !
Disconnecting/connecting the battery is then just a matter of turning the black wheel one way or the other !
It's of a very solid construction and there's no sparking at all , when used !
curro101 is offline
#9 Old 09-09-2013
Minion
Quoted: 148 Post(s)
Curr that's brilliant! I'll have to find one on the us ebay or the local parts store.
Ray-I no longer have the factory radio-would this matter? I would think not.
#10 Old 09-09-2013
Mensra's Avatar
Quoted: 385 Post(s)
Most aftermarket radio nowadays do not have security codes. So, it would not.
Mensra is offline
#11 Old 09-09-2013
curro101's Avatar
Quoted: 528 Post(s)
Something like this ??
http://www.ebay.com/itm/BATTERY-MAST...0c5105&vxp=mtr
curro101 is offline
#12 Old 09-09-2013
leapyfish's Avatar
When disconnecting the battery,
make sure the car is turned off & do not leave the key in the ignition.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
R171 Good Practice Tips (Includes Battery Connection Checklist) DansSlk SLK R171 Class DIY 35 08-31-2018 03:16 AM
Battery Trickle Charger pre-wiring install etyu General Modifications R171 79 02-13-2017 03:34 PM
Aftermarket Head Unit install, Disconnect battery? Mic placement liamstears SLK R171 General Discussion 2 05-17-2013 01:08 PM
going to indy service - details needed brake pads and battery replacement zymotix3 SLK R171 General Discussion 6 04-08-2013 08:23 PM
CDC problems after recent battery disconnect andyrno1 SLK R171 General Discussion 5 03-29-2012 04:36 AM
