Brake Booster Vacuum Hose Replacement - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Woolly
  • 1 Post By DIYGirl
  • 1 Post By DIYGirl
#1 Old 09-03-2013
Vehicle: 2001 SLK 320
When I remove the vacuum hose from the brake booster to replace it, do I need to do anything to "re-pressurize" the system? Or is it a "closed" system until the engine is started and the brake pedal is depressed?
DIYGirl is offline
#2 Old 09-03-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
No, you don't need to do anything. As soon as you start the engine, you'll get inlet manifold depression. Don't worry, it doesn't need pills!! - it's normal.
JaysonM likes this.
Woolly is offline
#3 Old 09-03-2013
Thank you Woolly. Fix was so easy. Glad I can just start her up and drive
DIYGirl is offline
#4 Old 09-03-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Ahem.. where are all of the DIY videos?!? for the reference section!
slk320chick is offline
#5 Old 09-03-2013
Not a video kinda girl but I am working on the DIY. Trying to figure out if I can save in .pdf since I really hate when the photo links disappear on older DIYs
JaysonM likes this.
DIYGirl is offline
#6 Old 09-04-2013
Did you manage to replace the broken plastic connector? If so, can you tell us how you removed it?!
#7 Old 09-04-2013
Minion
Quoted: 148 Post(s)
Create the word doc diy with photos
save as "pdf"
done ty
#8 Old 09-04-2013
For all of the hair pulling on my end, the yellow connector piece was very easy to remove. I had read on another forum to use a wood screw to "gently" grip into the yellow piece, then use the wood screw and lubricant to work it out. Used a 3/8 x 3" wood screw from Home Depot. Worked like a charm. Did not even need the lubricant. I pulled just a little to see if I had gotten a grip on the piece with the threads of the screw it is slipped right out.
The cap with the two tabs that I shattered into a million pieces (before I knew what I was doing) just popped back on the remaining cage piece with just a little push and a click.
The guys a mymercedesparts.com were awesome. I was concerned that the hose was just the hose and not the connector. Confirmed that hose did have the connector and they also helped me figure out that I only needed the cap and not the cage and the o-ring. Saved me $6 in parts. Really cool of them.
Write up coming soon with photos.
JaysonM likes this.
DIYGirl is offline
#9 Old 09-09-2013
The DIY for this has been posted to the R170 DIY thread. If you guys notice any issues that need correction or clarification, just let me know. I will correct the document and re-post. Thanks again to all those that helped me get the info I needed to get the job done.
DIYGirl is offline
brake Bulb Replacement (Even if welded stuck) foreign freak SLK R170 class DIY 2 11-05-2011 02:11 PM
Brake light Switch replacement foreign freak SLK R170 class DIY 0 07-03-2011 12:27 AM
