SLK230 Quarter window problem - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By DIYGirl
Old 09-01-2013
Vehicle: 01 SLK 230
Hey everyone
back here with another problem on my slk230, this time it with the quarter windows not going up.
It started when my dad took it out for a ride and he told me the roof button started blinking and beeping while the roof was up, so he figured he should try to put the roof down and see whats wrong. well he put it down then tried to put it up, everything worked fine except the quarter windows not going up. The motor runs under the quarter windows but they dont come up.
I did some research on google and checked fuses and w.e I could think off including the double tap to get the windows up.... so what else can be wrong?
xxwikkixx is offline
Old 09-01-2013
Vehicle: 2001 SLK 320
There is a motor that runs a wire that makes the window go up and down. That wire can jump off of its wheel and pulley. If that happened, the wire usually gets wrapped up in the regulator. It can't be fixed and has to be replaced. I do not have the part price since I got mine from a salvage yard. The part cost me $95. The part number is in the PDF.
Just re-read your post and see that it is both windows so I am not sure this is the issue, but thought I would post in case it turns out to be the issue
Here is the DIY I followed.
it was posted by Yggdrasil on the benzworldforum
File Type: pdf Replacing rear wing window regulator R170.pdf (1.03 MB, 191 views)
JaysonM and Pep943 like this.
DIYGirl is offline
The Following 2 Users Say Thank You to DIYGirl For This Useful Post:
Old 09-01-2013
Vehicle: 01 SLK 230
thanks a lot but yea its both of my windows that are stuck all the way down, but I will save that DIY for future
Old 09-02-2013
leapyfish's Avatar
In my signature there is a link for a troubleshooting guide,
I think it is symptom number 19 "Rear side windows are not raised"
Possible causes are,
Vario roof "locked" limit switch (left rotary tumbler) (S69/3) or
Vario roof "locked" limit switch (right rotary tumbler) (S69/2) or
Trunk lid "open" limit switch (S69/9) or
Left trunk lid "closed/locked" limit switch (S69/7) or
Right trunk lid "closed/locked" limit switch (S69/8) or
Voltage supply for power windows or
Multi-function control module (N10-3) or
Hydraulic pump (A7/5) or
Vario roof solenoid valve (A7/5y1)
In the Top Operation page of the SLK encyclopedia, click on Top Switches & that will show you where all the switches are.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
Old 12-30-2015
Vehicle: 1998 SLK 230
SLK230 Quarter Window Problem
Followed the instructions posted by DIYGirl. Worked great. Purchased a used part on eBay (modernauto63) for less than $100.
Only tip I have is: The part came with the window in the up position. I had to plug it in and electrically motor it to the down position. Be careful not to go to the full down position or else you will have difficulty getting to one of the bolts, on the glass mounting bracket, because the socket access hole will not be aligned with the bolt head.
sflankey is offline
The Following User Says Thank You to sflankey For This Useful Post:
Tags
roof, slk230, window
Side window question Dr Tomato SLK R170 General Discussion 13 06-22-2017 02:23 PM
how to access rear quarter window??? nguyenphananh General Modifications R171 11 06-29-2013 01:53 PM
Newbe with window problem MSRP General Discussion 14 06-15-2012 10:37 AM
Hi from Australia (problem with R170) Giacinto New Members Introduce Yourself Here 16 12-21-2011 07:07 AM
