Fault Codes On a Used SLK 230 I'm looking at - Mercedes Benz SLK Forum
  • 1 Post By Woolly
#1 Old 08-31-2013
Vehicle: 1998 Black SLK 230
Other Toys: Looking to get a Harley next.
I went to check out this SLK230 and when doing my OBDII test these faults came up, I'm not really mechanically inclined, but with the help of youtube I can fix most things, should I bother buying this car or should I run the other direction and keep looking?
jimithing60089 is offline
#2 Old 09-01-2013
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
I'd say at least a MAF and maybe plugs depending on service history.
Len
1999 E300D 215,000 miles
sokoloff is offline
#3 Old 09-01-2013
Would you buy this car for $5k with these problems?
Also do you think me and my friend could change the MAF or is it too hard?
#4 Old 09-01-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Even if you are a diy'er.. how much time do you have? It seems to me the car is lacking service [clearly] and it's not these particular issues I would be worried about, rather the other parts the errors affect. Are you getting the car for a bargain? Usually if it's too good to be true, it really is.
Flipside
A cheap diy project car with stunning results once the kinks get worked out.
Do you have a piggy bank saved for a rainy day in case you run into something that requires major work?
Food for thought
slk320chick is offline
#5 Old 09-01-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
The MAF is easy to change, but might just need cleaning. As well as checking the plugs, check the plug leads & coil packs.
Tolak likes this.
Woolly is offline
#6 Old 09-01-2013
What year is it? How does the rest of the car look and drive.
#7 Old 09-01-2013
Its a 98 slk230 with 106k miles, the car looks gorgeous, haven't seen many with the interior this well preserved, the car drives and handles great. The only thing I can see is the fabric from the roof is hanging, so I'd have to figure out how to fix that. The car is $5,000.
#8 Old 09-01-2013
The roof fabric can either be reglued or replace the whole unit, dealer charges around $400. Since its a pre facelift model they tend to have PSE and K40 problems. I would do some research on both and then have a good hard look at both items.
#9 Old 09-01-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
If the 'fabric from the roof is hanging', the chances are that the seals on the hydraulic cylinders for the roof mechanism need replacing. Not 'difficult' per se, but 'involved'!!
Woolly is offline
#10 Old 09-01-2013
Do you know of a how to page with pictures or video on how to reglue the roof fabric?
#11 Old 09-01-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
If the seals have gone (which is more than likely by the sound of it) the fabric and the base will be impregnated with hydraulic oil. It will need replacing, as you will never get glue to stick to it. You can often pick up a new headlining from a breakers yard.
Woolly is offline
#12 Old 09-01-2013
What kind of glue to glue the fabric on the top back?
What kind of glue do you guys suggest using to glue the fabric thats hanging from the roof of the car?
#13 Old 09-01-2013
Quoted: 6545 Post(s)
some info here on adhesive:
https://www.slkworld.com/slk-r170-cla...er-solved.html
#14 Old 09-01-2013
Like Woolly says if the cylinders leaked the headliner is junk. Check for signs of oil stains first. In my case the glue just failed over the years and fell apart.
#15 Old 09-01-2013
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
You should replace the fabric when doing the repair. The headliner fabric has a foam backing. It is the foam backing that has good bad that causes the material to drop. Just gluing the old material you will not get a good smooth clean headliner. For not more material that you need it is not that costly. Check Ebay for headliner material.
Gbarringer100 is offline
#16 Old 09-01-2013
Thanks. The foam part is not oily or anything, the roof works perfectly, so maybe the glue just wore off.
#17 Old 09-02-2013
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
If the asking price is $5000 and you know of all of these issues, then you should be able to get the price reduced by the amount of the repairs needed. If you showed the owner the fault codes, then that alone could be a very good bargaining ship. Are there any service records at all?
Len
sokoloff is offline
1999 slk 230 reidclifford New Members Introduce Yourself Here 11 10-14-2012 10:17 PM
SLK 230 & 320 Mille Miglia Edition leapyfish SLK R170 General Discussion 0 05-06-2012 10:44 PM
Help: Fab Design MERCEDES 230 SLK KOMPRESSOR 1999 sunray General Discussion 3 12-24-2008 10:04 AM
SLK 230, break pads... HBK SLK R170 General Discussion 4 11-07-2008 04:44 PM
