headlight and marker light removal - Mercedes Benz SLK Forum
#1 Old 08-30-2013
I need to remove the headlight lens and all info on this site tells me to remove the marker light, but no one tells me how to do it.
I would like a simple explanation of how to get this lens out so that I can access the headlight mounting bolts.
Tom Barnhart is offline
#2 Old 08-30-2013
Quoted: 6558 Post(s)
https://www.slkworld.com/slk-r170-cla...er-lights.html
#3 Old 08-30-2013
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
To remove the headlight unit is done by raising the hood and there are two screws on the top of the headlight, remove them. Under the headlight unit is a tab you use a screw driver to release and the unit is lose to remove. It is a tight to side out, removing the grill helps a little.
Gbarringer100 is offline
#4 Old 09-01-2013
Light Removal, part 2
In my previous query I wanted to know how to remove the Marker (?) or Turn Signal light. My 1999 SLK has a 2 part headlight turn signal light cluster. I have been told that I have to remove the turn signal cluster first and then there are 3 bolts that secure the headlight unit.
I repeat my question: how do I remove the turn signal light unit???
#5 Old 09-01-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Moved to your original thread - it helps other users to keep all the information together.
Woolly is offline
#6 Old 09-01-2013
Vehicle: 2007 SLK 280
Other Toys: 2013 Kia Sportage
Quoted: 14 Post(s)
The turn signal lights slides into the main headlight unit. There is just a tab that holds it in. If you look behind the headlight where turn signal is you'll see it. You press on the tab than push. Than it slides right out. Once it is out you'll see the third screw holding in the main housing.
Sent from AutoGuide.com App
Bassman62 is offline
The Following User Says Thank You to Bassman62 For This Useful Post:
#7 Old 09-01-2013
Quoted: 14 Post(s)
See the tab I am pointing to. Move it to the side a bit and it will come right out
#8 Old 09-01-2013
Quoted: 14 Post(s)
This is what it looks like once out.
#9 Old 09-01-2013
leapyfish's Avatar
Heres another pic
place a screwdriver in the hole & move the screwdriver towards the radiator then rearward.
The turn signal assembly should be able to slide out & you can see the 3rd bolt.
There are instructions in the owners manual & the SLK Encyclopedia under Disassembly
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#10 Old 09-02-2013
Cool
Thanks for the tips. This morning I pushed the magic spot on the turn signal lamp assembly, removed it, then found the 3 bolts holding the headlight assembly and removed them. After a bit of wiggling I had the headlight assembly out, pulled the clips and found the gummy seal had deteriorated in several places.
No hope of buying a replacement, so I used the best available substitute--clear silicone RTV. Put the unit back in place.
Elapsed time: less than 1 hour. Later I tried the water test--No leaks. Problem solved. Let the next owner figure out how to get the RTV seal broken.
Repair of Headlight washer Danvslk SLK R170 General Discussion 4 09-30-2010 08:56 AM
clear front marker lenses V8SLK General Modifications R171 54 12-10-2009 07:37 PM
