SLK230 Bad Sputter - Barely Moves - Mercedes Benz SLK Forum
Old 08-23-2013
Vehicle: 2000 Mercedes SLK230
Angry SLK230 Bad Sputter - Barely Moves
Alright guys,
2000 SLK230, bad sputtering. It misfires on 2 cylinders, pressing gas makes it move, but only just. It actually moves more if I press and release the pedal. Only code thrown was for the Throttle Actuator, which works perfectly. I got this car recently, and when I reset the computer to see if my CD player in fact worked, this began. Checked K40, no bad solders, air filter is brand new K&N, Throttle Actuator works, supercharger is engaging. Transmissions fine, this car SHOULD run perfectly. Changed plugs recently to see if that was the problem, no difference. TPS is working as it should, nothing clogging intakes, cleaned MAF. I've tried everything pretty much. The only thing I haven't taken a close look at is coilpacks.
Is it possible when I put the cable back on the battery it fried a coil? I just can't see it happening. Help me out guys, please.
Pualso is offline
Old 08-23-2013
Is it possible it's the computers sorting out everything? I kept looking it up, do I need to do a driving cycle?
Pualso is offline
Old 08-23-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Take it to an auto shop and let them read the error codes for you. At least that way you'll have a starting point. It should be no charge.
slk320chick is offline
Old 08-23-2013
Already did, the only code it threw was from a while back, and it was the air bypass for the supercharger. I checked it out and it works as it should. No check engine light nor BAS light.
Pualso is offline
Old 08-23-2013
Swap coil packs and see if the missfire moves, if it does then there's your problem. If that doesn't work check into the CPS.
slk320chick likes this.
Old 08-24-2013
Okay so, pretty sure it's coil packs. Both of them. When I switched them it shuddered horribly as before, and it's emitting a strange smell. I'm going to buy some and will replace them next week. I will update progress when I find out. Thanks all.
Pualso is offline
Old 08-24-2013
Before you buy them check the plugs. Also check the K40 for dry or cracked solder joints.
Old 08-25-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
My SLK 230, once I've had the battery disconnected for quite a while (four hours or so) forgets how nicely it should be running, and struggles horribly to run for about 10 minutes; it suddenly remembers, and starts to run as it should.
The only time I found this didn't happen was once I'd cleaned the MAF; that was such a quick job, I might not have exceeded the time for the memory to be lost.
So, to get it going again, let it tick over for a while, then try revving it mildly (at which point it splutters like it's just never going to run right again) and finally, after about 5 minutes, you will get some revs (but not confidence), and after another 5 minutes, thing will start to run OK again.
This may not be your problem, but may be useful for others who have disconnected their battery and so entered this dark world of "doesn't seem to work any more"
Tolak is offline
Old 08-25-2013
Tolak's Avatar
Coils
The coils are relatively inert high power items, and so would not be affected by a power pulse when you connect the battery. In fact, a coil is normally used to control an inrush, to define a soft-start (in non-electronic designs) so is really safe.
But the support circuitry (effectively Capacitive Discharge Ignition) might just be able to suffer. But the normal failure mode for these is to fail, not to become intermittent. Again, it is power circuitry, so robust (and should be supported by robust design).
Dodgy connections (and broken wire harnesses) will make intermittent operation; pulling the cables might help this show up clearly. But all of these would run the same for
And some items (like low pressure fuel rail) will cause bad operation, even at tickover, and worse when throttle is applied. (Good option as described)
Leaking air would affect tickover, but as more throttle is applied, so the effect of leaking air will decrease. (Not applicable in this case.)
You could check the plugs to see what colour they are running at; at tickover, the plugs should be black to beige. When you increase the throttle, running under no load, they should go to beige. If they come out wet with fuel, then the plug and coil are not igniting (properly), if at all.
If you run the engine for a short while, and then whip out the plugs, you can confirm which plugs are running, and which are just getting warm from the compression of the cylinder.
However, if the fuel system is the problem, rather than the ignition system, then the plugs will all be dry, the plug colour will be light beige (since it's running lean) and they will all be the same temperature.
Happy spannering.
Tolak is offline
Old 09-13-2013
Sorry to dig this from the grave but...Alright the parts finally came in, tried to start, sputter and died for the first couple times. Then, it starts, sounds better, then back to horrible. Where to next? Spark plugs, done. Coils, done. MAF clean? Done. No gas on spark plugs, awesome. Still missing, exhaust is LOUD. Cam position sensor? Pushing gas pedal to get higher revs is all wrong. I have to floor it then release the pedal, then the revs go up.
Ideas?
Pualso is offline
Old 09-13-2013
Also already checked k40, no bad solders on it. One looked a little rough so I went ahead and re-soldered the sucker. Figured it couldn't hurt.
Pualso is offline
Old 09-13-2013
Mensra's Avatar
Quoted: 387 Post(s)
Seems whenever you have adequate vacuum the engine runs properly. That's what happens with the RPMs go up and you suddenly let off the throttle, the plate snaps shut and the engine drawdown the vacuum and then starts to run again. On a carburetor car, that would be the engine pulling more fuel into the system. You might want to check your fuel pressure.
Mensra is online now
Old 09-14-2013
Okay so I went out and started it, it fired up shaking horribly again. Thing is..I can't help but wonder if the dealership was lying to me. They said, "It threw a code for ignition." So I've replaced plugs and coils, checked all spark plug wires but no difference, and wires are good. I've bought a bluetooth OBDII reader so I can read codes myself. I'm tired of relying on dealerships here in Germany. BLEH I just want the car to work. BLEH.
Pualso is offline
Old 09-14-2013
Location: Bloomfield Hills Michigan, Spring Hill Florida & Lantana Texas
Vehicle: 2006 SLK55
Other Toys: 2015 Dodge Durabgo RT and 2014 Chrysler 300 SRT
Fuel Filter changed???
matton is offline
Old 09-14-2013
Fuel filter was supposedly changed before the car was sold. However, I am now unsure as to the credibility of the previous owner. It ran perfect up until the day I unplugged that battery for 30 minutes. Then all went bad.
Pualso is offline
Old 09-15-2013
Vehicle: 99 slk230k
Other Toys: Cars lots,Yacht-colvic atlanta 32..
I had this problem recently so changed coil packs and plugs.Also found the MAF sensor was 'oiled up' so cleaned that too. Runs like a dream now.
single is offline
Old 09-15-2013
Vehicle: 2001 SLK 320
When you crank the car and let it run for a minute or so to run all the fluids through, after that minute, does the idle stay under 1000rmp and stay constant? Or does the idle speed go up and down when you are not pushing the gas pedal?
DIYGirl is offline
Old 09-16-2013
Tolak's Avatar
Let it run
Not clear from the posts above, but have you tried to run the car for about 10 minutes, as if you were trying to drive it away?
As mentioned above, I found mine was very bad running after the battery had been disconnected, but after trying to drive it (so used to get-in and go) it took quite a while of spluttering and then I could drive it, and before I got back up the hill to home, it was working OK.
Tolak is offline
Old 09-17-2013
The idle speed stays about the same but there are some misses, you can feel it.
I reset the computer yet again and let it sputter for about 10 minutes, then I revved it a little to see what it would do. For a 1-2 minute gap it ran what felt like perfectly, then it started to stutter again. I noticed if I hold the pedal the RPM's climb and fall with no pedal movement, but no I haven't driven it yet. I feel like it won't move. Should I try and drive it sputtery? If so, how long before I should give up?
Thank you everyone. You have no idea how much this helps.
Pualso is offline
Old 09-17-2013
Idle does however stay under 1000 rpm, sometimes it jumps, it seems like it's trying to learn but I don't know, so I didn't move the car.
Pualso is offline
Tags
coilpack, misfire, sputter
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 3 3 Days Ago 03:13 PM
99 SLK230 Intermitten Sputter kaykay3233 New Members Introduce Yourself Here 18 04-09-2012 06:07 PM
