Valve Cover Stuck - Mercedes Benz SLK Forum
 6Likes
#1 Old 08-21-2013
Vehicle: 2001 SLK 320
Valve Cover Stuck
Replacing the valve cover gasket on SLK 320. Have all of the bolt removed, even removed the plug wires to see if that would give me enough room to wiggle the cover out. No such luck. Do not want to keep banging the cover on the engine parts, that is not a good solution.
What is this (circled in blue)? Can it be removed? If so what issues will it cause? If not, how do you get the valve cover off? Thanks for the help
DIYGirl is offline
#2 Old 08-21-2013
Can you post a general picture? And probably your VIN? I can try to look it up in the Workshop manual.
#3 Old 08-21-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
I've been trying to find it as well, with no luck.
slk320chick is offline
The Following User Says Thank You to slk320chick For This Useful Post:
#4 Old 08-21-2013
Post
I have found info about cylinder head cover removal and removal of cover for crankcase ventilation but I need your VIN to pull the correct one.
#5 Old 08-21-2013
General Photo? I am guessing that this is what you are looking for?
VIN WDBKK65F01F201929
Thanks for the help
DIYGirl is offline
#6 Old 08-21-2013
Thanks for the help
Ok, stay tuned. Let me compile some PDFs for you.
#7 Old 08-21-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Here's your data card:-
Woolly is offline
#8 Old 08-21-2013
Ok, that seems to be the fuel distributor line. You need to disconnect the battery!!!!!! Follow the line it's attached to and there should be a plastic cap on the end (towards the front of the engine). There's a tire-like valve inside, used to release the pressure from the system! There might be a little bit of fuel so use some container. Some PDFs are compiling.
#9 Old 08-21-2013
Ok, here's the information I was able to pull out from the Workshop manual.
If you take your pictures along the way we'll highly appreciate it!!! and then create a DIY thread?!
File Type: pdf SLK 320 install cover for crankcase ventilation.pdf (203.8 KB, 25 views)
File Type: pdf SLK 320 install cylinder head cover - 2.pdf (41.3 KB, 19 views)
File Type: pdf SLK 320 install cylinder head cover.pdf (56.1 KB, 19 views)
File Type: pdf SLK 320 install fuel distributor with injection valves.pdf (36.9 KB, 14 views)
#10 Old 08-21-2013
JaysonM- Awesome. Just what I needed. Ok, so once everything is back in place, what do I need to do to repressurize the fuel lines? Any ideas?
DIYGirl is offline
#11 Old 08-21-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
. You don't need to do anything, the fuel pump will re-pressurise the fuel system
JaysonM likes this.
Woolly is offline
#12 Old 08-21-2013
As Woolly said - no need to do anything! Just make sure everything is screwed back together and once you reconnect the battery and turn the ignition on, the fuel pump will re-pressurize the whole system =) Smart, isn't it? =)
#13 Old 08-21-2013
Great news. You guys have been wonderful. Problem now is that I cannot get the breather cover off. While it is leaking like a sieve, it will not come loose. No wiggle, no give, no nothing. I tried dental floss. I can get it in the places where the leaks are but no go everywhere else.
DIYGirl is offline
#14 Old 08-22-2013
Breather Cover will not budge. Help
I have removed all of the breather cover screws and the Valve Cover Bolts. My breather cover is leaking a vast amount of oil but I cannot get it to budge so that I can re-do the seal. You are not supposed to hit the cover with an object to get it free and you are not supposed to use sharp objects to pry it apart. I have used a razor blade to very carefully remove the excess seal that squeezed out from the last time it was sealed and I have tried dental floss. No luck with either. They are solid like they are still screwed together.
Anyone else have this issue? Any help on how to get this separated from valve cover?
DIYGirl is offline
#15 Old 08-22-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
I've moved your post to your existing thread - it's better to keep all the info together in one place
JaysonM likes this.
Woolly is offline
#16 Old 08-22-2013
I think the manual suggests using some kind of MB solvent to remove the old gasket. Maybe you canfind smth similar in you local parts store?
#17 Old 08-22-2013
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
From what you posted (about cutting away the excess gasket) it's possible the last time the valve covers were removed they've put them back on with liquid gasket - which is like glue. Have you tried a large screw driver?
FUN 4 2
Der Flieger is offline
#18 Old 08-22-2013
Will check and see. Thanks
DIYGirl is offline
#19 Old 08-22-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by Der Flieger View Post
. . . Have you tried a large screw driver?
Not a good idea between an alloy head & rocker cover. A rubber or hide mallet would be more suitable.
Unless of course you meant a
Tolak likes this.
Woolly is offline
#20 Old 08-22-2013
Quoted: 123 Post(s)
Point well taken Woollmeister! See my oil DIY post - I'll have a double.
...what about a small plastic scraper, forced in between? clearly the lady is stuck...
FUN 4 2
Tune up and valve cover gasket follow up question DIYGirl SLK R170 General Discussion 8 08-06-2013 11:35 PM
DIY : R170 : '98 Benz SLK 230 How to exchange engine cover gasket and valve gaskets w PIC dr.Benz SLK R170 class DIY 13 08-06-2013 01:40 PM
Valve cover questions.. Jcornet SLK R170 General Discussion 4 06-27-2013 04:17 PM
Help my paint on the valve cover starts to bubble Berliner Heckflosse General Discussion 9 09-15-2012 01:14 PM
why does the paint peel off the valve cover Berliner Heckflosse General Discussion 2 09-15-2012 10:17 AM
