Brake light wiring colour please - Mercedes Benz SLK Forum
#1 Old 08-17-2013
PaulRUK3's Avatar
Vehicle: R171 SLK350 (2004) Black, 7G-Tronic, Airscarf, Parktronic, Red Heated Seats, AMG Bodykit, STUNNING!
Other Toys: C320 (W203 2000) Auto, Sadly Departed R170 SLK320 (sob)
Quoted: 17 Post(s)
OK, I know, I should probably be able to find the answer using 'search', but, I have been searching for over half an hour and I can't. So, can somebody please tell me the colour of the brake light wiring at the terminal block in the light cluster, I am adding illumination to a perspex wind restrictor that I managed to lay my grubby mits on!
PaulRUK3 is offline
#2 Old 08-17-2013
Quoted: 6580 Post(s)
until someone replies, windrestrictor is very good at answering those questions and promptly too.
#3 Old 08-17-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
Put a bulb on a long lead, so you can see it and press the pedal at the same time, and trial it out!
But consider; if it is bright enough to be seen outside the car, it will be mighty bright inside the car.
Now if you lit the airvents in the hoops, this wold not impact the rear view from teh central mirror!
Tolak is offline
#4 Old 09-28-2013
wtgmd1's Avatar
Vehicle: 2007 SLK55 AMG Iridium Silver
Other Toys: Honda Magna 750, 1986 Sea Ray Seville, 2000 LX470, 1993 Toyota Land Cruiser
I contacted Steve Pennington at Windrestrictor via email as JBanks suggested regarding a brake light wiring schematic or directions to tie the lighted windrestrictor to the brake light; this is the reply I got:
"Hello, sorry we've never had any success with that. So, we prefer hooking up to a constant and using the remote control for dimming and on/off functions.
When we attempted to hardwire, we always got codes that came up on the dash."
So I am still looking to see if anyone out there has done this mod already and can save me from opening up wiring looms....
wtgmd1 is offline
#5 Old 09-28-2013
PaulRUK3's Avatar
Quoted: 17 Post(s)
Thanks for bringing this up again. However, I have since done the mod and it works a treat. As suggested, I did it with trial and error, but a brick took the place of a long wire and bulb! I put the brick on the brake pedal, found a suitable earth near the right hand rear light cluster for the negative wire and poked the positive down each connector on the terminal block until one of them lit up the wind restrictor! I then pushed the wire all the way in and taped to the rest of the wires so that it won't come out. Tah dah!
If you want the colour of the wire for the brake light, let me know, I wasn't too bothered what it was once I'd found it!
As for codes coming up on the dash, not on an R170, and no bulb failure warning either.
Once I have figured out how to upload photos, I will post one of it in operation...... chuffed to little mint balls with it!
PaulRUK3 is offline
#6 Old 09-29-2013
wtgmd1's Avatar
Thanks, Paul.
Yes, please let me know if it is convenient what wires you ended up hooking into.
Todd
wtgmd1 is offline
#7 Old 09-30-2013
PaulRUK3's Avatar
Quoted: 17 Post(s)
Will do Todd, but it may be 2 or 3 days time as the car is garaged away from home and I won't be driving it until then.
PaulRUK3 is offline
#8 Old 10-01-2013
wtgmd1's Avatar
No worries. Only at your convenience.
wtgmd1 is offline
#9 Old 10-03-2013
PaulRUK3's Avatar
Quoted: 17 Post(s)
The positive wire is connected to (pushed into!) pin 3 (black/yellow wire) of the terminal block on the right hand light cluster. The ground is mounted under a nut around 6" inboard of the terminal block. Hope that helps.
PaulRUK3 is offline
#10 Old 10-04-2013
wtgmd1's Avatar
Paul-
thanks so much!
wtgmd1 is offline
Performance Brake Kits at CARiD - Your Safety Guarantee! carid CARiD.com 1 03-20-2013 08:34 AM
Brake Light Flasher noregret4life General Modifications R171 221 02-10-2009 07:38 AM
3rd Brake light flasher noregret4life General Modifications R170 30 12-21-2007 11:22 AM
Rear Brake Light Keeps "not working" SLKman SLK R170 General Discussion 8 09-07-2006 02:10 PM
Brake light outage shanepk General Discussion 7 09-03-2006 07:43 AM
