Low Power, rough idle...One problem after another. - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By CarolinaBluetec
  • 1 Post By fly1705
  • 1 Post By fly1705
#1 Old 08-17-2013
Vehicle: 1998 SLK230 Blue
Other Toys: 1963 W111 Fintail, Boat, Models
Question Low Power, rough idle...One problem after another.
Hi everyone, Just fixed the roof nicely and now another problem.
Over the last year or so occasionally my '98 SLK230 would idle rough and have low power and I only had to restart it once to fix the problem. Then just lately it decided to stay on for good.
I took it to a workshop for some advice whereby a compression test and readout was performed.Compression good and no codes.It's possible that a coil was suspect but it couldn't be defined.(Both coils have small cracks but no evidence of tracking.) While we were idling the engine and just following a few cables, suddenly the engine ran smooth and full power was restored. We both shook heads, it didn't change, so I left (after one or two engine hesitations) and drove a small distance.
Stopped for an errand, back in the car and it came back...Grrrr.
Now I have done a few things....A brand new Bosh MAF fitted 5 days ago. Also inspected the K40 relay...no sign of burning - but resoldered most of PCB just in case. The car starts and stops easily with normal idle after warmupl. Normal temp. No smokey exhaust. Iridium plugs are 12 months old with less than 10,000klms.
Rough idle, poor acceleration, not nice to drive. Removing plug tops one at a time whilst running did not conclude anything. Any thoughts? I hate paying for parts not required and not many used bits available here in AUS. Any help is greatly appreciated......Barry
fly1705 is offline
#2 Old 08-17-2013
Vehicle: R171 SLK 350 (2005)
Hi Barry.
Have you considered the fuel injectors?
I had a '97 SLK 230 (R170) for 12 years before. The only real problem I had with it was with the fuel injectors. Twice! Seven years apart.
The first time: Very rough idle and very powerless. Intense gasoline smell. One of the injectors must have failed in the open position.
The second time: Rough idle and slightly powerless, but not that bad. No smell. The car was drivable. The car dealership had a look at it and said it was the injectors this time too. But I traded in the car for a newer SLK (my current R171) instead of having it repaired, so I can not be 100% sure about the diagnose.
Your case sounds similar to my second time case with the exception that my problem didn't come and go. When it had failed it stayed that way.
mhslk is offline
The Following User Says Thank You to mhslk For This Useful Post:
#3 Old 08-17-2013
Quoted: 6543 Post(s)
moving to r170 general discussion
#4 Old 08-17-2013
Vehicle: 2008 SLK200 Kompressor Fire Opal 6 Spd Manual
Other Toys: Giant & Planet X Road Bikes
Quoted: 26 Post(s)
Hi, does your car have an EGR (exhaust gas recirculation valve) fitted? If so try blanking it off for a while. If it's sticking it will may be bleeding exhaust gases back into the inlet manifold when it should not be.
Rooster is offline
The Following User Says Thank You to Rooster For This Useful Post:
#5 Old 08-17-2013
Since you were following cables and it started working, I would suspect an intermittent break (open circuit) in one of the wires supplying power to a coil or plug. I had this problem on an Audi and it took 3 years to track it down after the dealer threw thousands of dollars in parts at it. What you have sounds like an ignition problem.
Tolak likes this.
CarolinaBluetec is offline
The Following User Says Thank You to CarolinaBluetec For This Useful Post:
#6 Old 08-17-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
As CarolinaBlueTec says, possibly a wiring problem.
Three things might change following a restart:
System reinitialisation; something got confused, and restarting cleared that.
Something cools down, and makes good; unlikely to happen regularly.
Wiring has a break, and teh shake of the engine starting up makes teh wiring good again.
Check wring both on the outgoing and earth (return) paths; put a meter between teh engine block and the negative terminal of the battery when it is misfiring, and if you have any voltage at all, there is your problem.
Tolak is offline
#7 Old 08-19-2013
Thanks for your interest. I'll take this on board and investigate further. I'll remove the injectors to have them cleaned and tested. It's a possibility that this could be the culprit but I still think it's something else. Other clues from other members must be followed up as well. Cheers...
fly1705 is offline
#8 Old 08-19-2013
Have you looked into the CPS or the fuel filter as the culprit?
#9 Old 08-19-2013
I wiggled every wire and loom with a decent force while the engine was running with no change. Someone had changed the O2 sensor without soldering but fixing this had no impact. Previously the engine had been idling for a long time during diagnosis and although not overheating, it suddenly corrected itself and we tried moving wiring etc but it stayed good for 30mins or so until a restart. I'd like to think it was a bad connection but not convinced yet. It may be something else.Looking for the EGR valve....if it has one. Might be able to find a pic. Cheers...
Tolak likes this.
fly1705 is offline
#10 Old 08-19-2013
Thanks for the clues. Will check and report ASAP. Cheers...
fly1705 is offline
#11 Old 08-21-2013
Well I solved the problem with the rough idle....couldn't believe it was a faulty iridium plug! They had only done around 10,000km so I presumed they were still in good order. Also the fault was intermittent - not generally what I would expect from a spark plug. Last week two plugs were removed for inspection and some movement of wiring temporarily corrected the problem and I would have thought more of the wiring/coils rather than the plug.Anyway I re-fitted the original (standard?) BKUR6ET-10's and it's back to full smooth power.
So the question is should I have fitted the Denso IQ20 5302 Iridium's in the first place,is there something better, or was I just unlucky?
Thanks for all your thoughts....i will never presume again!
JaysonM likes this.
fly1705 is offline
#12 Old 08-21-2013
Glad you sorted it all out! I'd say you just got unlucky. I put Bosch spark plugs in mine and they perform same as the OEM NGKs!
#13 Old 08-21-2013
Vehicle: 2001 SLK 320
Trying to find the info again....when I was researching info about issues with my car I came across thread about using platinum plugs and not the iridium. From what I recall they are not completely compatible and cause issues randomly. I do not remember if this was for the M111, m112, M113 engine or all of them. I have the M112 so I know it covered my engine so I changed my order from the iridium to the Bosch platinum. If I find the info again, I will post the thread. I am sure some of the seasoned members here will chime in if I am incorrect or they may be able to find the info quicker. Hope you do not have any new issues anytime soon.
DIYGirl is offline
Tags
power loss, rough idle, slk230
Might have a problem with my power windows Brian_74 SLK R171 General Discussion 8 08-26-2009 05:33 AM
