What is that part of the car called? - Mercedes Benz SLK Forum
 7Likes
#1 Old 08-13-2013
Vehicle: 1999 Mercedes Benz slk 230 Kompressor
I just got my mercedes, and I am trying to figure out ways to get in the trunk, by way of seat removal, I have searched all over the place but I don't know what it is called the wall behind the seats of a 1999 SLK230. Is there a way to remove that and possibly get into the trunk. Reason for this is I have tried many different methods to get the trunk open, but no success. I don't want to take it to a dealer because I can't afford the MB dealer. Any help would be greatly appreciated
bekim is offline
#2 Old 08-13-2013
Quoted: 6543 Post(s)
moving to the r170 general discussion section
The diy section is for already made diys
Someone will respond if they can assist
#3 Old 08-13-2013
rear panel part 10 good luck getting through there
JaysonM likes this.
#4 Old 08-13-2013
Thanks that helps me out more than you know, do you know if that is removable?
bekim is offline
#5 Old 08-14-2013
Quoted: 11 Post(s)
no mate its not you cant get in that way
beerbelly is offline
#6 Old 08-14-2013
cyberdrakon's Avatar
Vehicle: SLK55 2006 widebody
Chats: 7
Quoted: 55 Post(s)
Sometimes it's called a rear firewall...
And there's no way you'll get through there.
cyberdrakon is offline
The Following User Says Thank You to cyberdrakon For This Useful Post:
#7 Old 08-14-2013
well that puts a damper on everything now
bekim is offline
#8 Old 08-14-2013
Quoted: 912 Post(s)
Did you lock your keys in the trunk? Or has the trunk latch malfunctioned?
efair is online now
#9 Old 08-14-2013
I bought the car that way, with the trunk problem, thinking I could get it opened, because the seller said a week ago that everything was working fine, but when a buyer was looking at the car he must have pulled something and since last week it doesn't open, so now the trunk doesn't open and the top doesn't go down, all I hear is something like a motor working when I try to open the top with the switch. I have tried turning the key to the left and trying to open the trunk but no good. Also I know that the top was working before that other buyer touched it, because of the photos the guy showed me on his phone with the date stamps.
bekim is offline
#10 Old 08-14-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
There is a way to manually open and close the top, so I can't imagine why there wouldn't be a way to get the trunk open.
Keys won't work?
Console lock won't unlock it?
slk320chick is offline
#11 Old 08-14-2013
Please please please tell me how to manually open the top, because if I could get the top open there is a point when the trunk opens up and then the top starts to open also, I could get a look inside to see what maybe is stopping the trunk from opening
bekim is offline
#12 Old 08-14-2013
Someone will respond but have you searched, top right, 'open roof manually' or checked your manual?
#13 Old 08-14-2013
Thanks, but all the instructions say that the trunk must be opened to have access to the hydraulics pressure release screw
bekim is offline
#14 Old 08-14-2013
Question
Hmmm... sounds like a failed lock. Although you should be able to unlock it manually by inserting the key... Jeff, I know you pulled the leapyfish's signature where he had all links for roof troubleshooting a day or so ago. Still have that link?
#15 Old 08-14-2013
yes, standby..
#16 Old 08-14-2013
https://www.slkworld.com/762353-post6.html
#17 Old 08-14-2013
Jeff, Thank you sir!
Bakim, check this link for Emergency Top Operation:
P.S. you need a quicktime for that.
https://www.slkworld.com/r170/topoperation.htm
#18 Old 08-14-2013
Thanks JaysonM, but unfortunately I can't even get my top moving because I feel there is some kind of obstruction inside of the trunk. Preventing the trunk from opening and also not allowing me to operate the top, opening or closing. I don't know what the previous owner did to this car for the top to not work. Right now I am feeling like pulling out the license plate and cutting a hole in that area to stick my hand in there to feel for a release spring, and then welding the piece back on again as a last resort. We will see I have not given up yet. I will get this trunk open, to correct this problem.
bekim is offline
#19 Old 08-14-2013
leapyfish's Avatar
Have you tried putting the top up!
Press the roof switch forwards instead of rearwards?
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#20 Old 08-14-2013
Try to follow leapyfish's advice and hold the switch as if you're closing the roof, then try to open the trunk with your key manually.
The Ultimate Home Car Wash for the Ultimate Car Stinger Caring for your SLK 37 07-21-2015 01:05 AM
part number please for the antenna booster in my car the boss SLK R170 General Discussion 7 06-22-2013 04:22 PM
Volvo Car Group demonstrates the ingenious self-parking car jbanks15 Off Topic 3 06-21-2013 01:30 PM
I give you a dedicated thread to the CLK GTR AMG,built to prove AMG's dominance alroumi AMGs 0 05-04-2008 02:17 AM
