It's time for my weekly 170 Gremlin strikes again post - Mercedes Benz SLK Forum
 17Likes
#1 Old 08-05-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
So..
I fixed the brake switch issue, then I get the seat relay fixed..and the new headlights in. I FINALLY get to take the girl out on a gorgeous 70 degree night drive the other day and what do I see? The middle bulb on the instrument panel has gone out.
Now you KNOW I used every curse word I could think of. Big deal? not really. Inconvenient? always. Could I change it out? I would change them all out of course if i decided to dive into the instrument panel. I even found a killer DIY instructional pdf [with pictures and all ] here on our lovely forum. My question to the DIY'ers is.. is it just time consuming or is it tricky getting that sucker back on? Should I attempt it? I am smelling the need for patience here a mile away.
OR.. should I just wait.. that would be the easy answer yes?
slk320chick is offline
#2 Old 08-05-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by slk320chick View Post
.. .. ..OR.. should I just wait.. that would be the easy answer yes?
Depends upon whom, what & how lomg you're waiting for
Woolly is offline
#3 Old 08-05-2013
Minion
Quoted: 148 Post(s)
For one of the other lights to burn out as well
#4 Old 08-05-2013
Mensra's Avatar
Quoted: 400 Post(s)
Well you could always get it fixed October 11, might be a long drive though!
Mensra is offline
#5 Old 08-05-2013
Minion
Quoted: 148 Post(s)
I may as well fess up to the October 11th thing.. I rented a 172.. Bella stays in the garage and mom gets to go out and play with the big boys!
#6 Old 08-05-2013
If you are into the DIY stuff, it will be a good weekend project.
#7 Old 08-05-2013
Minion
Quoted: 148 Post(s)
I am beginning to think that she purposely sabotages herself, JUST to be talked about. These cars have a mind of their own, truly. I'm a diy'er when I'm forced to do so. But I have a very hard time justifying $100 an hour to take some screws off of panels just because its time consuming. Thanks for the post
Keep em coming.
#8 Old 08-05-2013
Keep em coming.
I'd say don't panic chicky =) Just wait till another burns out.
It isn't a hard DIY. Just time consuming and another aspect is that plastic gets fragile over the years and you might crack some hinges/plastic inserts. Mine mostly cracked in areas where bolts are located... Spent lots of time with crazy glue putting it back together so I can screw it back in not applying too much torques on bolts...
Besides you gotta mess in your "lovely" under the wheel area .
It's not expensive, but just time consuming. I was quoted $150 for a bulb change =) Was my 1st DIY, Spent like good 45 minutes getting the dash apart and figuring out what goes where Two T-10 bulbs were around $4 at my local parts store and another hour or so trying to get everything back in place =)
Edit:
Here's Ebay link for bulbs:
http://www.ebay.com/itm/Mercedes-ins...83f4f6&vxp=mtr
and you will also need 2 bulbs of W5W type (otherwise knows as T-10)
http://www.ebay.com/itm/Box-10-Benz-...dfa2de&vxp=mtr
Bucket List likes this.
#9 Old 08-05-2013
simplyslk's Avatar
Other Toys: '13 GLK350
Quoted: 241 Post(s)
Noooooo, why did you tell them?
Marykay
simplyslk is offline
#10 Old 08-05-2013
Minion
Quoted: 148 Post(s)
LOL it's ok.. even I don't know what it will look like I'm horrid at keeping secrets anyway.
#11 Old 08-05-2013
Here's a couple of pictures which might help some. I decided to replace all the bulbs while i had the cluster out and went with red bulbs to match the car. These pictures are not in any kind or order.
AZ SLK likes this.
#12 Old 08-05-2013
Minion
Quoted: 148 Post(s)
red bulbs eh?? hmmm.. thank you dear.
#13 Old 08-05-2013
Does one have to remove the steering wheel in order to disassemble the instrument cluster panel in the R170?
#14 Old 08-05-2013
Minion
Quoted: 148 Post(s)
It depends on if you have telescoping steering or not. At least that's what our DIY says.
File Type: pdf Instrument cluster removal on R170 without telescoping steering.pdf (602.4 KB, 9 views)
etyu likes this.
The Following User Says Thank You to slk320chick For This Useful Post:
#15 Old 08-05-2013
simplyslk's Avatar
Quoted: 241 Post(s)
Chicky, I don't want to come across as a Debbie downer but after seeing lfod's pics are you still thinking of attempting it? If you are, you're crazier and braver than I thought!
Marykay
#16 Old 08-05-2013
raybonj's Avatar
Vehicle: 2001 SLK 230 BLACK
Other Toys: My Golf Clubs
I have to agree with Marykay, Chicky that looks like a lot of work for someone that took her car to the shop to get the head lights put in. I have one of my dash lights out and I not going to even attempt it until all my lights go out and then I might just drive the car during the day.
simplyslk likes this.
My name is John
raybonj is offline
#17 Old 08-05-2013
Minion
Quoted: 148 Post(s)
You're killing me smalls
Bradley61496 likes this.
#18 Old 08-05-2013
You do not, I removed the wheel to replace the multi function switch, while I was in the mood I replaced the bulbs.
slk320chick likes this.
#19 Old 08-06-2013
Vehicle: 1999 slk 230
Quoted: 527 Post(s)
Chicky check under the Bed!!!!! Gremlims love to hide under the Bed and bowl with Light Bulbs ........ they sneak out while you are in the Shower steel them Bulbs from the R 170 bowl a couple of Rounds ........ and put them back in when you are asleep........ No wonder you have Head Light Problems.......
simplyslk and slk320chick like this.
Berliner Heckflosse is offline
#20 Old 08-07-2013
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
I could replace the bulbs for you. No big deal! Ive had my dash all apart before! Pretty simple.
https://www.slkworld.com/slk-r170-gen...-refinish.html
etyu and AZ SLK like this.
Bradley61496 is offline
The Following 2 Users Say Thank You to Bradley61496 For This Useful Post:
Daylight savings time changes tonight 2 am for those that participate. jbanks15 General Discussion 31 11-05-2018 10:16 AM
Daylight savings time changes tonight 2 am for those that participate. jbanks15 General Discussion 16 03-14-2012 11:01 PM
What to expect from 230SLK Pat Dolan SLK R170 General Discussion 16 08-08-2009 07:18 PM
Long Time . . . No Post B55 Off Topic 28 11-29-2007 11:11 PM
