R170 Central Locking - Mercedes Benz SLK Forum
#1 Old 08-03-2013
Vehicle: '00 R170 SLK 200
Other Toys: '79 635 csi, E62 Touring
Hi Guys,
The locks stopped opening from the remote, still lock OK. When you open the Drivers door with the key, only the drivers door unlocks (don't know if this is correct)
A local garage said it was the vacuum pump in the boot, done a bit of research and it seemed logical. Got one from Ebay - same fault. He said its common and its probably another faulty unit. Got a refund and bought another one - fitted myself. Still same fault, I suspicious that I could have three faulty units. There is also a clicking noise sounds like a relay constantly click when you open it with the key.
Any idea's guys.
b16nrh is offline
#2 Old 08-03-2013
Quoted: 6548 Post(s)
Moving to r170 general discussion
#3 Old 08-03-2013
Vehicle: R170 230 in silver 1997
Other Toys: Yamaha FS1E Raleigh Chopper
Got to be an air leak somewhere upstream of the vacuum pump has'nt it
Mike C is offline
#4 Old 08-03-2013
Quoted: 11 Post(s)
usually the filler cap that goes first run the engine to build up vacuum then switch off and lock the car the lock that reacts the slowest will be the culprit. you don't have to change the lock just the vacuum unit
beerbelly is offline
#5 Old 08-05-2013
Vehicle: Red SLK230
Other Toys: 2001 E320
Having just replaced the PSE on my E320, found some useful info in this article here. note the following:
The system uses a vacuum pump mounted under the passenger seat to either suck or blow air through lines to each door. At each door, there is a vacuum diaphragm that over time can leak and eventually fail."
hope this helps
2000 SLK230 is offline
#6 Old 08-05-2013
Originally Posted by 2000 SLK230 View Post
... At each door, there is a vacuum diaphragm that over time can leak and eventually fail."
I do agree with that statement. If you hear a constant clicking then it may mean that the PSE is constantly pumping air due to the leak. When you hear this constant clicking try listening to the PSE in the boot and see if you can hear it working. Also, might worth a try to check all the vacuum tips/connections in doors.
#7 Old 05-10-2014
I had this problem a couple of days ago and discovered that fuse number 26 is the key to the central locking system. Its a 20A fuse and provides power to the PSE pump. Hope this helps everyone. Good luck
Key Fob / Central Locking Problem Sj89 SLK R170 General Discussion 41 05-16-2016 09:58 AM
Central Locking System Problem After New Battery EOLJR General Discussion 15 08-11-2015 07:02 AM
Interior light and central locking switch, dry PSE matphillips SLK R170 General Discussion 23 03-01-2015 04:23 PM
SLK Problem Central Locking donfark SLK R170 General Discussion 9 11-12-2013 03:31 PM
