1997 R170 powerless and high fuel consumption - Mercedes Benz SLK Forum
  • 2 Post By slk320chick
#1 Old 08-02-2013
Vehicle: R170 SLK 230 1997
My car is 1997 R170, just bought for a year, i found that the fuel consumption is quite high, for 100km it used up almost 1/3 tank of fuel...is it normal ?
Moreover, i also found that the engine seems powerless...i don't know why..
I have used computer to check and there is a failure code - P0803.. is this code related to the problem of the engine ? and can anyone advise how to solve the problem ?
Many thanks !!!
livermore_rich is offline
#2 Old 08-02-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
P0803 1 – 4 Upshift (Skip Shift) Solenoid Circuit Malfunction
This is what I've read on the subject:
Your bypassing it because the connection to the solenoids is out and you have an open circuit.
That is what is throwing the engine code. The way a skipshift bypass works is by putting a resistor
in the circuit. When the computer tries to activate the solenoids to lock out gears 2 and 3 it looks
for a voltage on that circuit to tell it that they are working properly. That resistor provides the
voltage drop but does not have enough power going to the solenoids for them to actually lock the gears out.
(or some bypasses disconnect the solenoids all together, but still works because the computer sees the
voltage drop across the resistor) Right now with it burned out you have an open circuit and it is not
seeing the drop, Thus your engine light.
I have no idea how to fix the issue though.
slk320chick is offline
#3 Old 08-02-2013
Cheezhd's Avatar
Vehicle: 1998 SLK 230 Kompressor
Other Toys: '66 GTO, '06 Charger
Sorry Chick - You sound JUST LIKE an engineer LMAO You can explain the circuit but don't know how to fix it. ...still laughing
Cheezhd is offline
#4 Old 08-02-2013
Minion
Quoted: 148 Post(s)
I can't explain it, google explained it. I am only here to assist. Early on I was trying to diagnose any and everything. Then I realized that the people here who really DO know what they are talking about, were very polite to me. Somewhere in hidden cyberspace there is a thread called "slk320chick tries again.. so cute..but".
So, I have tried to adopt the Joe friday method of diagnosis. Only the facts Sir. Because I am positive anyone that knows about the issue will pipe up.
[secretly laughing to myself..cute right? ]
jbanks15 and Cheezhd like this.
#5 Old 08-02-2013
Wheels52's Avatar
Vehicle: 1998 SLK Black Opal
Other Toys: 2010 SV6 Commodore 210kw, 4.7 Mtr Runnabout
I would be checking the Cat Converter has not failed as that can cause the problems you mentioned.
[SIGPIC]Old but not broken!!
Wheels52 is offline
#6 Old 08-03-2013
Very appreciated for your information provided, i will look into more on this subject. By the way, do u have any idea on how to lower the fuel consumption ? coz i already shifted the gear to below 2,000RPM and try not to push it hard...pls advise if you have any idea. Thanks so much!
#7 Old 08-03-2013
Do u have any idea on how to check the cat converter whether it is failed or not ?
Thanks!
#8 Old 08-03-2013
Vehicle: 2001 SLK 3.2 V-6
Other Toys: 2012 Infiniti EX35
Quoted: 11 Post(s)
Send a message via Skype™ to Simprof
Theres a few ways to test the cat but an easy way is to use a Inver red thermometer to check the temp before the cat and the temp after the cat. Run the engine to operating temp then get someone to keep it at 2000/2500 rpms take the temp's if it's good then outlet side should be much higher than the inlet side. If it's not it's plugging up.
Low power bad gas mileage..
Hope this helps..
Simprof is offline
