R170 door latch - Mercedes Benz SLK Forum
  • 1 Post By kenhewitt
#1 Old 08-01-2013
Vehicle: 1999 SLK r230
Red face R170 door latch
Hi Everyone, Two weeks ago I opened my drivers door from the inside and heard a "snap". The handle did not return to the door unless I pushed it in. Yesterday I took the door apart expecting to see a spring either broken or down in the bottom of the door. Found nothing. No sign of a spring. Went on line on E-bay, looked up door latches for pictures. Found the pics but again no spring. Can someone help me. What returns the handle to the stored position? Is their a return spring inside the latch mechanism?
davronoe is offline
#2 Old 08-01-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Here you go:-
Woolly is offline
#3 Old 08-02-2013
Thanks Woolly
The problem I have is when I pull on handle (290) it pulls rod (230) which is connected to mechanism (10). But it does not return to the stored position when I let go of the handle. Now where the rod is connected to the mechanism, I can remove the rod and the mechanism moves freely (not spring loaded). I willing to guess the spring is located inside the latch mechanism. I going to remove the right door panel and see if that latch is spring loaded. I'll let you know my results.
davronoe is offline
#4 Old 05-23-2014
Vehicle: 05' SLK 350
Chats: 10
Originally Posted by davronoe View Post
Thanks Woolly
I believe that it is the rod (230) that pulls the handle back.
MrsSLK350 is offline
#5 Old 04-29-2016
Location: Spain, previously UK, Born and lived in South Africa
Vehicle: 1998 SLK230 project car. (ex UK RHD car)
Other Toys: Fiat Stilo, not a toy but a neccesity
davronoe, I know this is a bit old but wondered if you ever resolved this. There is an eBay site selling repair kits for just about every merc except the R170 and their drawings show a pretty substantial spring as part of those kits. I,m trying to stall having to pull locking unit as these are quite expensive as a replacement,
kenhewitt is offline
#6 Old 04-29-2016
Quoted: 6544 Post(s)
fyi, davronoe has not been on since: Last Activity: 10-23-2015
hopefully he has subscribed to the thread and will be notified
#7 Old 05-08-2016
Please see my other post. The problems are actually the same. Cable provides the tension, not a spring.
https://www.slkworld.com/slk-r170-gen...ml#post2829074
#8 Old 06-02-2016
sharkboards's Avatar
Vehicle: 98 230, 99 slk230 AMG Sport
A little late, but relevant.
Our R170 plastic bits tend to break down with age. On two of my SLKs I have had the displeasure of finding the door latch/actuator broken inside. It's usually a cascading problem, and by the time we detect it, many parts are broken inside. Finding another part is a problem--not just the expense, but because the working replacement is as old as the original.
I have tried various glues, and am having success with basic ABS glue used for plumbing (the original is made of ABS). With patience it can be repaired and strengthened. The key is to roughen any parts needing glue, and treat it like a puzzle. Then add extra ABS where necessary to add strength.
By the way, the ABS glue also works very well on our cracked/broken interior plastic bits.
sharkboards is offline
The Following User Says Thank You to sharkboards For This Useful Post:
Tags
drivers door, latch, r170
How to strengthen signal with the R170 Antenna dsb SLK R170 class DIY 5 02-12-2013 05:56 PM
Does Basset Slooper counts 4 a R170 Problem Berliner Heckflosse SLK R170 General Discussion 3 03-16-2012 12:22 AM
Demon R170.... RacerCub68 SLK R170 General Discussion 1 07-09-2007 05:01 PM
