What to use to Reattach this - Mercedes Benz SLK Forum
  • 2 Post By -1-
#1 Old 07-30-2013
Vehicle: 2001 SLK 3.2 V-6
Other Toys: 2012 Infiniti EX35
Quoted: 11 Post(s)
Send a message via Skype™ to Simprof
On my car the wood ingrain on the center console is coming loose not sure what to use to reattach it. Picture included. Tried contact cement, Krazy glue neither worked.
Simprof is offline
#2 Old 07-31-2013
You image is so small it is difficult to tell, but it looks like the veneer is coming off the area above the climate controls. If so, it is very tricky to get it properly bonded in the vertical position, it will help if you can either take out the module or hold it in place while the adhesive sets up. I can see two possible adhesives the will work. Either Gorilla Glue or two part epoxy, In either case, follow directions carefully, and work carefully. Once it is stuck, it will be there. I have had good luck with quick drying two part epoxy.
CarolinaBluetec is offline
#3 Old 07-31-2013
Quoted: 11 Post(s)
Thanks it is actually coming apart in a few places so like you said I would like to pull the module BUT the car is new to me and I have know idea how to get it out without coursing damage. So could you help me with that. Don’t even know yet how to pull the radio the cup holders or even get the ash tray the piece that holds to actual ash try itself out.
Simprof is offline
#4 Old 07-31-2013
If you have a stock M-B radio, you have to pull it first (make sure you have the radio code, as you will need it if you unplug the radio) with a set of "keys" (you can buy cheap on Ebay). Search this forum and/or Google for SLK console disassembly, etc. Plenty of threads and pictures on this.
#5 Old 07-31-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Just as a side note: I've tried gorilla glue on many different applications throughout the house, it's never worked properly for me.
slk320chick is offline
#6 Old 07-31-2013
Gorilla Glue is great for wood (if you follow directions). It needs moisture to "set it off". Other stuff not so good. If I really, really, want something to stay stuck, I will use a 2 part epoxy for a particular application (metal, wood, marine, what ever) as they are formulated for the particular material(s). The problem with it is getting things apart once you have joined them.
#7 Old 07-31-2013
Gorilla Snot--the yellow weatherproof seal adhesive, sold in most auto parts store--packaged in a red tube.
Will stick any two substances in the world together, use as contact cement, apply, let dry, press pieces in place. May never come off your fingers, clean up parts with Goo-Gone
Tom Barnhart is offline
#8 Old 07-31-2013
Quoted: 11 Post(s)
Better picture I marked it in white where it's loose right now..
I will order the keys from ebay and search how to remove it for repair.
Simprof is offline
#9 Old 07-31-2013
May help if you do them in stages with a a few good pairs of padded C-clamps or something similar.
#10 Old 07-31-2013
-1-
Don - Founding Member #4
-1-'s Avatar
I would not recommend Gorilla Glue or a two part epoxy. Here's what will work, DAP Weldwood Contact Cement/Adhesive. Sold at Lowes, Wal*Mart and just about everywhere. I would recommend the 3 oz bottle with brush. You brush it on the two surfaces to be bonded, let dry, and press together. If you can either completely remove the pieces coming loose, or separate the two surfaces enough to coat the two, let dry, and then press together. Once you press together, it's set, no further drying. I've used this stuff for years on a variety of surfaces and it works well.
etyu and Der Flieger like this.
-1- is offline
#11 Old 08-01-2013
Follow the directions that Don listed above with the contact cement. I repaired mine with the same product and procedure.
Randy
randy993 is offline
#12 Old 08-02-2013
Quoted: 11 Post(s)
I have been unable to find DAP Weldwood Contact Cement/Adhesive. in Canada do you know of anything else like it that I can buy up north. I tried regular contact cement but that will not stick these two parts together at all.
Simprof is offline
#13 Old 08-02-2013
How about Wally Mart? http://www.walmart.com/ip/20370938?w...902876&veh=sem
#14 Old 08-03-2013
Quoted: 11 Post(s)
Yes I see that Wal-Mart sells it but that's in the USA I was hoping to find something in Canada. Next time I go into the USA I will pick some up.
Thanks for the input mate
Simprof is offline
#15 Old 08-06-2013
leapyfish's Avatar
Here's 2 how to remove console DIY's
http://www.benzworld.org/forums/r170...ml#post2897396
& https://www.slkworld.com/r170/dash4.htm
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#16 Old 08-12-2013
Quoted: 11 Post(s)
Thanks everyone pulled it all apart on Sunday it seems someone had tried to fix it in place and made a right mess of it. Had to brake each of the levels apart then clean all the (....) off aplied the contact cement waited for 15 minute then very carefully brought the pieces together. I had to clamp it all up over night for it to allow the pieces they had bent out of place to stick to each other. It's now back in the car but I'm afraid whilst removing the (....) they had left behind I scratch some of the finish. When I wet the wood grain is still there so it's the finish that has come off. But I don't know if it Varnish or Lacquer.
Anyone know.
Simprof is offline
#17 Old 08-12-2013
Lacquer. Strip of finish with stripper made for Lacquer and #0000 steel wool. Hand sand with 400 grit paper, clean with tack cloth. Use automotive grade lacquer, sanding with ever finer paper between coats (as many as you like).
The Following User Says Thank You to CarolinaBluetec For This Useful Post:
