air-conditioning blower just stopped - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By JaysonM
  • 2 Post By jbanks15
#1 Old 07-30-2013
robbiemarcelo's Avatar
Vehicle: 1997 slk230 Linarit Blue
This happened to me twice.
First time I was driving for about 10 minutes , the blower was in number 2, the cabin recirculating switch was on. Then the blower just stopped. No air was coming from the vents. Tried turning the blower switch to off then on but still no air was coming out. Had to park, turn off the engine then stars start it up again. Turn up the blower and air was coming out. Had no problem after that.
After a month, I was driving for about 20 minutes with the blower set to 1 and the cabin recirculating switch was off, the sir just stopped coming out of the vent. Turned the blower switch off then on again and everything was fine again.
In both cases the outside temperature was 33 deg Celsius. No warning light from the dashboard.
Did this happen to any one else? Is this normal?
robbiemarcelo is offline
#2 Old 07-30-2013
Smile
Sounds like a common SLK issue =) Motor brushes start wearing out and fan gets intermittent on/off problems.
Some other thread:
https://www.slkworld.com/slk-r170-gen...operative.html
Are you handy with tools? It's a relatively easy fix
Here's the possible solution:
http://www.benzworld.org/forums/r170...fan-motor.html
And the new brushes will cost you under $30 compare to the new blower motor which will be $$$'s
http://www.ebay.com/itm/110455054501...84.m1423.l2649
slk320chick likes this.
#3 Old 07-30-2013
Thanks for the suggestion. I'll try to observe it some more then I'll check on the brushes.
#4 Old 07-30-2013
Vehicle: 2005 SLK350
edmundo528 is offline
#5 Old 07-30-2013
Quoted: 6570 Post(s)
slk320chick and gr8day4you like this.
#6 Old 03-07-2014
karenroller's Avatar
Vehicle: Mercedez benz SLK 350
This is a common problem of air conditioning. Your compressor which is responsible for providing cool air during summer might have been stopped working. This means, either your car is aging or your compressor needs an experienced ac repair boca raton technicians.
karenroller is offline
#7 Old 03-07-2014
Karen,
Please update your vehicle (model and year) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t already.
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’.
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. https://www.slkworld.com/new-members-...yourself-here/
Join our April 12th meet:
https://www.slkworld.com/u-s-southeast-region/
Air recirculation/flap/inside/outside the cabin air problem JaysonM SLK R170 class DIY 14 03-03-2018 05:50 AM
Crayon like odor from air conditioning - solution Stan Mowre SLK R171 General Discussion 48 01-28-2017 02:51 PM
Air Conditioning Karl SLK R170 General Discussion 13 05-08-2016 08:08 AM
Spring Cleaning: Get your HVAC ready for with 1Z einszett Klima Cleaner DetailersDomain Caring for your SLK 0 04-09-2010 02:25 AM
