Considering 32 AMG. What should I be looking for? - Mercedes Benz SLK Forum
  • 1 Post By alex1118
  • 1 Post By jbanks15
#1 Old 07-30-2013
Vehicle: 2002 SLK AMG
Hey guys,
I've been a lurker on here for 4-5 years I think. I considered buying a 230 about 4 years ago but decided not to. Well, I'm looking again.
We have a friendly friend looking to sell his 2002 SLK 32 AMG. Here's the skinny:
1. 97k miles
2. Somewhat maintenance record (they're the second owners)
3. Car has been well taken care of aesthetically for what its worth.
What do I need to be considering before buying this car? Touch points to make sure the car is in good shape? Is there anyway to tell how good of shape the hard top convertible is? That's a feature that I'll be using every time I go out which is important.
Finally, we've settled on $12,800. Should I be lower?
Thanks,
Alex
alex1118 is offline
#2 Old 07-30-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
1. get the VIN so we can look up the datacard specs for you
2. the amg owners will chime in shortly
slk320chick is offline
#3 Old 07-30-2013
PS
I just found this thread.
https://www.slkworld.com/slk-r170-gen...checklist.html
Anything else on an AMG?
Is that mileage okay for that high performing of an engine?
Alex
alex1118 is offline
#4 Old 07-30-2013
Quoted: 6558 Post(s)
Alex,
Please update your location/vehicle (model and year)(put looking) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t already.
#5 Old 07-30-2013
vehicle checklist
https://www.slkworld.com/general-disc...checklist.html
#6 Old 07-30-2013
VIN is WDBKK66F02F262200
alex1118 is offline
#7 Old 07-30-2013
standby...
slk320chick likes this.
#8 Old 07-30-2013
Here ya go!
#9 Old 07-30-2013
Originally Posted by alex1118 View Post
Hey guys,
1. 97k miles
Thanks,
Alex
Welcome from Houston, TX! 32AMG should be really fun!
If you'll be using the roof quite often then I'd suggest you check it thoroughly. Open/close several times, see if it catches on anything (misalignment). Check the headliner for any oily spots (If there are any then you got a leaking locking cylinder. $30 DIY or $$$$'s at dealership). Check the roof hydraulic fluid. The roof hydraulic pump is located in the trunk on the passenger side. The small quarter side panel right behind the CD change removes (The same place where you get access to change you tail light bulbs) and there you'll see the pump. Can be seen here:
Check the fluid level. It should be between two lines.
Also, from my experience it's a good idea to check the steering drag link (usually it serves 100k miles) for any play and check tie rods. Check steering damper (usually 80k miles life span). See if it's oily. You can't really check it unless you remove it... Removal is just 3 bolts and 7 minutes of labor + dirty hands. This part is usually around $60. Engine mounts - see if there's any unusual resonating vibration that's hard on your ears at certain rpm range. Mine got loud at between 1700-2000 rpm and it was very loud inside the cabin at speeds exceeding 70 mph.
#10 Old 07-30-2013
Vehicle: SLK32 AMG (2002)
Other Toys: Yamaha FZ1 (gen1) and DRZ400E
Quoted: 43 Post(s)
Hi and welcome from a rainy SE of England at the moment.
I have just had mine for 3 months and love it, especially the power, it just pulls and pulls. Mine had a FSH and 81,000 on the clock when I got it and I have put on nearly 5k on since.
The power is one of the things I would check on a good test drive as it should pack a punch and be silky smooth.
I've also heard that the intercooler pump goes at about 40,000 plus miles so this should have been changed by now. A lack of power could be a symptom.
All of the checks in the links above are equally valid and there are rust issues around the wheel arches which are well documented.
Haggle on the price as much as you can if you like it and it feels right and drives right.
Remember these cars were well over Ł45,000 new, most parts are reasonably priced and there is always someone on here who can help you out.
Let us know how you get on.
Steve
steve pring is offline
#11 Old 07-30-2013
Vehicle: 2003 SLK32 AMG
Other Toys: 73 Mustang convertible
Quoted: 15 Post(s)
Send a message via MSN to adrose Send a message via Skype™ to adrose
108000 miles
PS
Alex
10 years old next month,its still bringing smiles from me and screams from my wife!
Had 2 intercooler pumps,46k and 76k.miles,7 heated seat elements(in warranty) now not working.Otherwise,engine mounts and tie rods,steering damper.
$52000 new.
Need tires every 12k or 12 months!
Maintain it and it will last for 50 years.
adrose is offline
SLK 171 350 by Tzitzos tzitzos General Modifications R171 86 11-02-2012 06:34 PM
Piston Heads SLK 55 AMG Review Valkirk SLK R172 General Discussion 0 12-28-2011 03:57 AM
AMGPL: AMG 5.5-litre V8 biturbo engine Cold Shot AMGs 14 03-21-2010 09:11 AM
MB Official Release of 2009 SLK Cold Shot SLK R171 General Discussion 208 10-13-2008 02:35 PM
NY Auto Show AMG Event? editor58 General Discussion 7 03-21-2008 12:32 AM
