170 updates - Mercedes Benz SLK Forum
#1 Old 07-26-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
170 updates
On Monday I will be completing the first real set of body modifications to the slk. But now, I need to add things to the 2014 spring list. One of the very first things I saw when I first bought her, was how ugly the metal looked behind the wheels [the brakes]. Throughout reading the multiple threads, I remember seeing something about specialty brakes?
New rims are #1 on the list for the Spring 2014 project. But when I do the rims, I want to do the brakes as well. So take me to brake school.
slk320chick is offline
#2 Old 07-26-2013
Cheezhd's Avatar
Vehicle: 1998 SLK 230 Kompressor
Other Toys: '66 GTO, '06 Charger
Depends on how deep your pockets are... I put these on my Charger - $5,000. They perform exceptionally and look great.
Cheezhd is offline
#3 Old 07-26-2013
Minion
Quoted: 148 Post(s)
They won't be anywhere near that.. but thank you for posting . I found 1k ea rims that I just about lost my mind for, but that's not going on the girl either. I have to be reasonable with a 2nd vehicle. I'm not cheap with her, but 5k seems a little extravagent for my taste packer lover
#4 Old 07-26-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Hi Chicky, check out THESE rims - all genuine MB, and shipping cost to 'merrica is not that exorbitant
slk320chick likes this.
Woolly is offline
#5 Old 07-26-2013
I'm planning on installing EBC rotors in the future. I don't know about changing the brake calipers. Probably not. I'm not a racer and the stopping power is good with my stock brakes. I might just repaint the stock ones into black color to match the car.
Take a look and see if you like these:
http://ebcrotors.com/p-224-ebc-ultimax-rotors.aspx
They have other styles too. =) Repainting calipers seems like a cost saving option
#6 Old 07-26-2013
Minion
Quoted: 148 Post(s)
Really .. I need the basics. If all I'm looking to do is make them look good, which components are needed? I probably don't have to reinvent the wheel [nyuk nyuk nyuk]. For example brakes consist of what? pads shoes roters blah blah blah? But what would I change to make them look good Think CHICK.. with a little bit of functionality
#7 Old 07-26-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by slk320chick View Post
.. .. .. Think CHIC .. .. ..
I often do - one of my fave bands!!
Woolly is offline
#8 Old 07-26-2013
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Chick... go to search, your friend, somewhere out there was a thread about painting your calipers (the part that actuates your pads, and red in the foto above) - it has to be high heat paint, you can put in contrasting/white lettering. Rotors are pretty much equal (price point wise) - are the 170 rotors cross drilled? (ie holes through them, swiss cheese style). Keeps them cooler.
Good luck with your rims - you want something different than OEM? If not, an alternative would be to have the OEM ones redone while it's hibernating...
FUN 4 2
Der Flieger is offline
#9 Old 07-26-2013
Minion
Quoted: 148 Post(s)
The oem rims are ugly..always have been. I'm thinking more along the lines of these:
http://www.bigbrandwheels.com/XXR-Wh...d-Stripe/5720/
#10 Old 07-26-2013
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
Go with ceramic pads to stop all the black brake dust. You can paint the calipers and the rotors where the pads do not rub. Calipers paint red or silver or black is what most do and the rotors paint silver. You might want to replace the rotors with stock or an aftermarket that meets OE standards if they are worn down to near min requirement specs. Good luck in picking out new wheels.
Gbarringer100 is online now
#11 Old 07-26-2013
If you decide to go with ceramic brake pads then you'll definitely need cross-drilled and/or slotted rotors. Otherwise they will be squeaky... I have this issue after I got ceramic brake pads. Yes, it's a lot less dust but one needs to have different rotors.
As for the brake calipers if you want them to look nice it's better and cheaper to repaint them. Aftermarket premium Brembos will cost you $$$$'...
I found a different set from CEika manufacturer. But it's also pricey... Front set will cost you at leas $850...
http://ceikaperformance.com/Small-6-...e-kit-p29.html
Some find on the brake calipers:
http://www.buybrakes.com/p-681-nht-c...-calipers.aspx
Here's some info about the caliper paint:
http://www.formymercedes.com/mb_resu...iper+Paint+Kit
I think this is a good kit which includes everything you need =)
You can google for the heat resistant/brake caliper paint.
#12 Old 07-26-2013
Minion
Quoted: 148 Post(s)
When it comes to center caps though, will I be able to purchase mb caps and put them in any rims? I guess what I'm asking [while we were talking about wheels] is can I buy any kind of rim, and just replace the center cap with the mb cap?
#13 Old 07-26-2013
I would say MB caps won't fit every rim. Usually MB caps have the diameter of 75mm. You better check with the seller of the rims and ask if 75mm caps will fit the aftermarket rim
#14 Old 07-26-2013
XOFMOT's Avatar
Vehicle: 2001 SLK 230
THanks!!! Now you got me looking at wheels!!!! Was originally gonna refinish the factory ones til I saw this....
Gold may work quite well on Bella and Lucy!!!
XOFMOT is offline
#15 Old 07-26-2013
Minion
Quoted: 148 Post(s)
You can't get gold.. you changed lucy's headlights to the black casing...have to go darker on the rims my dear.. like these!
http://www.ebay.com/itm/16-WHEELS-RI...cc0e11&vxp=mtr
Spring is a long way off.. I have some time
#16 Old 07-26-2013
XOFMOT's Avatar
I don't know about that just yet...still evaluating!! LOL
XOFMOT is offline
#17 Old 07-26-2013
XOFMOT's Avatar
Bronze not to bad either!!
XOFMOT is offline
#18 Old 07-26-2013
XOFMOT's Avatar
Kinda like these and they make them for our car too!!
XOFMOT is offline
#19 Old 07-26-2013
Minion
Quoted: 148 Post(s)
Other than the red and black combo other colors won't match.
#20 Old 07-26-2013
XOFMOT's Avatar
I may have to do some photoshop'ing to see. but your prob right!!
XOFMOT is offline
SLK 350 2004 program Updates? Finn-SLK350 SLK R171 General Discussion 10 09-27-2010 12:53 PM
2011 SLK Updates mb911 SLK R171 General Discussion 13 05-19-2010 12:07 PM
What to expect from 230SLK Pat Dolan SLK R170 General Discussion 16 08-08-2009 07:18 PM
