Won't Start-Showed PO170 Fuel Trim - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By JaysonM
  • 1 Post By JaysonM
  • 4 Post By JBeck
  • 2 Post By ichris93
#1 Old 07-25-2013
Vehicle: 1999 SLK230 Kompressor
Other Toys: Old Harley, Jetski
Hi Everyone, My 99' slk230 just got out of the auto body shop about 2 weeks ago for a small hit in the quarter panel. They replaced my vario pump which had stop working about 6 months ago. Bonus
A few days ago the "check engine light" lit up and showed a PO170 Fuel Trim indication. The car still ran ok, a little sluggish. I have been on the forum looking this up, and first thing this morning the car will barely start and then dies. It won't go anywhere now.
Starter and battery crank the engine over with no problem and it's trying to go but won't stay running for more than a few seconds.
K40 relay has been fixed about a year ago. I'm just trying to figure out where to start looking, fuel filter, mas, crankshaft sensor?? Anybody have a good starting point.
Is it possible that autobody dust got in the mass air flow sensor and affected it? Any help is greatly appreciated.
JBeck is offline
#2 Old 07-25-2013
Some info I googled:
http://www.obd-codes.com/p0170
Check you MAF sensor. Try cleaning it. (I used electric contact cleaner on mine last time). See if there's any oil present in the pipe where MAF connects.
Here's a possible cause of MAF contamination:
http://forums.mercedesclub.org.uk/sh...ad.php?t=34036
Desert_SLK likes this.
#3 Old 07-25-2013
Dead SLK
Thanks for response, I did clean the MAF sensor about 3-4 months ago. But since then it was in the auto body shop for 3 weeks. I am going to try re-cleaning it.
JBeck is offline
#4 Old 07-25-2013
Jason, that's an interesting article on the oil contamination problem with high mileage cars. I've got 100K miles on the car, will try cleaning MAF tonight and see what happens and will also look for oil residue problem. Thanks
JBeck is offline
#5 Old 07-25-2013
I have cleaned this area couple months ago and I still get the oil leaking down this pipe. I'm 100% sure my air flow nozzles are at least 90% blocked due to gunk building up. Already ordered the parts which cost me $50. The biggest cost was the PVC Valve (T-piece) $20. I could have used the old one but I've read that these things get contaminated and it's better to replace them every 50,000 miles or so. Not a big deal =) Will post DIY as soon as I get to this repairs.
#6 Old 07-25-2013
Here's a good article about the PCV valve contamination, why we should protect it using oil catch tanks.
http://wiki.answers.com/Q/What_is_an_oil_catch_can
And a very good explanation of the oil catch install on our fellow benzworld!
http://www.benzworld.org/forums/r170...tallation.html
I actually like the idea!!!! Do it once properly and be done with it!
#7 Old 07-25-2013
And the installation for post facelift models.
https://www.slkworld.com/slk-r170-gen...-plumbing.html
Damn, I keep bumping this thread! Got really hooked up on the idea of oil catch tank!
#8 Old 07-26-2013
Fixed!!!
The car would not run, took out the MAF and cleaned it with CRC cleaner. Put it back in 15 minutes later and the car started and runs perfect. I did have a few small spots of oil in the black air tubing. Jason you were exactly right about the blow back of oil with higher mileage cars. I'm going to keep my eye on it and possibly do the procedure to clean everything out once and for all.
Thanks again everyone, this forum rocks!! (I used the other half of the can on an high mileage work van, and it's running considerably better as well)
JBeck is offline
#9 Old 07-26-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Brilliant!!!!! nice work J.
slk320chick is offline
The Following User Says Thank You to slk320chick For This Useful Post:
#10 Old 11-08-2014
Vehicle: '99 SLK 230
I'm having the same problem with my 99 SLK 230 cel p0170 by using the crc cleaner would get the job done last year, but the MAF is completely dead. So where can I get a new mass air flow sensor for a decent price?
102 MB is offline
#11 Old 11-08-2014
Vehicle: SLK
Quoted: 20 Post(s)
Very good work/information Jason!
Something to look at if I start getting the following: MIL (Malfunction Indicator Lamp) Illumination Start and stall Poor fuel economy Black smoke at tailpipe Hesitation/misfire at idle or under load.
Since I plan to keep my 99 forever and don't experience any of these problems yet (79K miles), is there any preventive maintenance plan to avoid or prolong these issues? Do you think the type of oil (synthetic vs standard) oil would make a difference? One more reason to keep the oil changed and clean!
Jason - again great post!
Desert_SLK is offline
#12 Old 11-08-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Unfortunately the MAF seems to be one of those parts that if you don't go original ( or original make , Bosch etc ) they tend to play up sooner or later !
With the price they have , you might want to try one from a breakers ?
curro101 is offline
#13 Old 11-09-2014
You're absolutely right, I read it here somewhere that get the original MAF and save yourself the headache. No sure if the SLK store would have it in stock.
102 MB is offline
#14 Old 11-09-2014
Quoted: 6544 Post(s)
slkstore does not have mafs
Mercedes Benz Parts, Accessories and Electronics
#15 Old 11-09-2014
Thank you jbanks15
102 MB is offline
#16 Old 01-16-2015
Would this be the part that I need. OEM Bosch 0280217114 / 0000940948 Mass Air Flow Sensor (Meter).
102 MB is offline
#17 Old 01-16-2015
ichris93's Avatar
Quoted: 89 Post(s)
Yes Bosch 0280217114 should be the correct part
jbanks15 and El_Toro_33809 like this.
ichris93 is offline
#18 Old 01-17-2015
Thank you.
102 MB is offline
Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas jbanks15 Off Topic 252 2 Weeks Ago 01:31 PM
DIY - Replace rear window trim cover garylight SLK R171 Class DIY 66 09-24-2018 11:52 AM
Wont start no fuel pressure giossoj SLK R170 General Discussion 21 12-23-2015 07:02 PM
