remains in gear. - Mercedes Benz SLK Forum
 6Likes
#1 Old 07-24-2013
Vehicle: Mercedes Benz SLK 230 2000
remains in gear.
so this has happened twice to me.
what's going is that when I pull out of gear to neutral, its stays in gear and the engine is raving high. has anyone had this problem??
I have to pull aside the road, and shut down the car and then start the car up again to reset the gear..
SLKGuY is offline
#2 Old 07-25-2013
How many miles does the car have? Can you look under the car and see any fluid leak near the transmission connector? A good advice to check the transmission fluid level.
#3 Old 07-25-2013
it only has 70k on the car and the year 2000. I well check out the fluids.
thanks!
SLKGuY is offline
#4 Old 07-25-2013
thanks!
You can either buy a tranny dipstick or go to your local indy. They should be able to check it for you.
Also, there's another member with sticking gears.
https://www.slkworld.com/slk-r170-gen...em-course.html
Perhaps also a good time to check your brake light switch?! =)
slk320chick likes this.
#5 Old 07-25-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Just to add one more note here-Jayson also pointed out to me this morning that the breaklight switch has been updated 2 times since it's original inception. May not be a bad idea to check that as well. I'm going to try to replace mine on lunch today and I'll let you know if it worked.
JaysonM and SLKGuY like this.
slk320chick is offline
#6 Old 07-25-2013
Post
Good point slk320chick! Here's the latest part number: A 001 545 95 09
#7 Old 08-25-2013
So I have narrowed it down. so when I am in 2nd gear and ready to shift to 3rd gear as soon as it goes into neutral it stays in 2nd gear. I have to pull up on the stick to pull out of gear. any ideas...
SLKGuY is offline
#8 Old 08-25-2013
You did not say whether you have an auto or a stick. by the responses it would seem that it is thought that you have an auto, is this correct? if so does the tranny function properly when you are not shifting manually?
CarolinaBluetec is offline
#9 Old 08-26-2013
sorry its a manual. 5 speed.
SLKGuY is offline
#10 Old 08-26-2013
Ok, since manual, it is probably the linkage from shift lever to tranny. Could be loose and need adjustment, jammed with road debris, or worn. I would bet on loose.
#11 Old 08-26-2013
Post
I'd agree with CarolinaBluetec. Check the linkages from underneath the car. I used to own a 1992 VW Golf III with manual. And once I was driving home just a mile away, and heard a loud click and smth fell off... My shifter started wobbling everywhere and I couldn't change any gear! Luckily for me it stuck in 3rd gear. So I managed to get home on the 3rd gear with the help of clutch
After inspecting it turned out that the gear shift lever had a rubber bushing and it got cracked due to age and fell apart. I managed to find a replacement and voila - my shifter was so smooth. I even didn't think it was so smooth before it happened =)) Maybe MB has some similar sort of bushing?
SLKGuY likes this.
#12 Old 08-26-2013
Ok that's better then a bad transmission. Do you know if there's a diy to fix that problem. . or how much to expect to be charged on the repairs. ..
SLKGuY is offline
#13 Old 08-26-2013
Sorry, can't tell you... I have an automatic. Can you put your car on ramps and get underneath it to see what's going on underneath and if you can actually see anything.
If not, then you should look for a good indy in your area.
#14 Old 08-27-2013
so I narrowed it down, took it to a buddy's shop, and he said that's a syncro issues, bad tranny. needs to be rebuilt. :/ it has really low miles. 71k kinda disappointed with Mercedes... :/
SLKGuY is offline
#15 Old 08-27-2013
Minion
Quoted: 148 Post(s)
The question I have now is why is it Mercedes fault that there's a bad tranny in that car unless it was original to you there's no way to know what the previous owner did...no?
#16 Old 08-27-2013
Seems like previous owner did drive it tough... MBs hit millions of miles. I agree with chicky - it was simply abused... =(
#17 Old 08-27-2013
that could be true as well. :/ its going into the shop this week, to get the tranny repaired.
SLKGuY is offline
#18 Old 09-16-2013
UPDATE STATUS: so I finally got my car back on Friday, the reason why it stayed in gear is because the bushings were bad on the shift linkage (I replaced all 6 bushing), I also replace the motor mounts, and now she runs very nice!! happy to get my car back up and running.
SLKGuY is offline
The Following User Says Thank You to SLKGuY For This Useful Post:
#19 Old 09-16-2013
Quoted: 6544 Post(s)
Glad you got it sorted!!
#20 Old 09-16-2013
Minion
Quoted: 148 Post(s)
May I ask [ballpark] what that ran you?
2nd Gear Problem Jigy SLK R171 General Discussion 5 08-07-2012 06:08 PM
It felt like the gear shifting wasn't right... Th3120ck General Discussion 22 09-22-2011 10:29 PM
Gear doesn't change sometimes samskong SLK R171 General Discussion 20 05-05-2011 01:16 AM
Top Gear Season 11, A Reminder because its out TODAY alroumi Off Topic 20 07-07-2008 07:50 AM
