98 slk 230 oxygen sensor location - Mercedes Benz SLK Forum
#1 Old 07-22-2013
Vehicle: 98 slk 230
My oxygen sensor on my 98 slk 230 is bad so i try to figure out the location but couldn't find the sensor! Your help would be greatly appreciated...
Quoc2006 is offline
#2 Old 07-22-2013
Quoted: 6533 Post(s)
I found this using the 'search' feature
Since it a 4 cylinders, there's only one exhaust manifold, not like V6, V8...etc. that have 2 exhaust manifold. Sensor 1, is before the CAT. It very easy to replace. Spray alot of the rust buster stuff and let it soaks.Only buy the OEM part or it will not work right.
https://www.slkworld.com/slk-r170-gen...-sensor-s.html
#3 Old 07-22-2013
Vehicle: 98 slk 230
Thanks jbanks15 still doesn't help on the oxygen location
Quoc2006 is offline
#4 Old 07-22-2013
why not? it says 1 sensor and the location before the cat
#5 Old 07-22-2013
look in the parts diagram link
https://www.slkworld.com/703186-post7.html
#6 Old 07-22-2013
Vehicle: 98 slk 230
Thanks I will try to find it and post picture for other member in the future
Quoc2006 is offline
#7 Old 07-22-2013
see above post for parts diagram link
#8 Old 07-23-2013
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
From the top of the engine look down on the left side between engine and battery about a foot down on the exhaust pipe is the first one. There is a second one after the cat.
Gbarringer100 is offline
#9 Old 07-23-2013
MBDiagMan's Avatar
Vehicle: '01 SLK320 6 speed manual
Other Toys: Modified Cessna 140, 300E 5 speed manual
They are always located on the exhaust system, screwed into a bung, perpendicular to exhaust flow. Since the advent of OBDII ca. 1996, all cars have had at least two sensors. There will always be one before entry to a catalytic converter and one after. If the engine has two banks such as a V8 or V6, it has sensors before and after both cats.
The system measures the difference in exhaust temperature before and after the catalytic converter. If it does not see at least 100 degrees Fahrenheit Delta, it considers the catalytic converter not working properly and sets a code.
MBDiagMan is offline
The Following User Says Thank You to MBDiagMan For This Useful Post:
#10 Old 07-23-2013
Vehicle: 98 slk 230
I can located one of the sensor from top of the engine but still have to jack the car up for easy access, I might have to do it this weekend.. I will post picture up for anyone interest
Quoc2006 is offline
#11 Old 07-23-2013
Wheels52's Avatar
Vehicle: 1998 SLK Black Opal
Other Toys: 2010 SV6 Commodore 210kw, 4.7 Mtr Runnabout
1998 230slk have only one Oxygen sensor and it is located on the engine (exhaust pipe) prior to the Cat Converter and its exhaust portion of the exhaust system. Accessible on the Right hand drives from the engine bay or from underneath the vehicle then as per jbanks15 posts.
[SIGPIC]Old but not broken!!
Wheels52 is offline
The Following User Says Thank You to Wheels52 For This Useful Post:
#12 Old 07-23-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
Aligned with this information, the Lambda sensor measures the remaining level of oxygen in the exhaust flow. (Partial Pressure of Oxygen, aka ppO2)
So the current crop of oxygen (lambda) sensors are self-heated, and accurate at low ppO2 levels, but tend to have quite a slow response time (10s of seconds).
And I suppose the indication of optimal fuelling is when there is almost no oxygen before the catalyst, and the same amount in the sensor after the catalyst. Too much fuel, and there's no oxygen left, and too little fuel and the nitrous oxides are generated, but the ppO2 will be too high.
So a fine tuning input for the fuelling which is already tuned by the MAF, and primarily controlled by the revs/throttle setting.
How subtle is this control due to be?
Tolak is offline
#13 Old 09-14-2013
Vehicle: 98 slk 230
Ok so I got a chance to change all two o2 sensor but the engine light still on the code is p0133. The code reader said O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) anyone got any idea?
Quoc2006 is offline
#14 Old 09-16-2013
MBDiagMan's Avatar
Did you clear the codes after replacing the sensors?
#15 Old 09-16-2013
Vehicle: 98 slk 230
I did clear the code but for some reason the light back on a few days later
Quoc2006 is offline
SLK 230 Inspection Checklist slk230_itch SLK R170 General Discussion 56 06-27-2019 11:24 AM
Updrading From SLK 230 R170 to SLK R171 austaccomm Australia 7 12-30-2012 09:44 PM
SLK 230 & Kompressor Badges - Suggestions on where to find? peabody Where to get R170 SLK Items 15 08-21-2012 10:32 PM
2001 SLK 230 Wheel Bearings Heinzen72 SLK R170 General Discussion 1 06-03-2010 01:18 PM
