Rear Brake Light Keeps "not working" - Mercedes Benz SLK Forum
#1 Old 09-02-2006
Over 100,000 miles!!!
SLKman's Avatar
Other Toys: Just my SLK
Chats: 59
Passanger Brake light is burned out, bulb is ok, it looks as tho the blue plastic peice, that holds the bulb, is burned.
This is the second time in 4 months this has done this.
It is only a $11 peice from the dealer but it is a MAJOR hassle to change out.
The dealer took my vin number and said there is no recall on the item or any items on my car for that matter.
Soooo, guess I will have to keep changing light sockets every few months.
At least I can keep re-using the 99cent bulb!!!
SLKman is offline
#2 Old 09-02-2006
I do not own a R170 but you may want to check the voltage and amp rating of the contacts that go to the blue plastic lamp holder. It may be getting more juice than it needs to and is heating up. Is the 99c bulb of the correct rating?
Also check the fuse that feeds to the rear brake lights, maybe it's faulty and allowing more than what is specified.
#3 Old 09-02-2006
SLKman's Avatar
Chats: 59
Yep, bulb is from the dealer...checking the voltage and all is beyond my skills.
Thanks for the suggestions.
SLKman is offline
#4 Old 09-02-2006
bazzle's Avatar
Vehicle: slk230 1998
Common fault.
There IS a recall pending in USA.
Easy to change out if you put hand thru brush slot .
Clean contacts.
Bend a little for more pressure.
Put a plastic zip tie thru base to increase contact pressure.
Dont hold foot on brake pedal, use hand brake in long stops in traffic.
White LED lamps work (lower current draw) but shine a bit pink.
Bazzle
bazzle is offline
#5 Old 09-02-2006
Thanks Bazzle for chiming in. Great information.
#6 Old 09-03-2006
SLKman's Avatar
Chats: 59
Thanks Bazzle. I put 2 zip ties thru the base to apply pressure. reaching thru the brush slot did not work for me as I could not reach the top light bulb that route. I took the plastic away from the side and it is right there.
The bulb socket is soooo tough to remove that I have to use pliers to turn it.
I hope the recall happens soon...maybe the ties will solve the problem??? we'll see.
Thanks again,
SLKman
SLKman is offline
#7 Old 09-06-2006
Vehicle: SLK32
Tslick is offline
#8 Old 09-07-2006
Vehicle: slk230 black
Originally Posted by Tslick
Check Star bulletin. Its a warranty quick fix.
http://www.alldata.com/tsb/Mercedes-..._P-82-10-406A/
Does this mean they will not fix it if warranty expires? Will have to wait for recall?
slk230r170 is offline
#9 Old 09-07-2006
Vehicle: SLK32
Hard to say. I'd print the TB and show it to your MD dealer. They may do the repair. They acknowledge the problem with the TB.
Tslick is offline
What's "up" with the 171 rear end lift? webslinger SLK R171 General Discussion 24 02-08-2010 10:55 AM
AMG smoked rear light clusters / 3rd brake light. jfb1977 Where to get R171 SLK Items 2 07-24-2008 12:40 PM
Baby Monster "SLK55" meets the Baby Aston "AMV8" alroumi Off Topic 9 09-26-2007 07:54 AM
At Italia Nido Light weight 18" alroumi General Modifications R171 18 10-09-2006 04:38 AM
