Are the stock speakers behind the seats full range, or "just" subs with a crossover? - Mercedes Benz SLK Forum
 15Likes
  • 1 Post By Mike6F
  • 3 Post By Dave2302
  • 1 Post By dorth
  • 1 Post By dorth
  • 2 Post By Dave2302
  • 1 Post By Mn car guy
  • 2 Post By Avel Du
  • 1 Post By Rofa
  • 1 Post By Rofa
  • 1 Post By Rofa
#1 Old 1 Week Ago
Vehicle: 1998 SLK230
Question Are the stock speakers behind the seats full range, or "just" subs with a crossover?
The existing aftermarket head unit is not functioning well and I have determined that it's the actual HU which is malfunctioning. While diagnosing the system in the car I observed that the fader was not working. However, I'm wondering if one or more of the following might be true.
a) The rear speakers are not a separate REAR channel from the amp, but rather just crossovers using the FRONT channel. This would mean that fading to the REAR using the HU wouldn't produce any sound.
b) The amplifier has a blown rear channel.
c) The HU has a blown rear channel or other electrical malady (it definitely has more than a FEW issues, so this wouldn't surprise me.)
Can anyone verify that the behind seat speakers are full range speakers? And if so, are you able to use the fader on your HU? (I don't know what the capabilities of the stock Bose HU are, so maybe this is just an aftermarket question. Please note what your HU is when replying.)
Thanks to any info you can provide!
Dave O
'98 SLK 230
dorth is offline
#2 Old 1 Week Ago
Vehicle: White/beige 2012 350
Quoted: 86 Post(s)
First guess, aftermarket head unit has 2 channel output, factory had 4 or more channels, pretty common.
Mike6F is offline
#3 Old 1 Week Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 312 Post(s)
If they are the Factory Fit BOSE items, they are Woofers only, note the distinction, NOT SUB Woofers.
When adding an Aftermarket System, you are best off removing all the old technology BOSE components completely. Swap the Rears for Component Speakers, same with the Door Speakers and to save a bit of time you can pick up the Speaker Wiring at the original BOSE Amplifier Location, and also add an Amp here if you wish.
My System FYI ...............
4 x 6.5" Mid Range Speakers 4 x Tweeters 1x Active 8" 100w Sub Woofer
ERISIN "Factory Look" (not Single / Double Din), 4 x 50w Channels, Android OREO with USB Data / Charge Socket fitted in Centre Console, TPMS and Reverse Camera add ons, plus full Steering Wheel Control's via Retrofitted Modified R171 Steering Wheel and Paddle Shifts
Some Pixels ........
HTH, Cheers Dave
jbanks15, M4rCu5 and Avel Du like this.
Dave2302 is online now
#4 Old 5 Days Ago
It's a Blaupunkt New Zealand - https://www.blaupunkt.com/us/nc/prod.../single/18752/. It says "Power output: 45W X4" and it does have a Fader in the unit. I also wired up 4 speakers from the unit to the am so I was thinking I was covered there, but perhaps not. Thanks for chiming in here - appreciate it!
Dave O
dorth is offline
#5 Old 5 Days Ago
Good distinction. I was wondering if they were sub-woofers (20-200Hz) which is why I wasn't really hearing any sound when I faded to the rear speakers. If they are indeed woofers (40-2500Hz), then I should have heard music when playing from the rear channel/back speakers. I guess I will find out what the situation is once I get the replacement HU installed.
I don't disagree. However, I'm just trying to get the bare minimum invested here to get the car suitable for general driving by my son. The car has some other issues which means I want to keep the investment as low as possible so I can reserve some funds for the required items. But yes, you have a nice looking system set up there. I assume the R171 uses a double DIN? Or did you makes some modifications to fit in the double?
Thanks!
Dave O
dorth is offline
#6 Old 5 Days Ago
Quoted: 312 Post(s)
Hi Dave,
Serious Modifications to an EBay Centre Console and slight Mods to shave the plastic edges of the Head Unit to get it to fit between edges of the Console. Took hours and hours of plastic trimming to get nice gaps around the edges.
Problem with trying to leave the BOSE Amp in is that it is not really suitable for anything other than Stock R170 H/U and Speakers, which are old tech.
Even if you just want a simple single DIN H/U Change, you will need to ditch the Stock BOSE Amp, then hard wire the Door Speakers to the new H/U, and also remove the Rear Woofers and put in a pair of Co-Axials or 3 ways or Components .............. 6.5" is really the biggest, although if you wanted to go 3 way then you could likely get a pair of 6x9's in there with a little creativity.
Worth you noting .............
My Car came with a retrofitted Pioneer Single DIN, but had no BOSE and no Rear Speakers from the factory!! The Sound Quality and distortion free outright Volume improved significantly as soon as I installed the Pair of Component Speakers behind the Seats, that was my first move ....................
There is not a lot of room and you cannot cut the Rear Bulkhead for structural reasons and Fuel Tank is banged up hard against it from behind
That is why I have that Surface Mount Sub in between the 2 Seats .............. Does sound amazing tho
I suggest you have a read of my Cars Thread here on SLK Forum, install is a bit disjointed as it was done over about 3 months or more, stages at a time in spare time, but well worth trawling, there is a lot of info in there.
That H/U I used was designed for a W203 C Class, pre facelift model, it was the only one that was physically the almost correct size to fit R170 Console, and I also liked the Knobs and Buttons styling etc as it was a bit more in keeping with an "Old Skool Roadster" like the R170
Thread linky is here, start at Page 2 Post # 30 then keep going, System Install is finished at Page 4 Post # 62 .............
https://www.slkworld.com/performance...project-2.html
HTH, Cheers Dave
Avel Du and savcom like this.
#7 Old 5 Days Ago
Quoted: 133 Post(s)
Dave O
'98 SLK 230
So here's what you have. Your aftermarket h/u is driving the bose system with the pre-amp out only, not the 4x45 side. The bose amp divides the incoming 2 channels to the door speakers and the rear subs. It has an integrated co. As you are only using the pre-out, you have no fader control.
It's really a surprisingly bad system and as Dave said, you're better off ditching the whole thing and starting from scratch. If you don't want to invest the time and money, you could disconnect the subs and buy a powered sub to fit under the passenger seat (assuming your h/u has a seperate sub line out). That would sound many times better than the one note wonder subs you have now.
Dave2302 likes this.
Mn car guy is offline
#8 Old 5 Days Ago
Quoted: 2327 Post(s)
I've seen Dave's system close up.
If we still had the 230, or a 320, I'd look at same.
It's modern without detracting from the 170's looks.
Very nice job.
savcom and Dave2302 like this.
Avel Du is online now
#9 Old 4 Days Ago
Vehicle: 1999 SLK230
Quoted: 35 Post(s)
I just went though the same dilemma with changing out audio bits. I decided to change the head unit and add an 8” subwoofer. Sounds way better, I ended up with Alpine head unit as the Kenwood one I order was defective upon install, but hands down the Kenwood sounded better. I marched the head unit with Alpine subwoofer, made a big difference to the low end but I would not really call it a subwoofer, I think two of them would be perfect.
subwiz is online now
#10 Old 4 Days Ago
Quoted: 312 Post(s)
I listen to a lot of Reggae, my 8" Active Sub together with the other 8 speakers really Kicks and is loud enough to still be clearly audible at 100mph with Roof down
I know for a fact the actual placement of the Speakers, especially Sub Woofers and Tweets, secure mountings and decent sized wiring makes a big difference too ....................
My home Audio System has Column Speakers with double 10" Drivers etc etc, thick gold cables and they stand on Concrete Paving Slabs rather than straight on the Carpet, makes one helluva difference
#11 Old 2 Days Ago
Nigg's Avatar
Vehicle: Slk 230 2003
Quoted: 9 Post(s)
Hi similar to you if I fade to the rear speakers no sound , and I thought the Bose rears were not working , but I’ve got alpine head unit and after playing with the subwoofer set up I now have a rather delicious sounding system it’s a really clean sound not with night cub levels of bass but the Bose rears are definitely adding bass definition to the sound imho play with settings on the head unit before ripping the rears out
Nigg is offline
#12 Old 1 Day Ago
The is a super good assumption. However, I have confirmed that it's actually using the speaker out wires which then go to the Bose AMP. I would expect a boat-load of hiss in this double amplified system, but it's actually not horrible. However, as I think I mentioned in one of my previous messages above, the existing H/U is emitting some horrible noise which is unrelated to the amplifier or car power system.
I agree that the Bose AMP is just using the front 2 channels and then splitting it up amongst the speakers. When I fade to the rear channel, it doesn't go anywhere and thus no sound.
I do *greatly* appreciate the input here! Instead of boring you with the "I've got this on order, and then my next plan is...", I'll post back with what I ended up installing and how it's working. I *think* I'm close! (Famous last words!)
Dave O
dorth is offline
#13 Old 1 Day Ago
Vehicle: 1997 230 Kompressor
Other Toys: Saab 9-5 V6 , Various Jags and Europa aircraft in the past
Quoted: 31 Post(s)
@dorth, have you seen the fairly recent post on the General Modifications forum re Bose rear speaker sizes? Might help with your choice.
Rofa is online now
#14 Old 1 Day Ago
Thanks for the tip! Here is the thread: https://www.slkworld.com/general-mod...imensions.html
Dave O
dorth is offline
#15 Old 1 Day Ago
Quoted: 31 Post(s)
@dorth, if you go that route, and are keeping your Bose amp, bear in mind that the Kicker speaker referred to is a dual coil, 2 ohm each coil. That's the 2 at the end of the part no. They do a 1 ohm as well. I am no audiophile at all, but it seems to me you could either replace your 2 rear speakers with a single 2 ohm speaker wired one coil to the left and the other coil to the right. The amp would see 2ohm then as expected on left and right channels. Or you could fit two of the 1 ohm speakers, each coil wired in series, again to give the 2 ohm expected. Depends on how much you want to squander:-)
Hope that makes some kind of sense.
Rofa is online now
#16 Old 20 Hours Ago
Quoted: 133 Post(s)
Dave O
It was wired incorrectly then. It should be driven with the pre-amp only. On a related note, you'll need to have 4v on the output of the head unit (many units are less than that).
#17 Old 13 Hours Ago
Quoted: 31 Post(s)
Post #3 2003 radio install https://www.slkworld.com/general-modifications-r170/326281-2003-radio-install.html
is worth reading. Not sure I understand it especially the circuit showing 4 wires going to each of the rear speakers? Are they dual coil?
Removal (for a Crossfire) covered by
https://youtu.be/a7QjRwutCb0
Rofa is online now
#18 Old 3 Hours Ago
Quoted: 31 Post(s)
The link in one of the previous posts will inform you that Crutchfield believe the rear speakers to be 6.75 inch. A quick look at eBay will show a number of these Bose speakers labelled woofer 6.5 inch. So I'm not sure a 6.75 will fit in. I picked up a 6.75 heavily discounted so I'll find out in due course.
The alternative is to try this, although he also used a 6.5 inch:
https://www.mbslk.de/modules.php?nam...rticle&sid=810
Rofa is online now
#19 Old 1 Hour Ago
Quoted: 312 Post(s)
Hi @Rofa ,
/\ /\ /\ That link is exactly how I did my Rear Mid Range and Tweets, then I removed the Centre Pocket between Seats and added the Active Sub Woofer.
I also upgraded the 2 tired MB Door Speakers with the same set as used for my Rear, I brutally used a disc cutter to cut the MB Door Speakers guts out of their Enclosures and then fitted the Component Mid Ranges in, left the original MB Tweets as they were fine.
I used a bead of PU Glue to bond them between the 2 halves of the original enclosure, clamps the glue down nice and tight as you screw the 2 halves back together
I even soldered the MB Speaker Wires / Plug onto the new Speakers for a decent plug and play job
Here's how I did the Door Speakers in piccies ...................
HTH, Cheers Dave
Dave2302
