Advice on a few MOT fail issues - Page 3 - Mercedes Benz SLK Forum
 140Likes
#41 Old 5 Days Ago
M4rCu5's Avatar
Quoted: 278 Post(s)
Originally Posted by Jody View Post
It seems I have been unlucky on a few fronts but... THE SEAT NOW WORKS!
Was it the relay?
Dave2302 likes this.
M4rCu5 is offline
#42 Old 5 Days Ago
Vehicle: R170 2.3 SLK. 2000 first reg and owned for about a year. 90k miles
Quoted: 8 Post(s)
Originally Posted by M4rCu5 View Post
Was it the relay?
I cleaned the switches on the seat by getting some WD40 down there, I reseated the relay after checking the solder, it seemed to be fine and then I replaced the fuse again to make sure and it just started working.
The biggest one left is the headlights and the ESP. I am replacing the brake light sensor tomorrow and going to try refit the original H7 connectors (Though I am a little unsure about this one)
M4rCu5, Avel Du and Dave2302 like this.
Jody is offline
#43 Old 5 Days Ago
Quoted: 8 Post(s)
Sorry I mean the Brake Light Switch (I can't edit my posts)
Jody is offline
#44 Old 5 Days Ago
M4rCu5's Avatar
Quoted: 278 Post(s)
I'm not at all sure about that ESP light (or lack of light), could be the brake light switch, could be the ESP switch .. those two are cheap enough to play 'parts darts' with but it ideally needs a scan.
I had a faulty brake light switch just a few days ago but that put my BAS/ESP light on on the dash.
Scans ..
iCarsoft MBII actually called that right for once
Double-checked with SDS which also told me that it was the brake light switch and for added clarity it had noted 5 Implausible Brake Bellows movements or words to that effect .. kinda made sense
11.16 for a new Febi switch and a middle-aged man getting into positions that a middle-aged man really has no business getting himself into and an hr later it was fixed
Trev5, Avel Du, savcom and 2 others like this.
M4rCu5 is offline
#45 Old 5 Days Ago
Quoted: 8 Post(s)
I had a faulty brake light switch just a few days ago but that put my BAS/ESP light on the dash.
Scans ..
I only have a obd2 scanner so I am not sure it will work but I will replace the switch anyway. Yes, I had a little close look earlier and a younger me wouldn't have any problem with that but older me complained a little getting in there and more so getting back out...
The guy at the garage told me that it was just the switch that was the problem, not the system, his words were "If the switch is there it has to work, if the switch wasn't there, it wouldn't have failed". I wonder if I just rip the switch out if it doesn't change it and see what he says...
M4rCu5 likes this.
Jody is offline
#46 Old 5 Days Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 311 Post(s)
/\ /\ /\ @Jody
I think that will light the dash up with warning lights, and you may not be able to reset them with just OBD
Also that switch is all part of the Hazard and Locking Switch as one assembly ...............
Nice to see you're almost there now
Do you want another switch posted to you ?
I have quite a few spare and can 1st class it tomorrow morning if so, let me know, pm me your address or phone me tomorrow morning from 8am 01599 511482 .................
HTH, Cheers Dave
Trev5, M4rCu5, Avel Du and 1 others like this.
Dave2302 is offline
#47 Old 5 Days Ago
Quoted: 311 Post(s)
@Jody ,
Here you go, one sat on my desk waiting to here from you
HTH,
M4rCu5, Avel Du, sgbgsb32 and 1 others like this.
Dave2302 is offline
#48 Old 5 Days Ago
Quoted: 2326 Post(s)
You now have 16 post. After 15 you should be seeing an edit button below each of your posts.
You can edit for 10 days after the post was made.
(PC & Laptop. Not sure where it is on phone/pad-probably need to view full version).
In red view on laptop it looks like this
#49 Old 4 Days Ago
Vehicle: White/beige 2012 350
Quoted: 86 Post(s)
There is a wide gap between working and safe and fixed correctly, but bridging that gap requires the person knowing how things work in a bit more depth.
Here in Calif we don't have MOT, state could care less about a car stopping or seats working, as long as the smog system is effectively restraining hp and all the bits have the correct numbers on them.
For the headlights I would think "most" of the original wiring should still be accessible, so that a replacement original socket with pig tails (prewired to easily splice in) would fix that.
Mike6F is offline
#50 Old 4 Days Ago
Quoted: 311 Post(s)
Hi @Mike6F ,
Emissions .............
Here in the UK we only have one "State" ...............
The "Nanny State" which is slowly stripping the entire populace of it's Human Rights, and still the majority of our Population believe we live in a democracy ............. PAH !!
Our MOT Tests get stricter almost by the hour these days. It is no wonder that a lot of testers can't keep up with the ever changing rules !!
I have many friends and customers who own beautiful immaculate Mercedes Cars, one is an absolutely mint 2005 S Class CDI Diesel, he is scrapping it because it needs a few hundred Engine Repair and next year he will not be allowed to use it to go to work in London due to ULEZ ..............
That Car is cleaner than most folks underwear when looking at Emissions
This now is applying to more and more Cities throughout UK as they all start to follow suit
Within 10 years now, and without intervention, I foresee that the Internal Combustion Engine will become a thing of the past, WAKE UP UK POPULACE !!
Cheers Dave
M4rCu5 and Avel Du like this.
Dave2302 is offline
#51 Old 4 Days Ago
M4rCu5's Avatar
Quoted: 278 Post(s)
A good friend of mine is an MOT tester and he refuses point blank to test cars that belong to his friends due them quickly becoming ex-friends. Understandable to a degree as he cannot show favouritism in any shape or form whatsoever, they have to be strict and It is really hard for them to keep up with the ever-changing rules and regs. They're not all bad guys, they've just got to do what they've got to do.
M4rCu5 is offline
#52 Old 4 Days Ago
Quoted: 8 Post(s)
So I just replaced the Brake Light Switch and it seems to have not made any difference. Can I just check that the big yellow triangle in the middle of the dash is the ESP? This lights up when the key is inserted and switch on, then when the car is started it goes off. I also have been reading that the cruise control is effected by this, my cruise control has never worked.
What is the action of the ESP switch when it's working? What happens when you press it to the dash? In the manual, it states the light should turn off and on. I bet it's the bloody switch.
Jody is offline
#53 Old 4 Days Ago
Some reading whilst you wait for the clever folk.
https://www.slkworld.com/gtsearch.php?q=R170%20ESP
If memory serves, this function uses the speed and possibly abs sensor.
But sounds like your call on the switch is likely the cause.
Did you see the Post from Dave2302? Offering a switch.
#54 Old 4 Days Ago
Quoted: 8 Post(s)
Yes, the guy is a legend and has sent one in the post, hopefully it arrives in time.
M4rCu5, Avel Du, Dave2302 and 1 others like this.
Jody is offline
The Following User Says Thank You to Jody For This Useful Post:
#55 Old 4 Days Ago
Quoted: 311 Post(s)
It went in the Post Office at 11:52, First Class, down to Royal Mail "Donkey Express" now
Nice talking to you, hope she gets through the test now,
Cheers Dave
Dave2302 is offline
#56 Old 4 Days Ago
Quoted: 8 Post(s)
Cheers Dave
Thanks, Dave, let me know what I owe you.
I had a second go with the handbrake today. It seems that the right side adjuster just doesn't want to turn either way unless I am doing something wrong. Should it be easy to adjust? It felt like it just didn't want to move.
Jody is offline
#57 Old 4 Days Ago
Quoted: 311 Post(s)
Hi @Jody
You don't owe me anything
I'm sorry to hear that you can't get the Adjusters to move, I would expect that those Adjusters and the Shoe Expanders are well seized up, possibly at least the Right Cable as well, which was why I suggested stripping and inspecting in the first place
HTH, Cheers Dave
Avel Du and Jody like this.
Dave2302 is offline
#58 Old 4 Days Ago
Quoted: 8 Post(s)
Hi @Jody
HTH, Cheers Dave
I agree. I think i might be fighting a losing battle in the short term. I think i need to think longer-term at this point if it fails again.
I will go for a pint and have a ponder.
I am not done yet, I just think Dave was right all along and this is a bigger job that needs doing well.
Jody is offline
#59 Old 2 Days Ago
Quoted: 311 Post(s)
Hi @Jody ,
What was the outcome buddy ?
Cheers Dave
Dave2302 is offline
#60 Old 2 Days Ago
savcom's Avatar
Quoted: 616 Post(s)
Do we not have any local members/garages that can assist?
Even if just a place to park and do the work.
I don't know the area well.
I know the two Martins aren't local, but may have a better idea of who/where to ask.
@MartinatMersea
@savcom
@Trev5 Do you know the area at all?
Sorry chaps - a bit late to the party.
If you need another opinion/price re the outstanding bits, I'd recommend talking to German Car Specialists, in Horsham. While they won't let you work there (obviously ) I've found them very good at sorting problems out (and there's usually a range of good quality cars being serviced there which indicates quality work, too).
I'd have offered my drive for you to work on the car, but as I no longer live in the area that's kind of hard now. Sorry.
Wish I could help more, but I can say that you're in very good hands with those already contributing to the thread. Good luck!
Also
Previous :
savcom is offline
