R170 Cigarette lighter install - Mercedes Benz SLK Forum
 14Likes
  • 1 Post By jbanks15
  • 4 Post By efair
  • 1 Post By Alex 3
  • 4 Post By Rofa
  • 2 Post By efair
  • 1 Post By Australian
#1 Old 20 Hours Ago
jovani2002's Avatar
Vehicle: 2003 Slk230 bright red with an automatic transmission. Has 57,300 miles on it
Tried looking to see if this was already a forum, but I’m not sure exactly what this part is called. Anyways I ordered this new cigarette lighter part but have no clue how to install it and as a 17 year old I really do not want to mess up my car. All help would be appreciated. (The part on the left is the new one, right is old.) Would need help removing the old one and installing this new one
File Type: jpg C2FDA345-81FC-476D-903B-33F403430E40_1565820067496.jpg (29.1 KB, 9 views)
jovani2002 is offline
#2 Old 20 Hours Ago
Quoted: 6424 Post(s)
from a search of our site threads
https://www.google.com/search?source...4dUDCAc&uact=5
Dave2302 likes this.
#3 Old 20 Hours Ago
jovani2002's Avatar
Oh, thanks appreciate it.
So do u think I have to remove the whole console? Bc I just need to replace the old part with the new one, and I can access the old part no problem.
#4 Old 20 Hours Ago
experts will chime in when they logon
@efair
@stu32
@savcom
@Turdo2
@VII7
@M4rCu5
@Dave2302
@Australian
M4rCu5 likes this.
#5 Old 19 Hours Ago
Quoted: 863 Post(s)
Its been a while, but I believe you will need to remove the center console - just the part under your elbow. There are nuts in the back and screws in the front (inside the storage box, under the liner, and under the shifter surround, respectively). Be extra careful - patience and caution will prevent the fragile plastic from breaking. If things break, save the pieces and epoxy them back together before reassembly.
jbanks15, M4rCu5, Idiot101 and 1 others like this.
efair is online now
#6 Old 18 Hours Ago
jovani2002's Avatar
Any tutorial or guide online to help me remove it?
#7 Old 18 Hours Ago
look here
#8 Old 16 Hours Ago
jovani2002's Avatar
Ok. Thank you very much. I’ll have to try that soon. One more quick question though, would it be possible to just remove the wires from the back of the old pet and connect them to the new part. Like in this pic I have the whole part out of the console
File Type: jpg F38189D0-6999-4B55-A753-FE421CC9F180_1565834240763.jpg (18.3 KB, 7 views)
#9 Old 13 Hours Ago
Other Toys: Traded them all!!
Quoted: 103 Post(s)
I think you can pop it out if you are careful. The wires just go on the new one. The roof switch is trickier but even if you have to take the rear console out it is no big deal.
I had never had one of these cars when I go my first one and the seller smashed the roof switch between me buying it and picking it up. He bought the switch and it was the first repair I did. Took less than 30 min as I recall. Once out it snapped in so the lighter I expect will do the same.
Alex 3 is offline
#10 Old 13 Hours Ago
Vehicle: 1997 230 Kompressor
Other Toys: Saab 9-5 V6 , Various Jags and Europa aircraft in the past
Quoted: 17 Post(s)
Have a look here for console removal
https://www.pelicanparts.com/techart...le_Removal.htm
The hardest job I found was removing the hand brake grip. In the end I used an old feeler gauge to unstick the grip from the steel underneath which had corroded slightly. A long strong pull is the way to go and it will free eventually.
Rofa is online now
#11 Old 7 Hours Ago
Quoted: 863 Post(s)
Why not just disconnect the old.and.plug in the new? IIRC that connector comes off sideways, not in the direction you'd think.
Idiot101 and Dave2302 like this.
efair is online now
#12 Old 6 Hours Ago
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 73 Post(s)
Here: https://www.slkworld.com/slk-r170-ge...isconnect.html
Australian is offline
#13 Old 4 Hours Ago
jovani2002's Avatar
Ok looked at the forum, just wanna make sure. So I would be pulling mine at the direction i have the arrow going? And would I have to click anything or do I just pull?
File Type: jpg 83FE5E03-5F0C-4875-A851-BE4514F407A1_1565878081396.jpg (18.4 KB, 3 views)
#14 Old 55 Minutes Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 147 Post(s)
Just pull
Dave2302 is online now
Dave2302
