R170 SLK 230 fan switch has ceased working !! - Mercedes Benz SLK Forum
 13Likes
  • 2 Post By ARoosterinaRoadster
  • 2 Post By Bartiny
  • 3 Post By M4rCu5
  • 2 Post By Avel Du
  • 2 Post By Alex 3
  • 1 Post By ARoosterinaRoadster
  • 1 Post By M4rCu5
#1 Old 1 Day Ago
Vehicle: 2004 (53) plate SLK 230 Face lift Auto in Pewter Silver Metallic (paint code C723) aka Cubanite.
Other Toys: 50cm Bianchi Via Nirone7 Alu Carbon Flat-bar Hybrid,51cm bespoke hand built frame by Steve Goff
Quoted: 23 Post(s)
Hi all. Well as the heading implies the fan has stopped working and presumably everything on the car related to Heating,Air Conditioning,cooling in the cabin has also ceased.
Any ideas please and is it something that is an easy DIY fix ?
M4rCu5 and Avel Du like this.
ARoosterinaRoadster is offline
#2 Old 1 Day Ago
Bartiny's Avatar
Vehicle: 1996 SLK 230 R170
Quoted: 11 Post(s)
Hi, If you have the drivers handbook I would start with the fuses, if you do not know the location of the correct fuse I will dig my handbook out and look for you unless someone else beets me to it
Edit; Just noticed you have a 2004 so I am not sure if the location of the fuse on mine will be the same as on yours?
My pre production R170 test/demonstrator built August 19th 1996 saved from almost certain to be broken up for spares. Potentially the oldest surviving RHD by VIN?
Bartiny is online now
#3 Old 1 Day Ago
M4rCu5's Avatar
Quoted: 199 Post(s)
Given the amount of rain that we're having, I wouldn't be at all surprised if your drains are blocked and water has gone into the fan/regulator
Try THIS ONE - HVAC wiring diagram is in post #24
HTH
Avel Du, Bartiny and Dave2302 like this.
M4rCu5 is online now
#4 Old 1 Day Ago
Moderator/RoTMorganiser
Quoted: 2188 Post(s)
Diys https://www.slkworld.com/slk-r170-class-diy/
TSBs https://www.slkworld.com/slk-r170-se...campaigns-tsb/
Many tsb have also got the solution attached.
#5 Old 1 Day Ago
Vehicle: 2009 CLK 350 cab
Quoted: 129 Post(s)
Mine would do that on occasion and I could get it to work again by cranking the speed control back and forth a few times. Obviously check the fuses as well.
Mn car guy is offline
#6 Old 16 Hours Ago
Other Toys: Traded them all!!
Quoted: 103 Post(s)
Your description is kind of universal. I found this test procedure years ago.
The three prong connection that attaches to the regulator(resistor) should always have power from the red lead, the brown lead is ground, and the white/pink strip lead is controlled by the fan switch. With the car off, and the fan switch in the "off" position, there should be no power to the white/pink lead. With the car on, the voltage to the white/pink lead should increase as the fan switch is rotated from "off" to "high".
If there is constant power to the white/pink lead, the control panel is defective. If there is no power to the white/red lead, but the fan still runs, the regulator(resistor) is defective. This is a common problem - the regulator(resistor) fails "closed" and provides power to the fan without power from the controller (fan switch).
Resistor PN A 202 820 73 10
Alex 3 is offline
#7 Old 9 Hours Ago
Quoted: 23 Post(s)
Hi all and thank you for your various info and links.
This morning the fan was fully functioning as was normal but I will get it investigated when my MB Independent returns from his hols.
Being rather short in stature I find it difficult to reach over into the central part of the windscreen to investigate the possibility of blocked drain hole scenario
M4rCu5 likes this.
#8 Old 4 Hours Ago
M4rCu5's Avatar
Quoted: 199 Post(s)
It's true that you have to reach to undo a couple of the central screws and to get a grip of the scuttle etc. but it's a job that has to be done anyway, no 'ifs' or 'buts', we've seen it too many times
Dave2302 likes this.
