ATF leak after servicing - Mercedes Benz SLK Forum
 16Likes
  • 1 Post By Rofa
  • 2 Post By Bartiny
  • 1 Post By Rofa
  • 1 Post By Avel Du
  • 1 Post By Dave2302
  • 2 Post By Rofa
  • 1 Post By i860
  • 3 Post By Dave2302
  • 2 Post By Rofa
  • 2 Post By Dave2302
#1 Old 2 Weeks Ago
Vehicle: 1997 230 Kompressor
Other Toys: Saab 9-5 V6 , Various Jags and Europa aircraft in the past
Quoted: 18 Post(s)
My'97 had never had a gearbox service as far as I can tell. So I had a workshop I have used for 5 years on other cars change the oil, filter and pilot bushing. Drove the 10 minutes home and found a leak under the car. Now I'm pretty sure they are not familiar with this gearbox since they didn't locate the drain in the torque convertor not did they seem to know what the pilot bushing was which is all a bit bothersome. What happens on these boxes if they are overfilled? I ask because I've been charged for 15 ltr fluid which is maybe a little over the top using a double drain,/flush.
Dave2302 likes this.
Rofa is offline
#2 Old 2 Weeks Ago
Bartiny's Avatar
Vehicle: 1996 SLK 230 R170
Quoted: 12 Post(s)
As a guide when I did my gearbox oil and filter change I drained the torque converter and also replaced the conductor plate (losing a little more oil) to refill it was 7 ltr.
Using the flush through method, and as the torque converter had not been drained (as a guess as I have no experience of doing this) I would imagine that 15 ltr would be roughly right, especially as the ones doing it are not paying for the oil.
I would imagine that if the gearbox was so overfull you would experience gear change problems?
As for the leak, it is hard to say, but maybe the sump gasket is leaking? I would take it back for them to check.
HTH.
My pre production R170 test/demonstrator built August 19th 1996 saved from almost certain to be broken up for spares. Potentially the oldest surviving RHD by VIN?
Bartiny is offline
#3 Old 2 Weeks Ago
Quoted: 18 Post(s)
Very helpful indeed. Thank you.
Rofa is offline
#4 Old 2 Weeks Ago
Quoted: 2207 Post(s)
If you look at the threads for those having gear change issues,
over and under filling are amongst the first suggestions.
#5 Old 2 Weeks Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 161 Post(s)
Agreed, the Oil Leak is likely Pan Gasket or ........... Pilot Bushing Connector ............
It is very easy to make a complete FUBAR when fitting a Pilot Bushing Connector if one is un familiar with the 722.6xx Transmission.
Having read the OP I think I would get a good reputable A/T Specialist to have a look see first, after explaining to them exactly what has been done, and also that the Transmission was functioning perfectly before (if it was), and also that it has been barely driven since this attempt at repair ................. (Don't drive any more than necessary with the leak)
HTH, Cheers Dave
Bartiny likes this.
Dave2302 is offline
#6 Old 2 Weeks Ago
Quoted: 18 Post(s)
Thanks Dave. It was the bushing and they should already have fitted a new one. The boss is doing it this time. Just as a matter of interest what is the issue fitting it? Seems a straightforward job really in principle.
LIL DON SLK and Dave2302 like this.
Rofa is offline
#7 Old 2 Weeks Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 897 Post(s)
Not overly tight the screw in the pilot bushing as the plastic might crack and make sure is latch in properly.
i860 is offline
#8 Old 2 Weeks Ago
Quoted: 161 Post(s)
/\ /\ /\ Agreed
Also .........................
The new 'O' Rings on the Pilot Bushing are often tight in the Casing bore, I always wipe a good smear of Wynns or STP on them and clean the Casing Taper thoroughly, I have seen issues where others have yanked on the tiny 7mm (head size) bolt to draw the tight assembly in, which usually results in the captive nut in the Conductor plate shearing / cracked plastic or scuffed / torn 'O' rings
The other thing I've seen over the years is that the front right pan bolt has been snapped in the Trans Casing, (happens due to corrosion), and then it is just left off by a "couldn't care less" merchant, so the Trans drips Oil from that corner of the Pan Gasket
HTH, Cheers Dave
LIL DON SLK, i860 and Bartiny like this.
Dave2302 is offline
#9 Old 2 Weeks Ago
Quoted: 18 Post(s)
Thanks all for the help. They did indeed get themselves into a real mess with the bushing. I'll get the full story and hopefully the car tomorrow.
Bartiny and Dave2302 like this.
Rofa is offline
#10 Old 2 Weeks Ago
Quoted: 161 Post(s)
At least this proves they are a good garage and have "put their hands up" and rectified your problem in a timely manner
We all make mistakes, often on something un familiar .....................
That is not the issue, it is what we do to rectify said mistake that really counts
Hope it is all good when you get her back
Cheers Dave
Australian and Bartiny like this.
Dave2302 is offline
#11 Old 2 Weeks Ago
Quoted: 18 Post(s)
Thanks Dave and well said indeed!
Rofa is offline
