Fan issue (Kind of) - Mercedes Benz SLK Forum
 6Likes
  • 3 Post By tdfs1234
  • 1 Post By tdfs1234
  • 1 Post By jbanks15
  • 1 Post By VII7
#1 Old 2 Weeks Ago
tdfs1234's Avatar
Vehicle: 2001 SLK 230
Fan issue (Kind of)
Just got this car, 2001 SLK230. learning about it as I go. The cooling fan wont turn on so I ran a power to it to test it and it turns on, I plugged it back in and was going over the fuses with the power on (not running) I pull fuse 11 and the fan kicked on. What are the possible issues? Also tested the fusible link with a volt meter and it seems fine.
LIL DON SLK, Idiot101 and Avel Du like this.
tdfs1234 is offline
#2 Old 2 Weeks Ago
Quoted: 6435 Post(s)
remember to search until someone jumps in
from a search
https://www.google.com/search?source...4dUDCAc&uact=5
#3 Old 1 Week Ago
tdfs1234's Avatar
Update: it seems the fan is kicking on but it is only kicking on at low speeds where when I pull the fuse it kicks on high and cools the engine almost intently. This fan issue looks like it is the man over heating problem the car has. So if anyone can help me pin point the issue it would be greatly appreciated.
tdfs1234 is offline
#4 Old 1 Week Ago
@efair
@stu32
@savcom
@Turdo2
@VII7
@M4rCu5
@Dave2302
@Australian
#5 Old 1 Week Ago
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 191 Post(s)
Fan is PWM, if there is no signal it will run 100%. You will need to test with diagnostics as problem might be temperature sensor.
Dave2302 likes this.
VII7 is offline
#6 Old 1 Week Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
101% agree with @VII7
The fan is supposed to run at gradually increasing lower speeds, very rarely runs at full speed, if it is not cooling the Engine as it should within the lower speed ranges then there is an underlying problem.
Temp Sensor is a good call, personally I always buy the housing with Stat and Sensor in it.
Proper diagnosis would be to put car on the appropriately capable diagnostic machine and look at data to correlate Temp against when (if) Fan Kicks in, and also use Actuations to test that the fan runs at all it's speeds properly, to eliminate possible ME ECU, Wiring, Fan or Fan Controller faults
HTH, Cheers Dave
Dave2302 is online now
