Will SRS light come on with passenger seat removed? - Mercedes Benz SLK Forum
  • 2 Post By i860
#1 Old 2 Weeks Ago
Vehicle: 1997 230 Kompressor
Other Toys: Saab 9-5 V6 , Various Jags and Europa aircraft in the past
Quoted: 18 Post(s)
The seat is coming out for repair for a couple of days and I understand that the warning light can only be reset by dealer standard diagnostics. So I'd like to avoid that if at all possible but still use the car. Will removing the seat trigger the warning light? This is a '97 which has a separate passenger SRS on/off switch.
Rofa is offline
#2 Old 2 Weeks Ago
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
@Australian
@Dave2302
@i860
I would suggest that anyone with the right kit can reset, not just a dealer.
As for SRS warning if seat is removed, I'd expect that you need to either isolate or complete the circuit.
#3 Old 2 Weeks Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
I will pull the battery out an do the work, then connect the battery again.
i860 is online now
#4 Old 2 Weeks Ago
Quoted: 18 Post(s)
Well according to the @1=Decotherm thread currently running, the Autel will clear SRS codes. My comments were based on an old thread after search. Disconnecting the battery is indeed the obvious solution, but I would like to use the car. Hey ho, try it and see what happens I guess.
Rofa is offline
