Vehicle Inspection post analysis - Mercedes Benz SLK Forum
 22Likes
  • 1 Post By finelytuned
  • 4 Post By Windinmyhair
  • 2 Post By Avel Du
  • 2 Post By finelytuned
  • 2 Post By Dave2302
  • 4 Post By Trev5
  • 1 Post By i860
  • 1 Post By M4rCu5
  • 3 Post By i860
#1 Old 2 Weeks Ago
finelytuned's Avatar
Vehicle: Mercedes SLK 230 Kompressor, 2001.
Quoted: 17 Post(s)
Post Vehicle Inspection post analysis
In the UK we have a legally required annual vehicle inspection, thankfully my R170 passed after a last minute back tyre change. Some advisories appeared in the report, looking on thoughts on what aspects are worth fixing in the next 12 months.
- Suspension arm pin or bush worn but not resulting in excessive movement Offside Front (rear bush)
- Brake pipe corroded, covered in grease or other material Nearside Rear
- Brake pipe corroded, covered in grease or other material Offside Rear
- Prop shaft flexible coupling slightly detoriated Central
- Wheel bearing has slight play Nearside Front
- Wheel bearing has slight play Offside Front
- Tyre slightly damaged/cracking or perished Nearside
finelytuned is offline
#2 Old 2 Weeks Ago
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 328 Post(s)
I'd get the brake pipes cleaned up and properly checked and replaced first.
Tyre next and then monitor the rest and rectify when funds allow.
Windinmyhair is online now
#3 Old 2 Weeks Ago
Quoted: 2203 Post(s)
Advisories do not necessarily mean get it done asap.
Tyre might get you into trouble with the bobbies.
Brakes are important and those lines need inspecting thoroughly (did you chat to tester?).
Generally testers are happy to explain how bad and what needs doing asap and what can be left.
He/She has witnessed and recorded the issues. Best person to ask.
finelytuned and Dave2302 like this.
Avel Du is online now
#4 Old 2 Weeks Ago
Quoted: 17 Post(s)
The mechanic was intending to discuss but we didn't get to it. I've scheduled a phone call next week to see the extent of the advisories. Things like wheels and brakes concern me too, keen to get such things sorted sooner.
#5 Old 2 Weeks Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 161 Post(s)
Just my 10p worth ................
If ever I get any advisories they get done straight away. It is rare after I've MOT prepped a car, but we are all human and it is after all "all in the opinion of the tester" .
IMO the test is not strict enough and certain amounts of wear etc are permissable, whereas I like Customers and my own cars to have no play etc etc and be mechanically perfect.
I think by keeping "on top" of these things, you will avoid down time due to failures, and not end up with a long list of jobs to do before next Test, also have a much more reliable Car
HTH, Cheers Dave
M4rCu5 and Avel Du like this.
Dave2302 is online now
#6 Old 2 Weeks Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 896 Post(s)
Fix all the above as soon as posible.
Had my mot and the guy was very picky.
Repair as soon as possible (minor defects):
Driver's view to the front outside the swept area of the windscreen wipers restricted by an obstruction mascot on dash (3.1 (a) (i))
Monitor and repair if necessary (advisories):
Brake pedal wearing smooth anti-slip worn (1.1.2 (c))
Driver's view Items removed from driver's view prior to test (3.1 (a) (ii))
Engine bay covers obscuring some components
Under trays obscuring power steering components, brake pipes & fuel lines
Outer sill covers obscuring some prescribed areas
i860 is online now
#7 Old 2 Weeks Ago
Delucas's Avatar
Quoted: 1133 Post(s)
Id question but what have they missed on the MOT ?
Delucas is online now
The Following User Says Thank You to Delucas For This Useful Post:
#8 Old 2 Weeks Ago
Trev5's Avatar
Quoted: 303 Post(s)
Agree that tyres & brake pipes are always No.1 priority....
That is picky, surprised the MOT tester didn't comment on the tiny bit of gravel on Your mats......!!
Trev5 is online now
The Following User Says Thank You to Trev5 For This Useful Post:
#9 Old 2 Weeks Ago
i860's Avatar
Quoted: 896 Post(s)
That was planted by him, I know their dirty tricks.
Dave2302 likes this.
i860 is online now
#10 Old 2 Weeks Ago
Quoted: 161 Post(s)
Having seen that Brake Pedal I think I would be looking for another Testing Station next year
Anal Sphincter or what !!
Cheers Dave
i860 and M4rCu5 like this.
#11 Old 2 Weeks Ago
M4rCu5's Avatar
Quoted: 205 Post(s)
Do tell please
M4rCu5 is online now
#12 Old 2 Weeks Ago
i860's Avatar
Quoted: 896 Post(s)
@M4rCu5
We call him mushy-mushy is my son toy, just a reminder to come home safe.
Australian, M4rCu5 and Dave2302 like this.
i860 is online now
