transmission 'dead' diagnosis - Mercedes Benz SLK Forum
 21Likes
  • 2 Post By Australian
  • 3 Post By Turdo2
  • 2 Post By jbanks15
  • 2 Post By frogfoot
  • 3 Post By Padgett
  • 4 Post By Turdo2
  • 1 Post By Dave2302
  • 3 Post By dMh
  • 1 Post By frogfoot
#1 Old 2 Weeks Ago
dMh
Vehicle: SLK 230 R170 auto 2000
Hi. Took my '00 SLK 230 (86k) to an auto box specialist recommended by my regular garage for a transmission diagnosis as although working Ok it just felt a little clunky/jerky every now and then, and a few months ago there was one instance of it not changing up which was resolved after 'turning it off and on again', and around the same time it had jumped out of gear once. So imagine my reaction when i was told by the mechanic it was completely dead and needed replacing! I asked him how he knew and he said there should have been a particular reading showing which wasn't, which told him it was dead and tried to explain to me what was happening inside (I know NOTHING about this stuff). He quoted me 1,800UKP to fix and was also charged 90UKP for the diagnosis which took less than 5 minutes! Does anyone have any thoughts/advice on maybe trying to source a replacement box and getting someone to fit it as a more practical/cost-effective alternative or do I just have to suck it up?! I live in SW London, UK. Thank you
dMh is offline
#2 Old 2 Weeks Ago
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
For some reason your thread went into moderation.
Back into public view now.
It may have something to do with a failed seal and oil leaking through an electrical cable.
But what do I know.
I'll flag this to our experts
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
@Australian
@Dave2302
Avel Du is online now
#3 Old 2 Weeks Ago
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 76 Post(s)
Following from what Avel Du said, the first thing to do is to pull back the carpet in the passenger footwell, remove the plate (three nuts) and check for the presence of transmission fluid leaking from the transmission. It's also important to check the transmission fluid level.
If nothing there, then it's important to get the results of the scan the transmission specialist got (or didn't get), ie, the results of the scan. If he doesn't remember (or similar response) I would get a second opinion. Or, dare I say it, buy a fault code reader
I've never needed to work on the transmission (yet?) but from all I read on here, these transmissions are very reliable mechanically and most of the problems are with sensor and electronics.
By the way, what do you mean by "it jumped out of gear"? It slipped into neutral?
Lots of stuff on here - try searching:
https://www.slkworld.com/new-members...searching.html
M4rCu5 and Avel Du like this.
Australian is online now
#4 Old 2 Weeks Ago
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
The only time a 722.6 (your transmission) is dead, is when you hear bad noises.. other than that, it's still solid and probably has an electrical issue, which is usually just 3 things:
1. Transmission conductor plate
2. 13 pin connector (dirty)
3. ATF wicking through the wiring harness and into your TCU (trans control)
I agree with above, let's see what those readouts were!!
M4rCu5, Avel Du and Dave2302 like this.
Turdo2 is offline
#5 Old 2 Weeks Ago
Quoted: 6441 Post(s)
i will change ************* to dead
frogfoot and Avel Du like this.
#6 Old 2 Weeks Ago
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
maybe torque converter has broken up and put metal swarf into the box ...but am only guessing.
they guy might of looked for pressure and temp readings ect on his tester and maybe drained some oil to inspect
frogfoot is offline
#7 Old 2 Weeks Ago
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Sounds like a parts swapper and not a mechanic. I'd change the tranny oil & filter, add a can of Seafoam Transtune, and drive.
frogfoot, Turdo2 and Idiot101 like this.
Padgett is offline
#8 Old 2 Weeks Ago
Turdo2's Avatar
Quoted: 346 Post(s)
Hey I was just quoting the original post!
Turdo2 is offline
#9 Old 2 Weeks Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
I thought it strange that a supposed Auto Specialist said it was "dead" ................................
Guess that must be "Fault Code 7" after all ........................
"It's FCUK'ed sir"
M4rCu5 likes this.
Dave2302 is online now
#10 Old 2 Weeks Ago
dMh
Thanks/codes
Thanks for the responses and apologies for the 'expletive deleted'
I've just had a look at the invoice which I just threw in the car and he's written 'codes 146/147, transmission needs replacing'
I've just a cursory glance about these and can't see anything pertaining to complete and utter failure but quite a few references to leaking/low ATF etc.. but shall do more research. In response to someone suggesting he'd taken a sample of the oil and checked it for debris, he did nothing of the kind, as I say he plugged the reader in and 2 mins later called me over to say it needed replacing. Will be checking level myself and all your other suggestions, thanks again guys
jbanks15, frogfoot and Dave2302 like this.
dMh is offline
#11 Old 2 Weeks Ago
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
well now we know he didn't drain any oil its the first places to start. give it a filter and fluid swap has to be worth a try. bit odd to say a gearbox is done for on a 2min code pull ?
Dave2302 likes this.
frogfoot is offline
