Gear not displaying in dashboard cluster - Mercedes Benz SLK Forum
 33Likes
  • 2 Post By efair
  • 5 Post By savcom
  • 2 Post By Rafael Otamendi
  • 1 Post By Rafael Otamendi
  • 3 Post By Dave2302
  • 3 Post By Andjeti
  • 5 Post By Rafael Otamendi
  • 1 Post By M4rCu5
  • 2 Post By savcom
  • 3 Post By Rafael Otamendi
  • 1 Post By Bartiny
#1 Old 2 Weeks Ago
Vehicle: 99 SLK 230
Question Gear not displaying in dashboard cluster
Hello all,
I'm having issues with the gearbox, it seems like the limp mode type of thing... But there's something else I need help with. When I move from park to drive (or any other gear) it won't show in the dashboard. I'm assuming the gear you're in should show left side of the clock, right?
What could be causing this issue? I plugged the ODBII reader and I'm only getting a P0715, already ordered the plug to change in the transmission and see if that takes care of that code. But the question remains about the gear not showing in the cluster.
Any help would be appreciated.
Rafael Otamendi is offline
#2 Old 2 Weeks Ago
Quoted: 863 Post(s)
The TCU senses the position of the stick and reports it to the instrument cluster. Probably your TCU is bad - but scan it first. Did you pull back the carpet and equipment bridge and check for red stains where the harness comes through the floor?
Dave2302 and Rafael Otamendi like this.
efair is online now
#3 Old 2 Weeks Ago
Vehicle: 99 SLK 230
Is it possible that a bad TCU cause the limp mode? In case it's bad, does it need to be mapped to the car?
#4 Old 2 Weeks Ago
savcom's Avatar
Quoted: 604 Post(s)
You might also find a sticky liquid on the wiring harness too. The culprit is the Pilot Bush that connects to the auto transmission. The o-rings have perished and transmission fluid is wicking up the harness to the TCU.
I was lucky, but if you do find fluid in your TCU, you could try cleaning it out with a suitable electrical contact cleaner and a toothbrush (nothing lost as you'd likely be throwing the TCU in the bin anyway)
Good luck.
Also
Previous :
savcom is offline
#5 Old 2 Weeks Ago
Vehicle: 99 SLK 230
Attachment 548694
Good luck.
Thank you, I'm going to check that module tonight and will report back my findings!
LIL DON SLK and M4rCu5 like this.
#6 Old 2 Weeks Ago
Vehicle: 99 SLK 230
Attachment 548694
Good luck.
Ok. I took the TCU out and I did found oil in the connector. I don’t think it went inside the TCU so that’s good news. I cleaned the connector with electrical cleaner until the oil was out of there. I guess this means the transmission connector will need to be changed as soon as possible. I will wait until tomorrow to plug the TCU back and see if the cluster is showing the gear.
Thank you guys
M4rCu5 and Avel Du like this.
#7 Old 2 Weeks Ago
Vehicle: 99 SLK 230
I ended up plugging everything back in place. Still nothing in the cluster, I might need to bring the car to the mechanic to plug the computer and diagnose what’s the real issue. Or maybe the tcu is busted.
M4rCu5 likes this.
#8 Old 2 Weeks Ago
M4rCu5's Avatar
Quoted: 201 Post(s)
I'm not so sure if its not the gear lever assembly or not as that will also you give you a 'no gear' on the dash but as efair says, it's best to get it scanned first.
HTH
M4rCu5 is online now
#9 Old 2 Weeks Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 151 Post(s)
A regular cheap OBD will not scan all Transmission Codes, whoever scans it needs the correct and appropriate equipment to do the job.
There are only a handful of reasons for no Range report in Cluster in order of probability ................
TCU
Shifter
Conductor Plate inside Trans
Wiring
Cluster
Do not bin your old TCU straight away if swapping it out with a replacement, sometimes, despite replacements having identical part numbers they can have the wrong Version Coding, and you will need the old unit to copy and paste the coding using SDS ................................
Do not ask me how I found that out, luckily the "bin men" hadn't emptied it !!
This is the only way to do this unless you go to MB Dealer or Indie with subscription to MB Server !!
You will know if it has wrong coding as it will go into limp mode as soon as it shifts, when you drive it, and come up with "Ratio Error" Code if read on an appropriate machine.
Bin it once you have driven the Car a while and know that all is well
HTH, Cheers Dave
M4rCu5, Avel Du and savcom like this.
Dave2302 is offline
#10 Old 2 Weeks Ago
Andjeti's Avatar
Vehicle: 10/96 SLK230K RHD (Australian Delivered)
I also have no display in the gauge cluster, but mine drives perfectly fine without it. So the issues might not necessarily be related.
Jay
M4rCu5, Bartiny and Dave2302 like this.
Andjeti is offline
#11 Old 2 Weeks Ago
Vehicle: 99 SLK 230
Thank you all for the help.
I'm going to take the car "limping" to the Mercedes mechanic (it's close to my house so that's good) and read the codes. Also I'll be ordering the connector for the transmission, the dipstick, and some oil to make sure it's up to the right level.
Hopefully the mechanic can point me in the right direction
Wish me luck.
jbanks15, M4rCu5, Avel Du and 2 others like this.
#12 Old 2 Weeks Ago
M4rCu5's Avatar
Quoted: 201 Post(s)
Wish me luck.
Good luck
Dave2302 likes this.
#13 Old 2 Weeks Ago
savcom's Avatar
Quoted: 604 Post(s)
Wish me luck.
Good luck!
You can clean the loom as best you can. Don't use brake cleaner to clean the loom - it's too strong. Use electrical contact cleaner (and lots of it) to dilute the transmission fluid so that it 'drips' away from the loom and leave kitchen towel in the footwell end to soak up any fluid still in the loom that continues to wick up to the TCU.
Also
Previous :
savcom is offline
#14 Old 2 Weeks Ago
Vehicle: 99 SLK 230
Back from the mechanic.
Long story short I have to change the transmission connector and go from there. At this point is a guessing game. So I have to start there and move forward with the transmission plate if the issue is not fixed. The good news is, the shop had some interior parts I needed for my car... score them for $20.
Will keep you guys posted
M4rCu5, savcom and Dave2302 like this.
#15 Old 6 Days Ago
Vehicle: 99 SLK 230
Hello!
The connector arrived and I just changed it.
I put half a quart of oil back into the transmission and turned the car on. I had the engine light on but I waited until the temperature reached 80. Check the oil level and filled the rest of the oil. Went back to the car and the check engine light was off (good news). The shifting is still harsh. I haven't driven the car yet to check if the limp is gone, I hope it is...
If this doesn't work I guess the next step is replace the computer... and if that doesn't work I guess I will have to replace the valve cover in the transmission.
I'll keep the forum updated
PS: Still no gear in the cluster, I'm going to try and clean the pcb there and see how it goes.
M4rCu5, Avel Du and Dave2302 like this.
#16 Old 6 Days Ago
Bartiny's Avatar
Vehicle: 1996 SLK 230 R170
Quoted: 11 Post(s)
Hello all,
My pre-facelift 1996 does not have that facility, although mine is pre production so may have been on the production cars??
I am not sure if that is what you were asking in the highlighted bit of your quote
My pre production R170 test/demonstrator built August 19th 1996 saved from almost certain to be broken up for spares. Potentially the oldest surviving RHD by VIN?
Bartiny is online now
#17 Old 6 Days Ago
Quoted: 151 Post(s)
Before possibly wasting a lot of time and parts money I would want to see the results of a Full Scan and maybe some Data on SDS first.
For example, is your TCU, EGS (Selector Module) and ICM actually communicating with each other ?
You could end up with a lot of frustration, expenditure and a still un fixed Car otherwise
HTH, Cheers Dave
Dave2302 is offline
Johnwentz
