Major leak into passenger footwell - Mercedes Benz SLK Forum
 103Likes
#1 Old 3 Weeks Ago
Vehicle: Mercedes Benz SLK320 - 2002
Other Toys: Hubby has a CLK320
Hello fellow slk lovers,
I have owned my slk for 5 years, the last 2 years she has had a major leak, after rainfall or wash every time I make a right turn I can hear the water gush along my windscreen sluice channel and pour into the passenger footwell from the glove box region. ( I have her covered now and I am a fair weather driver with a dirty car!)
I have had mechanics clear the drains but it kept happening. The latest mechanic (awesome chap) took the plastic away from under the hood to reveal a rectangular hole, perfect for maybe a grill?
My questions are:
Does anyone know what should be here and maybe a part number so I can replace it?
For the first three years this didn't happen, has someone removed it because there is no broken part under the plastic cover?
I hope I have made sense and here are pictures to help you understand?
Thanks in advance,
Julz
Judleberry is offline
#2 Old 3 Weeks Ago
Quoted: 6435 Post(s)
look up parts here
https://slk-links.neocities.org
or post that vin for free gift datacard and we can look for you
Judleberry likes this.
#3 Old 3 Weeks Ago
Sir you are a star, thank you. I'll go look that up
#4 Old 3 Weeks Ago
Hello again, my VIN is...WDB1704652F281661 - Thank you
LIL DON SLK likes this.
#5 Old 3 Weeks Ago
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
Can't remember if the 170 is the same, but think it is.
This is for 171.
It's the air intake for the cabin.
Behind and below that hole is the fan.
You might find that the passenger footwell is damp.
Once water gets in it has nowhere to go.
There is a diy on fitting a home made grill over it to reduce the problem.
This sounds daft, but helps.
Look at how it is parked to help avoid ingress.
LIL DON SLK, M4rCu5 and Judleberry like this.
#6 Old 3 Weeks Ago
170 experts will drop by.
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
@Australian
@Dave2302
LIL DON SLK and Judleberry like this.
#7 Old 3 Weeks Ago
Datacard here
so you did not look up the part yourself?
#8 Old 3 Weeks Ago
part 105 Myk?
A 202 835 12 40
* HOUSING
BLOWER COVERING
#9 Old 3 Weeks Ago
Brilliant!, Yes I'm still at it, thanks
LIL DON SLK and Avel Du like this.
#10 Old 3 Weeks Ago
Look at post 8 above?
#11 Old 3 Weeks Ago
105 That looks like the bottom cover to the blower, Jeff.
The hole is the intake. 80?
The 170 gang will know if there is a screen or not.
#12 Old 3 Weeks Ago
I have, it could be but it looks a different shape to the hole in the photo? I need to go check the car again
#13 Old 3 Weeks Ago
130 is the blower
105 is above the blower
so why wouldn't 105 be the top?
#14 Old 3 Weeks Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 154 Post(s)
Hi Jeff,
I don't think it's 105, that looks to me to be the cover that goes under the blower motor, just above the passengers feet. 105 is actually beneath the blower motor when it's all assembled, that's a bad parts drawing
When I had mine apart, it did not have anything over the HVAC Air intake, I'm betting the "mechanics" have not cleaned out that drain on the left side of the Car, (RHD), properly, there is 2 compartments here, a lot to clear out, and that side is the critical side, as it will form a lake / loch, and spill in bucket fulls through the HVAC Air Inlet :wink
HTH, Cheers Dave
Dave2302 is offline
#15 Old 3 Weeks Ago
Maybe 105 fits in here item 20 that has the hole?
#16 Old 3 Weeks Ago
#17 Old 3 Weeks Ago
M4rCu5's Avatar
Quoted: 201 Post(s)
Hi Jeff,
HTH, Cheers Dave
You beat me by 25 minutes this time
THIS ^ There is no grill, as has been already mentioned the large hole is there for the cabin fan intake. And as Dave says, there are TWO compartments on that side etc. etc.
M4rCu5 is offline
#18 Old 3 Weeks Ago
M4rCu5's Avatar
Quoted: 201 Post(s)
THIS THREAD post #6 shows the two compartments a little more clearly, there is a through hole from the large "loch" to the other and then another hole in the smaller compartment that leads to the outside .. BOTH of these have to be clear
HTH
M4rCu5 is offline
#19 Old 3 Weeks Ago
Hi Dave, that is exactly what happened. All has been cleared out of the clogged drains now, I am just surprised that there is a hole here and it really looks like it's made for a purpose i.e. vent? I'm very interested to see what the 170 gang think I'm still looking on the partsouq aswell. thanks again
#20 Old 3 Weeks Ago
Thanks for the thread M4rcu5, my blower doesn't work either, that is when I took it Mercedes and they told me I need a new wiring loom because of the water damage and I should get rid of the car because the loom replacement would cost too much. I wanted to sort the leak out first before moving onto this next problem which the link to the thread is perfect for too thanks
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
