Gearbox drive failure - Mercedes Benz SLK Forum
 17Likes
  • 1 Post By MattB
  • 3 Post By i860
  • 1 Post By efair
  • 3 Post By i860
  • 2 Post By efair
  • 3 Post By frogfoot
  • 3 Post By Turdo2
  • 1 Post By slkeric
#1 Old 4 Weeks Ago
Location: In a county visually not dissimilar to 'The Shire' from 'Lord of the Rings'
Vehicle: Mercedes SLK 230K (2002) / Designo Edition
Other Toys: Ford Ranger Wildtrak / 2015
Hello Folks. I would really appreciate some advice or opinions.
I have a 230k 2002 Designo Edition and around two weeks ago after being parked for only an hour after working fine I started the car up and immediately heard a high pitched whine when driving. Carrying on down the road it continued but ultimately at a roundabout it would not even engage into second gear and ultimately I had to get it towed home. It is presently sitting at a garage whilst I try to figure out what to do for the best.
I have had a quote for an auto box repair / rebuild at Ł1500 plus VAT but haven't gone as far as looking at filters etc not wanting to add to unnecessary costs. The car has done around 72k and is in decent order.
My question is ... do I repair the car ?... should I expect other expensive issues ?.. or should I cut my losses and buy another and attempt to part exchange it.
Any advice most welcome ...
all the best, Matt
MattB is offline
#2 Old 4 Weeks Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 894 Post(s)
i860 is offline
#3 Old 4 Weeks Ago
Quoted: 868 Post(s)
Presumably you've read about the pilot bushing issue - did you check it, and for ATF in the passenger footwell?
efair is offline
#4 Old 4 Weeks Ago
Nothing has been checked .... the garage was just wary of auto boxes.
Does my issue sound like it could be this ....
MattB is offline
#5 Old 4 Weeks Ago
Would it be something my local garage could put in ... or is it still requiring an autobox specialist mechanic ...
MattB is offline
#6 Old 4 Weeks Ago
i860's Avatar
Quoted: 894 Post(s)
First, I will scan that car with DAS Mercedes and see what faults are in the gearbox.
If the gearbox is damage then buy a second-hand one any decent garage can do the job.
frogfoot, Idiot101 and Avel Du like this.
i860 is offline
#7 Old 4 Weeks Ago
Moderator/RoTMorganiser
Quoted: 2195 Post(s)
Although done on a 171 @frogfoot recently sourced a recon tranny and had a local indy fit it.
He might be able to suggest a few ideas when he drops by.
#8 Old 4 Weeks Ago
Quoted: 868 Post(s)
Yes, possibly. Also - find a better mechanic. These tranny's done suffer from mechanical issues typically. It's usually electronic.
M4rCu5 and Idiot101 like this.
efair is offline
#9 Old 4 Weeks Ago
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
Smile
Close..it was a rear diff I got from a breakers yard darn south and MB of hull ( main dealer ! :-) ) fitted it... saved around 2 grand
For the price quoted on the repair you could buy a second hand 170 and pull as many parts you like from it and get them swapped onto your car , or just find a second hand box . Ebay good place to start looking
M4rCu5, Idiot101 and Avel Du like this.
frogfoot is offline
#10 Old 4 Weeks Ago
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
Usually pilot bushing failures were pre-98.. they upgraded the design after that. but who knows, could be anything. I would feel completely comfortable finding a used one to install.. they are good tough transmissions!
frogfoot, M4rCu5 and Avel Du like this.
Turdo2 is offline
#11 Old 3 Weeks Ago
Vehicle: SLK R170, 230 Automatic. 1997, German spec.
Other Toys: Honda 1100XX Blackbird.
I had thesame after replacing the conductorplate in the box.
Code P748. Main press sollonoid.
I did lots of things to solve this problem, long story.
On the end, I replaced (again) the oil and filter in the gearbox to be sure the level was ok.
MB resetted the car, everything allcodes cleared, all normal again.
Just 20 km from me is a Mercedes Classic dealer, they resetted the car, cost, 50 euro.......
Good luck!
slkeric is offline
