Resolved - Lock turns and clicks but trunk / boot will not open - Mercedes Benz SLK Forum
 8Likes
  • 2 Post By jbanks15
  • 2 Post By efair
  • 4 Post By myf16
#1 Old 4 Weeks Ago
Vehicle: 1998 SLK 230 _and_ 2001 SLK 230
Quoted: 9 Post(s)
My 12k mile 2001 SLK 230 has a trunk that will not open even though the lock appears to be working properly and the handle depresses normally.
Something is holding the trunk closed. I pulled up pretty hard but no joy.
What could be the problem? This is weird.
I've read that I can ground one wire under the hood to allow the roof mechanism to operate, allowing me to get to the innards of the trunk. Can anyone PM me that information?
myf16 is offline
#2 Old 4 Weeks Ago
Quoted: 6439 Post(s)
post 11?
https://www.slkworld.com/slk-r170-ge...-my-trunk.html
https://www.slkworld.com/slk-r170-ge...cant-open.html
#3 Old 4 Weeks Ago
Quoted: 868 Post(s)
Is the issue is your luggage partition, ground Pin 54, Grey/Violet, of the MFCU.
See post 14 https://www.slkworld.com/slk-r170-gen...ere-start.html
efair is offline
#4 Old 4 Weeks Ago
Quoted: 9 Post(s)
Plot twist. The trunk opened normally this morning.
I suspect a tired solenoid or a gummed-up latch is almost but not quite releasing sometimes. I will take it apart today and look.
Has anyone here experienced this problem?
myf16 is offline
#5 Old 4 Weeks Ago
Moderator/RoTMorganiser
Quoted: 2195 Post(s)
The trunk lock is vulnerable to road dirt, which causes it to jam.
Doesn't sound quite like your issue, but a little tlc, wiggling key a lot with graphite lubricant may help.
#6 Old 4 Weeks Ago
Quoted: 9 Post(s)
I opened the plastic access panel inside the trunk lid. The lock mechanism appeared to be working correctly. The PSE can actuate the lock by vacuum or the key can move it by hand.
I removed the whole mechanism, which requires removing the exterior piece with the license plate lights, two screws outside and two 8 mm nuts inside. Then there are two screws under that exterior piece.
I put some PB blaster on the moving part of the lock since I couldn't see anything wrong with it.
The problem persisted. The trunk sometimes opened and sometimes did not. I decided that the latch might be misaligned. I pulled back the plastic at the rear of the trunk and used a T30 driver to loosen the striker. It was slightly off center so I re-centered and tightened it.
The trunk now appears to open and close normally.
After all that, the problem was nothing more than a misaligned striker. Sloppy work at the factory, just like my two loose bolts inside the driver's door.
myf16 is offline
