front lock cylinder - Mercedes Benz SLK Forum
 6Likes
  • 2 Post By M4rCu5
  • 2 Post By murat orhan
  • 2 Post By Terminal
#1 Old 4 Days Ago
Vehicle: slk 200 2001
Send a message via Skype™ to Freda Dixon
front lock cylinder
hello all, I am back again! I hope I am posting in the right place this time.
I have already received from this wonderful site plenty of advice to do with this subject but sadly although I kept the files which were sent by mail to me, my computer will no longer open them.
Anyhow the story is 64 yr old lady owner with no mannot a lot of money either, one of her treasured possessions is her 2001 slk200, which now like her is getting old and has a leaking roof, I have been regularly filling up the pump but things have been getting worse and the headlining was sagging! So anyway, I have managed to remove it and have located the dodgy part (dont know the name) so the good news is that our local mercedes dealer have it in stock and its at 30% off and is going to cost me 230 euros!
I can see where the two pipes go and these are easy to follow up to a point, my question is will the new piece come with the pipes attached? Will I have to get them all the way to the boot and to the pump or is there another method without having to take the whole car apart? Are these pipes easy to mount at the pump, is there some protocol that should be followed and would the system need bleeding afterwards? I will try to add a photo of the front of the roof, I am not sure how to actually get into free the part from under the metal attachment, it seems to have some sort of circlip? Also is is easy to disconnect it at this end? Sorry I am not being very clear but any advice would be so gladly appreciated!!!!!
Freda
Freda Dixon is offline
#2 Old 4 Days Ago
Moderator/RoTMorganiser
Quoted: 2132 Post(s)
Were the files in posts? If so, they can be found for you.
#3 Old 4 Days Ago
Meanwhile, these folks might know.
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
@Australian
@Dave2302
#4 Old 3 Days Ago
M4rCu5's Avatar
Quoted: 175 Post(s)
Oh you're back, hello again
Until someone else jumps in, I'd recommend that you watch Klaus' playlist so that you can get a handle on the roof hydraulics .. nearly 2hrs worth
https://www.youtube.com/playlist?lis...6w5l1xEtmsKUXF
Dave2302 and Freda Dixon like this.
M4rCu5 is online now
#5 Old 3 Days Ago
murat orhan's Avatar
Quoted: 26 Post(s)
check this out, if you plan to fix the cylinder seal without removing the lines all the way to the pump.
https://cabriolethydraulics.com/our-...pair-couplers/
some notes:
- you can only remove the pump end of the lines, cylinder end is fixed.
- if you are to remove the lines make sure you mark the attachment points on them beforehand
- cylinder will self bleed after several opening closing cycles
- better to use oem style u-ring instead of cheap o-rings for one time only fix
- hardest part for front cylinder seal replacement is the connecting part that is at the tip of the rod is fixed. so it will need some drilling and re-fixing the clip holding it. if you search the net you'll find some solutions that people used
murat orhan is offline
#6 Old 6 Hours Ago
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 521 Post(s)
Other than your message above, this is the last topic you posted:
https://www.slkworld.com/slk-r170-ge...-cylinder.html
Terminal is offline
#7 Old 29 Minutes Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 104 Post(s)
That link above goes straight to this thread ???
HTH
Dave2302 is online now
