Hydraulic Cylinder Fix on SLK320 Vario Roof - Mercedes Benz SLK Forum
 7Likes
  • 1 Post By jbanks15
  • 3 Post By efair
  • 2 Post By efair
#1 Old 6 Days Ago
Vehicle: 2001 SLK320 Silver
Other Toys: Guitars
Hi everyone. I am thinking (and planning) to rebuild the hydraulic cylinders (all 5 of them) in my 2001 SLK320 vario roof. Can somebody please tell me if I also need to take the whole cylinder with the hydraulic lines? Or can I just do the rebuilding without taking out the hydraulic lines? I've been reading a lot of posts but it is not clear to me. I might have missed the info. I have removed all the trim panels, including the headliner and I now have access to all the cylinders. I am open for your good advice on this project.
Thanks in advance.
mountndo is online now
#2 Old 6 Days Ago
Quoted: 6339 Post(s)
check here also
https://www.slkworld.com/slk-r170-cl...cylinders.html
Dave2302 likes this.
Wavetrac LSD thread here:
#3 Old 6 Days Ago
Other Toys: Guitars
Thanks for a quick reply. Iv'e watched all the Top Hydraulics DIY videos but alll the instructions necessitates removal of the cylinder including the hydraulic hose. My question is do I have to remove the hydraulic hoses from the main pump before I can rebuild the cylinder?
#4 Old 6 Days Ago
let's summon some experts
@efair
@stu32
@savcom
@Turdo2
@VII7
@M4rCu5
@Dave2302
#5 Old 6 Days Ago
also from pelican parts 230 but the same as 320
The lines are removed at the hydraulic pump. Use side-cutters or an equivalent to carefully cut the nylon ties that secure the lines.
https://www.pelicanparts.com/techart...eplacement.htm
#6 Old 6 Days Ago
Quoted: 849 Post(s)
It is possible to rebuild without removing, however if you've removed all panels it's very easy to go ahead and remove the lines - and I recommend doing so.
Australian, M4rCu5 and Dave2302 like this.
efair is online now
#7 Old 5 Days Ago
Other Toys: Guitars
Thanks efair. I think I will heed your advice and remove the cylinders and the hydraulic lines to rebuild. I will try the Top Lock cylinder first since it is one of the two cylinders (out of the 5) that has a small leak at the piston rod. Is it really necessary to drill a small hole on the cylinder body to remove the snap ring? This is one of my big concerns. I wonder if anyone has tried to remove the snap ring successfully without drilling an hole?
#8 Old 5 Days Ago
Quoted: 849 Post(s)
I'm sure there is a special tool that will remove the retainer ring, but I don't know what it is or where to get one. Really though - there's no harm in drilling a small hole to facilitate removal. Or cutting a slot.
If you do drill, I also recommend you find a 1" length of brass or aluminum tubing, cut it lengthwise, and slip it around the piston rod while you're drilling. This is to protect the rod... in case you do slip you won't nick the rod.
mountndo and M4rCu5 like this.
efair is online now
