1998 SLK 230 A/C issues - Mercedes Benz SLK Forum
 9Likes
  • 1 Post By M4rCu5
  • 1 Post By cbrbo
  • 1 Post By jbanks15
  • 2 Post By jbanks15
  • 3 Post By cbrbo
  • 1 Post By Dave2302
#1 Old 06-26-2019
cbrbo's Avatar
Vehicle: 1998 SLK 230
Other Toys: Bike, Boats
Quoted: 15 Post(s)
My 1998 slk 230 had an issue while I was driving it one day and the gauges started to act up and the A/C quit working.
From reading the forum I was able to diagnose the gauges and ended swapping them out.
The gauges are working fine, but the a/c never did start working.
I thought it might be low on freon and took it to the shop, they checked it out filled the system and said that the compressor was not coming on.
I looked at the fuses I think feed the a/c and they are good.
My question is how to I test the clutch to make sure it is working.
Can I jump the wires on the pressure switch and if so which ones or is it better to just put 12 volt to the wire that feed the compressor.
Any other suggestions would be appreciated.
Bob
cbrbo is offline
#2 Old 06-27-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 161 Post(s)
To save yourself a headache and likely un necessary expense / time, get it on SDS, (not some cheap lesser machine), look at AAC and see what Fault Codes, look at live Data ("Actual Values") etc etc.
Anything else is pure speculation and guesswork with this type of fault, it could be a whole bunch of things, and the law of sod says it will be the last thing you look at
HTH, Cheers Dave
Dave2302 is offline
#3 Old 06-27-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
Bob
Fuse 15 for the Duo Valves? They're closing OK? You have ambient air or permanent red hot air?
Turdo2 likes this.
M4rCu5 is offline
#4 Old 07-11-2019
cbrbo's Avatar
Quoted: 15 Post(s)
A/c blows cold while driving and not at idle
The a/c is filled and working great when driving. When at idle it isn't cold at all. I narrowed it down to the silver finned controller on the fender. If I add power to the controller the a/c blows cold at idle.
What the issue is I am having trouble identifying the part number and name.
I looked on FPCEuro and saw this part which I think is it, and looking for a second opinion to be sure
https://www.fcpeuro.com/products/mer...230-0255453332
Thanks Bob
cbrbo is offline
#5 Old 07-11-2019
Quoted: 6453 Post(s)
you can go here with your vin and get the exact part number for your car
https://slk-links.neocities.org
#6 Old 07-11-2019
here from your vin
A 025 545 33 32
ELECTRO. TRS. CTRL. UNIT
AUXILIARY FAN
Replaces: A0275458132
Replaces: A0185459932
item 56 in the pic
M4rCu5 likes this.
#7 Old 07-11-2019
https://www.getmercedesparts.com/oem...UtNTQ1LTMzLTMy
#8 Old 07-11-2019
cbrbo's Avatar
Quoted: 15 Post(s)
The issue was low freon and now the system blows cold while driving, but not at idle. If I put power to thie part in the picture the a/c will blow cold at idle.
I can't find out what the part name or number is or even if it can be tested
Thanks this site is great, if I knew the part association group or part name. I got some searching to do
Bob
cbrbo is offline
#9 Old 07-11-2019
Thanks this site is great.
did u read my post 6 n 7 above?
it tells you the part number and part name and even where to buy it
part name.....part number
A 025 545 33 32
AUXILIARY FAN
#10 Old 07-11-2019
cbrbo's Avatar
Quoted: 15 Post(s)
no you are quick on the draw. only saw your last post.
Thanks again
jbanks15, M4rCu5 and Dave2302 like this.
cbrbo is offline
#11 Old 07-12-2019
Quoted: 161 Post(s)
Yes that is Cooling Fan Controller, it should come on when A/C is on regardless of Engine Temp !!
The fact that "A/C is working when driving" is because the moving car is forcing air through the A/C Rad but when stationary the Cooling Fan is needed to do the same job.
I'm assuming that what you are actually doing by applying power is making the Fan run
Once again, IMHO using the "appropriate Diagnostic machine" would be able to confirm or refute without spending money on Parts or wasting time changing something that may not be faulty .............
It may be a wiring or relay issue to that Controller, especially if the cooling fan is working at the higher end of engine temps
HTH, Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
