230 headlining - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By M4rCu5
  • 2 Post By Rofa
  • 1 Post By M4rCu5
#1 Old 06-24-2019
BSKPLoft100's Avatar
Vehicle: 1998 SLK 2.3 automatic blue convertible coupe
Other Toys: model trains DIY
Quoted: 9 Post(s)
230 headlining
Hi after removing the four screws from the headlining of my SLK 230 1998 170. I am stuck with the next procedure to remove, any thoughts please?
regards
Brian
BSKPLoft100 is offline
#2 Old 06-24-2019
Quoted: 2207 Post(s)
Should be in one of the diys. Cylinder rebuild I think.
https://www.slkworld.com/slk-r170-class-diy/
#3 Old 06-24-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
regards
Brian
There's 9 Brian, be careful not to drop those back ones, they can be a pain in the 'arris ..
Top Hydraulics Part 3
Dave2302 likes this.
M4rCu5 is offline
#4 Old 06-25-2019
Vehicle: 1997 230 Kompressor
Other Toys: Saab 9-5 V6 , Various Jags and Europa aircraft in the past
Quoted: 18 Post(s)
The back ones are an even bigger pain to put back. You need to set the roof to just the right angle and use BlueTack or similar to stick the screw to the driver maybe. It's worth getting a few spares, they are not a special screw really. You can extract the headliner without removing the back screws, but don't be tempted. The side pieces of trim lock into the fixed back piece with small plastic tabs which break off really easily.
Rofa is offline
#5 Old 06-25-2019
Quoted: 9 Post(s)
thanks for the info. folks, I seem to have a rogue elephant here, I have removed the two sun visors, and the surround, to get to three screws, two of which were obstructed by clips these were supposed to be glued to the headlining, (some hopes). Why did a class car like the Merces, have such a bad adhesive. Bad window stops. bad door panel connections etc
Anyway, having got access to the roof mechanics, the micro switches seem to be OK, which leaves me floundering still on the non function of the roof!!!
Regards
Brian
#6 Old 06-30-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
Chinese steel for body panels etc.
Early to mid-90's the German car industry was floundering due to low sales generated by expensive, high quality, well made cars. In essence, Joe Public couldnt afford to buy them and the Germans couldn't compete with the Japs.
Porsche called on Toyota to help them design the Boxster .. Mercedes called their accountants ..
M4rCu5 is offline
