Is my SLK jacked up? - Mercedes Benz SLK Forum
 34Likes
#1 Old 3 Weeks Ago
I think the previous owner of my SLK jacked up the rear with his suspension “upgrades.” I measure 27.5 inches from the ground to the highest point on the rear wheel arch. (Tape measure pressed against the tire sidewall.) What is yours? Thanks!
Gold5 is offline
#2 Old 3 Weeks Ago
Quoted: 6346 Post(s)
post a picture
Dave2302 likes this.
#3 Old 3 Weeks Ago
Thanks for your measurements!
File Type: jpg B1AA609A-7E51-4D10-A0C2-177DAFB6F9C0_1561374470910.jpg (48.8 KB, 20 views)
Gold5 is offline
#4 Old 3 Weeks Ago
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 64 Post(s)
Mine measures 25 3/4 inches.
2 minutes to measure it, couple of hours to find a tape measure with inches on it .
Australian is offline
#5 Old 3 Weeks Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 106 Post(s)
There is a lot of potential in this statement, are you bragging ??
Mine measures 26.5 " , it is slightly further up than it was .........................
but I've just fitted new rear springs and 4 dot spring seat rubbers to hike it slightly, when the V8 goes in it will squat under hard acceleration, I'm hoping it will settle down slightly, if not it won't take long to try a set of 3 dot seats
HTH, Cheers Dave
M4rCu5 and pwgunny like this.
Dave2302 is offline
#6 Old 3 Weeks Ago
Yes maybe it’s the aftermarket springs. I thought the mechanic said he took out the spacers. But I also have the wrong tires on the back. They are 245/50/16 instead of 225/50/16. I know this makes the tires wider, but are they taller too? Thanks again!
Gold5 is offline
#7 Old 3 Weeks Ago
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 521 Post(s)
Yes, abt 3/4 inch.
It's a ratio between width and sidewall.
https://tiresize.com/tyre-size-calculator/
Australian, M4rCu5 and Dave2302 like this.
Terminal is offline
#8 Old 3 Weeks Ago
M4rCu5's Avatar
Quoted: 177 Post(s)
Yes as @Terminal has pointed out, you have 50% of 245 (122.5mm) as opposed to 50% of 225 (112.5mm)
Australian and Dave2302 like this.
M4rCu5 is offline
#9 Old 3 Weeks Ago
M4rCu5's Avatar
Quoted: 177 Post(s)
Originally Posted by M4rCu5 View Post
Yes as Terminal has pointed out, you have 50% of 245 (122.5mm) as opposed to 50% of 225 (112.5mm)
Having said that, whilst the rear end of the car will sit 10mm higher, it also has 10mm more rubber all the way around the rim so you'd expect the wheel/tyre combination to fill the wheel arch a little more snugly than OEM if anything, which still points towards the springs or the seats as previously mentioned ..
M4rCu5 is offline
#10 Old 2 Weeks Ago
Other Toys: Traded them all!!
Quoted: 101 Post(s)
Certainly looks odd to me. The car looks like it is stuck on a sub frame.
The stock tires on the 230 and 320 are 205/55 x 16 front and 225/50 x 16 so they are more or less the same diameter.
On the SLK 320 Sport they are 225/45 F and 245/40 in the rear 17 inch
The SLK32 AMG runs 225/40 18 and 255/35 18.
A 205/55 16 and a 225/45 17 are to all intents and purposes the same diameter (24.9 vs 25), the wall heights are 4.4 vs 4.0 and revs per mile vary between 811 and 808
A 225/50 17 is theoretically 24.9 x 4.4 revs 812 and a 245/40 17 24.7 x 3.9 revs.
I didn't run the numbers on the SLK32 but I am reasonably confident the diameters will work out very close to these numbers with a shorter wall height
So there is no way this car with tires that actually fit this car should look that ugly.
Remember there has to be clearance at the front so offset has also to be considered when upsizing.
A
Alex 3 is offline
#11 Old 2 Weeks Ago
OK so it makes sense that the space between the tire and the wheel arch is the main problem. could the spacers or pads that the mechanic is referring to be the seats that you guys are mentioning? And should I ask the mechanic to remove the higher springs and replace them with factory spec springs? Will the shocks need to be replaced too? I had a good experience with FCP euro. Can you recommend a cheaper source? Thanks.
Gold5 is offline
#12 Old 2 Weeks Ago
Plus, how do I know if I have a 320 or a 320 Sport?
Gold5 is offline
#13 Old 2 Weeks Ago
Ok, update. FCP Euro took my VIN and said it’s a 320 non-Sport. OEM spec springs are $85 each. How does that sound?
Gold5 is offline
#14 Old 2 Weeks Ago
M4rCu5's Avatar
Quoted: 177 Post(s)
I think I'd take a closer look at the pads first, there may be nothing wrong with the springs
M4rCu5 is offline
#15 Old 2 Weeks Ago
I think the pads were removed. Would these springs work?
https://www.ebay.com/itm/For-Mercede...n/352197897737
Gold5 is offline
#16 Old 2 Weeks Ago
Quoted: 101 Post(s)
I am always leery about critical parts off eBay. For $2 more you can get these:
https://www.pelicanparts.com/More_In...=0&SVSVSI=4095
Alex 3 is offline
#17 Old 2 Weeks Ago
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 333 Post(s)
everyone hold on here!
Have you confirmed spring pads were removed? I would like to see picture evidence if so! I'd say it's highly unlikely that anything was done to JUST the rear except for the wrong tire size.
Mine sits a little high in the rear even with #1 spring pads. But I have CLK55 coils on my car and it definitely squats under acceleration.
Turdo2 is offline
#18 Old 2 Weeks Ago
Quoted: 106 Post(s)
Good to know we are both thinking of things like squat etc on our monster R170's
If you don't mind me asking, what dot rubbers are you using on the front and what Springs ?
Below is a photo of mine currently with the V6 in it, I think I will need to do a little work on the front as to me it looks already a tad low, despite 3 dot rubbers and brand new stock V6 Springs !!
I expect it will drop a little further when the M113 V8 goes in
What do you think Aaron ?
Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
#19 Old 2 Weeks Ago
Turdo2's Avatar
Quoted: 333 Post(s)
Cheers Dave
I imagine it will drop a little bit more with the V8. Mine dropped 12+mm but I had 230 coils. now it has #1 pads and 2001 CLK55 coil springs all around. I'm almost tempted to take the rear pads out to get a few more mm, but I dont really hate it the way it is. I like my wheels/tires to be concentric with the wheel arches and mine is close enough.
Turdo2 is offline
#20 Old 2 Weeks Ago
Quoted: 106 Post(s)
Hi @Turdo2 ,
Yours is exactly how I want mine to look, so with any luck I will simply need to either fit 4 or 5 dot front seat pads, or maybe just go to CLK55 Springs and 1 dot seat pads at the front ............
More fodder for my research folder, Thanks Aaron,
Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
