Resolved - 2002 SLK transmission issue - Mercedes Benz SLK Forum
 16Likes
  • 1 Post By i860
  • 1 Post By M4rCu5
  • 4 Post By SLKNESS
  • 2 Post By Mn car guy
  • 1 Post By Dave2302
  • 1 Post By Alex 3
  • 2 Post By M4rCu5
  • 3 Post By SLKNESS
  • 1 Post By Alex 3
#1 Old 06-22-2019
Vehicle: 2002 SLK 320
Hey everyone. I recently started having a little issue with my 2002 SLK 320. When I start the car in the morning or anytime really when the engine and transmission are cold, when I start driving my car won't shift out of first. It will rev up and hold in 1st gear. When I stop, put it in park and then back into drive, the car shifts fine. It sometimes judders a tiny bit when shifting into 2nd through 5th gear but it's very subtle and it dosen't always do it. It's at random. The transmission is due for a fluid and filter change and I plan on inspecting and if need be replacing the plastic connector for the transmission control module. Anyone else had this same issue with their 2002 SLK 320 with the 722.6 transmission? I'm hoping that it's just dirty fluid and changing it out will remedy the problem. I don't have any check engine lights and there is no violent or sudden jerking or slamming into gear from the transmission. It's just that 1st gear issue.
SLKNESS is offline
#2 Old 06-22-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 894 Post(s)
If you can scan the car to see if any errors in the transmision module.
Dave2302 likes this.
i860 is offline
#3 Old 06-23-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
First thought, if it's fine from 2nd to 5th, put into W and then it'll pull off in 2nd .. not really a fix tho tbf.
According to MB Medic (amongst others) the no.1 reason for AT gear change issues is low fluid.
You may need to bring your plan for atf + filter + connector forward somewhat .. sooner rather than later ..
M4rCu5 is offline
#4 Old 06-23-2019
Thanks for the feedback everyone. Gonna service the transmission real soon and replace the fluid, filter and connector 😁
SLKNESS is offline
#5 Old 06-23-2019
Vehicle: 2009 CLK 350 cab
Quoted: 129 Post(s)
Sounds like low fluid level. For some reason, many of these cars didn't come with a dipstick. I'd order one and check your level before you drive it again. If that is the problem and you keep driving it, major damage to the clutches will result.
Mn car guy is offline
#6 Old 06-24-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
Hi, /\ /\ /\ Absolutely 100% agreed
TBH in all my years of rebuilding 722.6 in various Mercedes Models I don't ever recall seeing one that came with a Dipstick
Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
#7 Old 06-26-2019
Other Toys: Traded them all!!
Quoted: 103 Post(s)
I can only speak to 2001 NA and Japanese but also W211 E Class but none of them came out of the factory with dipsticks in the trans as far as I know. They were sealed for "life" which is nonsense.
If a car has a dipstick it is because someone did a service and bought the kit.
Others and myself are of the view that 100, 000 mi is time to change oil, filter etc.
This sounds like low fluid to me as well. It could happen when really cold but should disappear after a couple of miles of driving,
M4rCu5 likes this.
Alex 3 is offline
#8 Old 06-26-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
Recommend that everyone downloads and at least part reads THIS .. contains all you need to know and then some!
Taken from page 10 ..
Recommended Fluid...
Mercedes Synthetic ATF...Part Number 001 989 21 03 10 or suitable substitute.
Daimler/Chrysler Sprinter & Crossfire....Part Number 5127382AA.
Dodge Magnum, 300C & Grand Cherokee.... Chrysler Type 4 fluid.
The Mercedes transmission does NOT come equipped with a dip stick for checking fluid level. The filler
tube has a locking plug in it from the factory. When fluid level needs to be checked use a screw driver to pry
the lock from the plug and remove the plug as seen below. Ensure vehicle is parked on level ground and
apply the parking brake.
Purchase the dip stick from a Mercedes Benz dealer using part number 140 589 15 21 00 shown below.
While in Park at idle, with fluid warm, use the tool to check fluid level by inserting the dip stick into the filler
tube until fully seated, wait 3 seconds, then remove the dip stick and check the fluid level indication on the
dip stick, as shown below.
Dipstick tool for Sprinter & Crossfire use Miller Tool 8863A, Magnum & 300C use Miller Tool 9336. Grand
Cherokee comes equipped with a dipstick. Sprinter/Crossfire uses Trans fluid 5127382AA and can be
topped off with no more than 1 quart of Type 4. The Dodge Magnum, 300C and the Grand Cherokee use
... and so on and so forth .. 120 pages worth
Australian and Dave2302 like this.
M4rCu5 is offline
#9 Old 06-27-2019
Thanks again everyone. Just had the transmission serviced. The transmission shifts smoothly now with no issues. Looks like it was the electrical connector. There was a little fluid in there. Thankfully the fluid was clean and the pan had no metal pieces in it at all so the transmission is in great shape 😁
jbanks15, M4rCu5 and Dave2302 like this.
SLKNESS is offline
#10 Old 06-27-2019
Vehicle: 2000 SLK 320
Quoted: 52 Post(s)
If you spend some time and read your owners manual you will find that the engine management system keeps the car in a low gear untill the catalytic converters are up to temp to reduce harmful emissions.
Regards Stuart
t140v is offline
#11 Old 06-27-2019
Quoted: 103 Post(s)
Think about this too. The fluid softens the insulation on the wiring and eventually will cause a short that will go right into your ECU so timely and cheap insurance.
Alex 3 is offline
