Transmission control module replace - Mercedes Benz SLK Forum
 22Likes
#1 Old 3 Weeks Ago
Vehicle: 1999 slk230
Other Toys: Jeeps
Was just told by my shop that my transmission control module is defective they want $1500 for a replacement module I have more than enough skill to replace it but I need to know if there is any programming required or can I just swap one from the junkyard
Thejeepguyonline is offline
#2 Old 3 Weeks Ago
Moderator/RoTMorganiser
Quoted: 2137 Post(s)
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
@Australian
@Dave2302
#3 Old 3 Weeks Ago
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 333 Post(s)
First!
Since you have a 99 you have an EGS-51 TCU. it means you can find a TCU from any other 99 SLK 230 and it will work without any programming. plug and play!
I have had luck with ebay units. Shoot for one that is a little more expensive to insure it was pulled from a vehicle with no stored transmission codes.
I bought one for $20 and it had the danged limp home syndrome.....
jbanks15, i860, M4rCu5 and 2 others like this.
Turdo2 is offline
#4 Old 3 Weeks Ago
Other Toys: Ginetta G32
Quoted: 92 Post(s)
Perhaps you know of a good reputable source for used parts you can buy from.
We had a c32 AMG that a previous owner had changed the TCU and it didn't work properly on the AMG. It only cost us 150 to have it re-coded and the adaptions reset so not the end of the world and still way cheaper.
M4rCu5, Avel Du and Dave2302 like this.
stu32 is offline
#5 Old 3 Weeks Ago
Other Toys: Jeeps
Thank you both for your reply’s I will be looking one up on eBay I will buy one with the exact numbers to be safe.
M4rCu5 and Avel Du like this.
#6 Old 3 Weeks Ago
Other Toys: Jeeps
Well after much reading I felt the shop may have been wrong about the tcm being bad. I bought my own scanner that has the 32 pin plug for checking the car out. Showed 13 transmission faults. Decided to change the conductor plate first. After replacing it all codes went away except one. It’s etc dtc18 shifter out of location or something like that.(I am at work don’t have it with me)I was checking to see if anyone has info about transmission code 18? I can’t find anything on how to fix it.
#7 Old 3 Weeks Ago
Other Toys: Jeeps
I also still have a tcm on its way. And will swap out when it gets here to see if that helps.
#8 Old 3 Weeks Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 106 Post(s)
You need to adjust the rod between Shifter and Transmission
HTH, Cheers Dave
M4rCu5 likes this.
Dave2302 is online now
#9 Old 3 Weeks Ago
M4rCu5's Avatar
Quoted: 178 Post(s)
Dunno if this helps or not, it lost me on about page 10 .. definitely not for the faint-hearted and a .pdf that's too big to upload!
One for the Pros I reckon .. Mercedes Jaguar Daimler Chrysler 722.6 .pdf
Dave2302 likes this.
M4rCu5 is online now
#10 Old 3 Weeks Ago
Quoted: 106 Post(s)
WIS gives the procedure to adjust the selector rod
HTH
M4rCu5 likes this.
#11 Old 3 Weeks Ago
Other Toys: Jeeps
Don’t mean to sound stupid but what is WIS?
#12 Old 3 Weeks Ago
Quoted: 106 Post(s)
Mercedes WIS / EPC = Workshop Information System / Electronic Parts Catalogue = Workshop Manuals (how to, torque figures, wiring diagrams etc) / Parts Dept Software (drawings part numbers, revisions etc)
A set of discs can be had off EBay for 10 - 20, load 'em up on your computer.
If you buy the correct diagnostic machine, (SDS), that already has all this loaded from 400 plug and play.
HTH, Cheers Dave
#13 Old 3 Weeks Ago
Other Toys: Jeeps
Thank you for the info is there someone who can post or direct me to instructions on adjusting the shift rod?
#14 Old 3 Weeks Ago
Other Toys: Jeeps
A friend turned me on to Alldatadiy.com and I got all the info on the car.
M4rCu5 likes this.
#15 Old 3 Weeks Ago
Other Toys: Jeeps
Setting
1 Move selector lever to position "D".
NOTE:
Vehicle must be horizontal and standing on its wheels.
Drive vehicle onto four-post lifting platform or over pit.
2 Mount rod head (98) on intermediate lever (97) and secure with clips.
3 Move range selector lever (33) to position "D".
4 Insert shift rod (63) into rod head, attach to range selector lever (33) and secure with clips.
5 Tighten bolt (99).
NOTE:
Press against the rod head (98) to tighten.
Do not twist shift rod (63) or rod head (98).
Do not move range selector lever (33) out of position "D".
6 Check function.
#16 Old 3 Weeks Ago
Other Toys: Jeeps
Here is a diagram
File Type: gif 647C4623-4705-467F-A768-C8AA084BED88_1561575453130.gif (16.8 KB, 3 views)
M4rCu5 likes this.
#17 Old 3 Weeks Ago
Other Toys: Jeeps
Etc dtc 18
File Type: jpg C26D1809-8CE9-4E31-9A66-EE0399136FA3_1561575616410.jpg (65.0 KB, 4 views)
#18 Old 3 Weeks Ago
Quoted: 106 Post(s)
Yep, that's it...................
I do however find it best to do them in N as it is kinda "mid range", I just pop the Clip, pull the Rod, Trans lever in N, Shifter in N, adjust Rod so it is a nice easy sliding fit without moving either Trans or Shifter, lock it up, job done
If you still have the same problem after this then it is likely a damaged or bad P/N microswitch on the Conductor Plate
Hope you didn't buy a Chinese Conductor Plate
HTH, Cheers Dave
M4rCu5 likes this.
#19 Old 3 Weeks Ago
Turdo2's Avatar
Quoted: 333 Post(s)
quick thought. how are the motor and trans mounts?
M4rCu5 likes this.
Turdo2 is offline
#20 Old 2 Weeks Ago
Other Toys: Jeeps
Well after I got home last night the new to me junkyard tcm was there so I swapped it out. No more code. Took it for a short drive still no code. But didn’t have the time to take for a long drive to be sure it is fixed. So tonight after work I will take it for a longer drive and if still ok I will drive to work tomorrow. I drive 70 miles each way to work, yes that’s right 140 miles a day. So I need to be sure the car is right before I take it to work. As for the question about mounts they look good and the motor doesn’t move around too much so for now they will be left alone. But I am planning to replace them in the near future. I will also be upgrading the brakes and rotors, headlights, and thinking of adding a rear sway bar.
M4rCu5 likes this.
