Transmission Oil choice? - Mercedes Benz SLK Forum
 17Likes
  • 4 Post By i860
  • 4 Post By Elmer Fudd
  • 1 Post By M4rCu5
  • 1 Post By Avel Du
  • 1 Post By i860
  • 1 Post By Mercslk
  • 2 Post By Alex 3
  • 3 Post By i860
#1 Old 3 Weeks Ago
Vehicle: Slk230 (170) 2001
Quoted: 9 Post(s)
The transmission dipstick oil level reads just below the hot mark, merc says use atf 134 which I believe is semi synthetic, I have a bottle of atf dx 111, I think this is mineral, can I add a little of the dx to what's already in their ? Thanks
Mercslk is offline
#2 Old 3 Weeks Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 859 Post(s)
You need mb 236.4 approved oil. I will not mix it with mineral oil.
i860 is offline
#3 Old 3 Weeks Ago
Elmer Fudd's Avatar
Quoted: 187 Post(s)
is it between the two marks
with the engine running, at normal temperature, you having popped it through the gears for a few seconds in each choice, up and down the box. If yes, don't worry. As long as it's between the marks you are fine.
If you haven't done all the above....
as for mixing, probably won't damage it, but I try not to move away from stuff which is listed as correct. Which doesn't have to be a big brand, but it has to meet the spec.
jbanks15, M4rCu5, Avel Du and 1 others like this.
Elmer Fudd is offline
#4 Old 3 Weeks Ago
Quoted: 9 Post(s)
Oil level when hot below lower hot marker, not in between, thanks
Mercslk is offline
#5 Old 3 Weeks Ago
M4rCu5's Avatar
Quoted: 178 Post(s)
So you're saying it's just below the lower warm range mark when it's warm (80c)?
M4rCu5 is offline
#6 Old 3 Weeks Ago
Quoted: 9 Post(s)
Just below 5.3 cm on drawing
Mercslk is offline
#7 Old 3 Weeks Ago
M4rCu5's Avatar
Quoted: 178 Post(s)
Seems that you've lost half a litre 'somewhere'.
I'm with the other guys, top up with mb spec fluid.
That 'somewhere' needs to be addressed tho.
Dave2302 likes this.
M4rCu5 is offline
#8 Old 3 Weeks Ago
Quoted: 9 Post(s)
Plan to replace filter and oil later in year. Merc wants £450 to do the job. Parts are only £80 think they are having a laugh.
Mercslk is offline
#9 Old 3 Weeks Ago
Moderator/RoTMorganiser
Quoted: 2138 Post(s)
Isn't the 170 the model where it creeps inside a cable?
https://www.slkworld.com/gtsearch.php...l%20in%20cable
Need to check for that.
M4rCu5 likes this.
#10 Old 3 Weeks Ago
i860's Avatar
Quoted: 859 Post(s)
£78.13
£25.33
Gasket, oil filter, 6x screws, electric connector, plug and washer.
£52.80
8l of Fusch titan atf
They arrived today, planning to do the job on an slk 230 on tue.
M4rCu5 likes this.
i860 is offline
#11 Old 3 Weeks Ago
Quoted: 9 Post(s)
The auto box on my 220 cdi was playing up, I purchased the electronic insert (forgot name) that fits into the gearbox and it fixed the problem, the old fitting was covered in oil.
M4rCu5 likes this.
Mercslk is offline
#12 Old 3 Weeks Ago
Other Toys: Traded them all!!
Quoted: 101 Post(s)
You have a dipstick?
Alex 3 is offline
#13 Old 3 Weeks Ago
Quoted: 101 Post(s)
Did I miss something here? OP said transmission and referred to ATF from which I concluded he has an automatic, My understanding is the 722.6 is sealed for life and needs no fluid top up IF YOU BUY into the that fable. Of course someone could have installed one as I recall there are kits.
Alex 3 is offline
#14 Old 3 Weeks Ago
M4rCu5's Avatar
Quoted: 178 Post(s)
Maybe
MB Medic
or
Pelican Parts
M4rCu5 is offline
#15 Old 3 Weeks Ago
Quoted: 101 Post(s)
Originally Posted by M4rCu5 View Post
Cheers!
Australian and M4rCu5 like this.
Alex 3 is offline
#16 Old 3 Weeks Ago
i860's Avatar
Quoted: 859 Post(s)
Did the job today.
Australian, M4rCu5 and Dave2302 like this.
i860 is offline
